Freightliner with detroit fault codes - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 03-01-2008, 02:46 PM Thread Starter
Anyone know what codes 26 and 62 mean on a 2000 freghtliner with a 60 series detroit? Thanks
Early 99 Ford F-350 4X4 Extended Cab Dually, 4 in lift, 6spd, dual 5in stacks,ts 6 stage, zoodad, ccv, tymar,
240,000 miles and counting
1993 Ford F-350, 4X4, Fuel Injected 460, MUD TRUCK, 40in super swampers, Dana 60 Front, Dana 70 Rear, 10in home made lift.
1982 Mustang 302 HO
HOURS TO BUILD, SECONDS TO BREAK
mflores is offline
post #2 of 4 (permalink) Old 03-01-2008, 06:19 PM
Code 26 is an " auxilary shutdown active.
Code 62 is a digital output open or shorted to ground.
Hope that helps.
95 F250,XLT, 4WD, Auto Trans,bbshimmed,synthetic trans oil,4:10 gears ,Truck Trunk ,Nerf Bars ,crome Mud flaps, Aux. trans cooler, front diff. drain plug. External trans.filter, trimmed snorkel. American wheels water temp guage, front fuel tank mod,Warn Manual hubs,Putman class 4 hitch 212k mi.
Currently also have 2012 Dodge 4X4 with a Cummins engine.
It is said if you sit by the river and watch the water flow by long enough, your enemies will pass by. This I believe to be true. It is also possible to watch your loved ones pass by as well.
Wife Candi 08/14/07 missing her always
Gone Fishen is offline
post #3 of 4 (permalink) Old 03-01-2008, 06:46 PM Thread Starter
Helps a little but not a lot. For some reason it will shut its self down when ever it wants to and I cant figure out why. Replaced the cam and crank sensors but didn't fix it. Anyone know what "digital output open or shorted to ground" means?
1982 Mustang 302 HO
mflores is offline
post #4 of 4 (permalink) Old 03-01-2008, 08:29 PM
Does your truck have 'optimized idle' as a function? If so you might have an issue with the cab wiring to the temperature controls in the sleeper. Does the truck shut down say every time at 3 minutes? Sounds like a wiring issue to me. You need to have a laptop to see what is shutting the engine off. Also the laptop will tell you what wire #. You can look at the programming feature in the laptop and find out what that wire is set to.
  Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
