Guy sues GM for overheated LLY Duramax - Page 8 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
Old 01-22-2007, 11:23 AM   #106 (permalink)
Re: Guy sues GM for overheated LLY Duramax
Obviously common sense is not required to buy a Heavy duty pu and haul some weight.
This goes back to the belief that NO common sense is required by the American consumer and this is why the manufacturers have made all the gauges idiot proof.
Just because one vehicle (Duramax) is less capable than another (Cummins or 7.3) does not mean it is faulty. It's just less capable. All my CATs run hotter than my Cummins motors but that does not mean they are faulty it just means the limits of the equipment are lower.
I sell Kenworths for a living and if the average trucker just felt that under all conditions he should be able to just run up the road at full throttle no matter what every truck would have blown up by now.
Early '99 7.3 Superduty. Built 3-98
Built motor. Homemade "Big Oil", GT42R Big frame turbo. Rods and junk to keep it all together.
http://community.webshots.com/myphot...ecurity=MuSLdj
Suns_PSD is offline
Old 01-22-2007, 12:53 PM   #107 (permalink)
No, all they needed to do was put a bigger radiator in the cats. I have an E model cat and the thing did start to heat pulling long hard hills. I had them put a new bigger radiator in it and I can run that thing all day long and I cant get the needle to move. It comes down to putting the right equipment in the truck from the start.
Early 99 Ford F-350 4X4 Extended Cab Dually, 4 in lift, 6spd, dual 5in stacks,ts 6 stage, zoodad, ccv, tymar,
240,000 miles and counting
1993 Ford F-350, 4X4, Fuel Injected 460, MUD TRUCK, 40in super swampers, Dana 60 Front, Dana 70 Rear, 10in home made lift.
1982 Mustang 302 HO
HOURS TO BUILD, SECONDS TO BREAK
mflores is offline
Old 01-22-2007, 01:21 PM   #108 (permalink)
Sorry Flores but if you knew much about the modern emissions motors you would know that the cooling systems have been optimized and just making them larger is not something that can be done at this point due to simple space constraints. E motors are ancient history.
The only way to GUARANTEE that a certain motor hauling a very heavy load absolutely will not overheat under even the most trying conditions is to WAY underrate the motor. For instance, Cat could guarantee their motor would not run hot under any circumstances if they rated it at say 200 hp. But that is not acceptable 99% of the time when not hauling under these horrendous conditions so they give you more hp and expect you to use a bit of common sense when needed.
Some people have this theory that you should be able to load the thing up as heavy as possible, run it absolutely full throttle indefinitely on the hottest day of the year, and the manufacturer should plan for this outrageous circumstance as part of their design perimeters? ***? They are not designed to be absolutely idiot proof.
Suns_PSD is offline
Old 01-22-2007, 01:32 PM   #109 (permalink)
And if you did make it idiot proof, someone would simply make a better idiot! [img]/ubbthreads/images/graemlins/smirk.gif[/img]
'06 Ram 3500 4X4 QC CTD 6sp LB
'01 F350 PSD 4X4 6sp Crew Cab (sold)
'68 F250 C/S 4X2 C6/428PI
Stidham 24' enclosed car hauler
Bunch of big old cars
In theory, practice and theory are the same.
In practice, they are not.
Packard8 is offline
Old 01-22-2007, 02:03 PM   #110 (permalink)
My Photos: (27)
Couldn't agree more. Years back I was having a slight overheating problem under extreme towing conditions after I installed my ATS turbo kit. Talking to a 7.3 Ford diesel mechanic he said, "You think you got problems, I got a guy's pickup in here, turbocharged, and he pulls a 19,000 lb. high profile 5th wheel and I'm supposed to solve his overheating problem". The Ford rep had told him he wished these huge heavy trailer designers had to design the trucks to pull them with.
I did fix mine however by installing the late model front bumper trim piece and cutting out the later model air holes in my bumper.
'91 F-250 SC 4X4, 5spd. ATS Turbo http://sports.webshots.com/album/180135797kNEIOu
LMJD is offline
Old 01-22-2007, 02:08 PM   #111 (permalink)
mudguppy's Avatar
My Photos: (12)
i guess the arguement of the post is that this guy wasn't pulling over his weight rating. so should his truck overheat while pulling less than max weight rating?
Travis
'03 F350 Dually, 6.0, Supercab, longbed, 4.10 LS, sport pkg, extremely RED, STRAIGHT PIPED, SCT Xcalibrator, full guages
- Job1 programming, Harpooned, Skweeker Mod, Zoodad Mod
- Did that thing that you're not supposed to talk about
'79 Bronco, 468cid Ford 460 marine motor, C6/NP205
Previous -'99 F250, Rg Cab XLT, 7.3/6spd, 3.73
Project truck
- '96 Cummins, 215hp/5spd, Diprocol guages, Plate & AFC full fwd, hi-capacity external lubrication system
To add: 2 1/2T axles, 46" goodyears, etc.
mudguppy is offline
Old 01-22-2007, 02:12 PM   #112 (permalink)
My Photos: (60)
This one has gone around the barn several times, time to move on I would think. The point has been made about the driver's lack of concern with his equipment.
Closed.
Dave / Believer45
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
LINK TO LIST OF THE FALLEN
'95 F250 ext cab long bed, PSD, 5 speed, 2 wheel drive, 3.55 gears, 286,000 miles, Edge Evolution CTS (LINK TO MY REVIEW), LUK clutch, homemade REAR BUMPER, open element AIR FILTER, 36" ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
Believer45 is offline
