How long will Diesel fuel keep? - Diesel Forum - TheDieselStop.com
post #1 of 16 (permalink) Old 08-26-2006, 04:03 PM Thread Starter
rms0726ea's Avatar
I know that diesel breaks down quicker that gasoline. My question is:
How long can you keep diesel fuel in storage containers (i.e. 5 gallon cans) before it goes bad. I assume that adding in an additive will help extend the shelf life - but how long [img]/ubbthreads/images/graemlins/shrug.gif[/img].
Anyone have any info or comments?
Thanks!
, 2003 7.3L F250 Lariat, Swamps 175/146 single shots, MBRP exhaust, AIS w/fender sleeve & Zoodad, ISSPRO A-pillar 3 gauge kit(pyro/boost/tran temp), DiPricol HPOP & Fuel, oilguard bypass filter, CCV mod, extreme duty tranny (by Jon Faubion-Richter69), BTS (PI) Torque Converter, AIH delete, 6.0 trans cooler, van turbo w/wicked wheel, Gutted EBPV,
, HX mod, Bilstein Shocks, Firestone Ride-Rite air bags w/compressor,
, Schaeffer's 15W-40, ITP in tank mod/pre-pump filter, Harpoon mod
rms0726ea is offline
post #2 of 16 (permalink) Old 08-26-2006, 05:06 PM
Re: How long will Diesel fuel keep?
Gasoline should be used in 60 days or so.
Diesel will easily last a year if it's kept dry and free from contamination.
www.chevron.com/products/prodserv/fuels/diesel/documents/diesel_fuels_tr.pdf
Look near the bottom under FAQ.
There was a post here sometime ago about a diesel automobile that was in storage for something like 26 years and was still able to be run on the old fuel. Diesel lasts much longer than untreated gasoline. Not sure if Sta-Bil works on diesel like it does on gasoline.
2001 F 250 Platinum Edition
7.3 PSD CC SWB 4x4 3.73 LS 4 spd auto
Mods- Autometer Tranny Temp Gauge, Hard Tonneau Cover
wandrews is offline
post #3 of 16 (permalink) Old 08-26-2006, 06:11 PM
Wobblin-Goblin's Avatar
Diesel will last indefinitely if stored properly.
2003 F-350 SRW XLT 7.3L 4R100 PSD 4x4 Supercab SB 3.73
1994 Dodge 3500 SLT Dually 5.9L Cummins NV4500 5spd US Gear "splitter" Exhaust brake 4x4
RETIRED: 1985 Chevy K20 6.2L Turbo-400 3spd auto 4x4 4.10
2003 Ford Explorer XLT 4.0L V-6 5-spd auto 4wd 3.55
NRA Life member
Wobblin-Goblin is offline
post #4 of 16 (permalink) Old 08-26-2006, 07:05 PM
My little Kubota sits for months on end and I never had a fuel related problem. Dang gasoline in the mower and trimmer on the other hand..[img]/ubbthreads/images/graemlins/phoney.gif[/img]
Not sure where some folks get their info. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
99 PS XLT 3.73 SC Auto Shorty, WD chip, triple A-pillar gauges
Ernest is offline
post #5 of 16 (permalink) Old 08-27-2006, 10:56 AM Thread Starter
rms0726ea's Avatar
Wow, that's good to know. I guess I was wrong - I thought diesel broke down quicker than gasoline. Thanks for all the info & quick replies everyone [img]/ubbthreads/images/graemlins/cool.gif[/img].
WB
post #6 of 16 (permalink) Old 08-27-2006, 03:11 PM
Hm, as I have my PhD in Chemistry I should know but why does fuel or gas break down? They are so small molecules that there cannot be a break up reaction at normal conditions. The only thing I ever heard is that there are some organisms living in it. A bigger problem for fuel companies or oil tankers, though.
Jim
2009 F250 PSD 4x4 CC LB KR
2007 Suburban LT3
2007 Yukon XL Denali
2005 F250 PSD 4x4 CC LB KR
JimJoe is offline
post #7 of 16 (permalink) Old 08-27-2006, 05:21 PM
OT
OT's Avatar
No PHD here, but think water is certainly involved.
FWIW www.batterystuff.com has alittle info. on fuel etc.
03 F250 XLT SC/SB 4X4 6L (stock) TqS. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
post #8 of 16 (permalink) Old 08-27-2006, 09:32 PM
Jim
Water
Organisms
Aromatic Distillate evaporation.
Too much junk/toys to mention, ever changing due to too getting bored too quickly. I need a 10 step program!
Want to call? I'm in the book. Want to argue....First explain the square root of negative one....lol
roofeditor is offline
post #9 of 16 (permalink) Old 08-27-2006, 10:49 PM
I started a Kubota B3000 that hadn't been touched in 10 years on the 10 year old Diesel fuel in it's tank.
Ran great! [img]/ubbthreads/images/graemlins/laugh.gif[/img]
hellokitty is offline
post #10 of 16 (permalink) Old 08-27-2006, 11:25 PM Thread Starter
rms0726ea's Avatar
Thanks wandrews for the link to the chevron document. Good info....
post #11 of 16 (permalink) Old 08-28-2006, 12:42 AM
CowKiller's Avatar
My Photos: (12)
my 6.9 sat for 1.5 years with half tank of off road fuel. fired right up and ran fine. fuel filter was dirty as all hell when i replaced it after that tank. i dumped it out and cut open just to looksie
PLAY TRUCK
1986 F250 6.9,ATS turbo, np435, BW1356, hp 60,welded up sterling 10.25.
converted from 2wd to 4x4
sittin on 36x12.5 goodyears
GETTING CONVERTED TO SHORTBED AS WE SPEAK!
TOW RIG
2002 gmc 2500hd 6.6 duramax 5 speed allison
4x4 extened cab.
2000 F550 Lube Truck (Work Truck)
Certified PA Inspection Mechanic
i'd rather be 6.9'n than cummin or strokin'!
CowKiller is offline
post #12 of 16 (permalink) Old 08-31-2006, 11:45 AM
Also try Pri-D. I've used it and have had no problems. Fuel looks clean and clear as the day I bought it.
http://www.priproducts.com/
2004 F-250 6.0 PSD SWB Crewcab 4x4
32K miles
dcbroussard is offline
post #13 of 16 (permalink) Old 09-01-2006, 10:18 PM
rmr
I bought a boat once, it sat for 15 months with the tanks full, it ran fine, I couldn't tell any difference when I filled up with fresh fuel.
1986 F250,Regular cab,XL,4X4,6.9, 4 speed,
rmr is offline
post #14 of 16 (permalink) Old 09-07-2006, 04:11 PM
My Photos: (24)
My boat holds 205 gallons of gasoline, and sits from late October till late April. Sometimes I add Sta-Bil, sometimes I don't. Always runs fine.
2001 F-250 (pcm PMT2) ISS Pro EV tranny, boost, pyro gauges. TS Performance flip chip. Banks MONSTER exhaust, Maghytec rear diff cover, ITP H/X kit, Whelan 52" Strobe Bar, Fisher 8.5' Snow Plow, 3 Weatherguard tool boxes. HUTCH fuel tank mods, REMANFACTURED Ford transmission.
CPSS is offline
post #15 of 16 (permalink) Old 09-07-2006, 06:29 PM
have taken fuel oil out of house barrels that were there for 30 yrs with no use--fuel was fine--and had no organisms--temp controlled basement probably helps--but have taken it out of junk cars and trucks also--no problems--im a scavenger---
94_turbo is offline
  Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
