General DieselDiscussion about diesels in general. All brands are welcome, please refrain from brand wars. Discussions about types of diesel fuel also go here.
I have the chance to buy an 86 Chevy K20 silverado, with a 6.2 diesel and a manual tranny, which HAS an overdrive. I've never seen one before, have you?
2000 F-350 Super Cab,Long Box,4x4,7.3L PSD, Bully Dog Chip,6 sp. LEVER ACTION, Camper Pkg.,200k,Lariat, Clearance lights, White on top,Gold on bottom,Gold interior. 285/75/16 BFG's, Dieselsite.com 203* T-stat, alum. T-stat neck and coolant filter kit with Fleetguard WF2077 filter added.
1993 F-250 Reg. Cab 4x4. XLT. 7.3L IDI, E4OD, 4.10 rear, Fleetguard WF2077 coolant filter. Born: 9/92, 163k, Lumbar bench with armrest. White on top, blue in middle, white on bottom. Clearance lights,DeeZee diamond plate running boards to back of cab. True dual exhausts with glasspacks and 4" stainless tips. Pretty well stock except for Pioneer CD player.
If there is no rust and the engine compartment is stock it is a rare thing these days.
Ask if the head gaskets have been changed. If they have not I am betting you will be.
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
Assuming it's a four speed, with lots of four speeds and bigger (in physical size and number of gears) you can press gears off the countershaft, switch the corresponding ones on the main shaft,re-assemble them in a different order and your highest gear is no longer direct, it's an overdrive. Your shift lever pattern becomes different also.
Well by saying "HAS an overdrive", i just mean it's not like the regular low geared 4 speed put in these trucks(actually a 3 speed with a granny). I mean it isnt L,1,2,3....it's 1,2,3,OD.
only thing id worry about is these trucks, chevy diesels, tend to be x military if it is its problay been beaten ran till it died then they put in a new drive train and ran it till it got bad then sold it
if its always been a civilian truck and you could prove that id say berret jackson auto auction they rarer than most 60000$ muscle cars
88 F-250 body,550 rear frame setup, 7.3 idi, back up camera, class 5 bumper hitch welded to frame and gusseted, front mount hitch and off road lights,93 front clip, headache rack, 37" humvee tires, ac power converter,factory buckets from quadcab, power windows and locks,cobra 29 cb w/ 102" whip, high lift jack behind seat, toolbox for the junk, visor, running lights, huge front bumper, oba,
in progress western style mirrors, holset turbo, airhorns, and some other goodies
actually if it is a military truck, then it's possible that it has been abused but not likely. (Most) military vehicles are low mileage and have had regular maintenance performed on them.
1997 F250 HD 4x4 5speed Reg Cab, 4" MBRP exhaust, 1.0 turbo housing, Tymar Intake , 17* HPOP,Swamps 150cc, TW 4 position chip, Dana 60 w/RSK, Crossover steering, sittin on 35's
Yeah, military vehicles do get regular maintenance, but they also get beat on pretty hard, just like rental vehicles.
Granny wouldn't do anything crazy in her new cadillac, but she'll cut donuts in her loaner cavalier!! [img]/ubbthreads/images/graemlins/shocked.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Dave
Smokyred- RED 11/97 F250HD XLT SCLB Auto 4.10LS 4x4 OFFROAD
Mods: Swamps tunes, Swamps 275/226's, a Gen3, a BTS, Comps, Crowers and H11's up top, S465/TN II mount kit, Custom Comp. fuel system, and an IC.
Good point, but all I remember from our USAR motorpool were K2500 6.2's w/ auto trans. Should be able to read the VIN and see if it is original.
[img]/ubbthreads/images/graemlins/shrug.gif[/img]
'06 Ram 3500 4X4 QC CTD 6sp LB
'01 F350 PSD 4X4 6sp Crew Cab (sold)
'68 F250 C/S 4X2 C6/428PI
Stidham 24' enclosed car hauler
Bunch of big old cars
In theory, practice and theory are the same.
In practice, they are not.
also, if it were ex-military it'd have been 24volt, which is a dead give away. even if it's been converted back to 12v, you still may be able to tell - the 24v wiring system was pretty heavily integrated into the underhood 12v system. basically it's a rat's nest.
also, there'd have been a hole cut in the grill for the NATO slave receptical. it basically looks like a giant male DC plug end.
and, sure enough, by '86 the army was well on it's way in phasing out manual shifted vehicles. every CUCV i've ever seen had the TH400 auto behind it. i've never seen an OD green 6.2 Cheby w/ a stick.
there's many more signs. basically, it's hard for a military truck to look like a civvy truck again.
i'd put my $ that it is not a military truck.
and, btw, are we SURE that it has an overdrive?? i mean, if it had real tall gears in it, like 3.08s or something, then L,1,2,3 sure would seem more like 1,2,3,OD. right? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Travis
'03 F350 Dually, 6.0, Supercab, longbed, 4.10 LS, sport pkg, extremely RED, STRAIGHT PIPED, SCT Xcalibrator, full guages
- Job1 programming, Harpooned, Skweeker Mod, Zoodad Mod
- Did that thing that you're not supposed to talk about
'79 Bronco, 468cid Ford 460 marine motor, C6/NP205
Previous -'99 F250, Rg Cab XLT, 7.3/6spd, 3.73
Project truck
- '96 Cummins, 215hp/5spd, Diprocol guages, Plate & AFC full fwd, hi-capacity external lubrication system
To add: 2 1/2T axles, 46" goodyears, etc.
Im pretty darn sure its been a civvy truck its whole life, it does have an OD on the shift knob.
Have you actually confirmed that it is an OD trans? Easiest way would be to jack up the read axle and mark the drive shaft then give the engine one 360 deg turn from TDC to TDC on the front pulley (with the tranny in OD). My experience with 20+ year old vehicles is that stuff can get changed around a good bit....what you see ain't always what you get [img]/ubbthreads/images/graemlins/eek.gif[/img]
Could it be a shift knob (or even a tranny) from another truck? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Keep us posted, if it is an original OD it would be pretty rare.
yeah I would check and make sure it's OD for sure, try and get some #'s off the tranny or jack it up and check the revs. someone could have just changed the knob...
__________________ 2001 F-250 PSD Crew Cab short bed, 4x4 Lariet, only 97k miles bone stock for now
previous trucks: 2001 F-250 PSD CC SWB 4" lift, 315's, DP Tuner.. late '99 F-350 PSD CC LWB 4" lift, 315's, DP...... early '99 F-250 PSD SC SWB short shifted 6-speed, 5" stacks, 5.5" lift, 4.30 gears, DP Tuner, etc.... 1997 F-350 PSD 4x4, 4" lift, 35's, Superchips tuner
Yes chevy actually made this tranny I had one a few years back. I've only seen one of them and heard of two others yours and another guys. So the tranny in this truck truck makes it pretty rare.
