Ignition Shutdown Timer - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
Old 10-22-2009, 12:40 AM   #1 (permalink)
Unhappy Ignition Shutdown Timer
Just a quick question. I used to have manual timer for turning off the engine on my Peterbilt. Would simply dial to the time you wanted the truck cool down, and turn the key off.
I have looked on google, and most everything is computerized now. Does anyone know who makes these still and where I can pick one up. With the new idle laws, would be nice to have one.
Thanks in advance for any information.
ase111 is offline
Old 10-22-2009, 05:31 AM   #2 (permalink)
My Photos: (5)
A modern engine installation usually has a wire from the ignition switch to the brain box telling it when to turn the engine on & off. It should still be possible to install a shutdown timer by interrupting that wire.
The one surprise you might encounter is that because that wire carries almost no current, tarnish might build up on the timer points. The arc which results from interrupting current serves to keep switch points clean, and there won't be any arc in this case. It'll take a year or more to crop up.
To prevent this, select a timer with precious-metal contact points rated for "dry contact" or "logic level" switching.
Douglas Campbell, P.E.
1986 Isuzu P'up, 177,673.8 miles.
- Hella headlights (highly recommended)
- DOT C-2 back end (also recommended)
- R-12 air conditioner converted to R-406a. Saved ozone and money
- 4.1:1 final drive converted to 3.4:1. Quieter, better mileage but it's a good thing I live in the flat Midwest.
- 9/22/2007, age 21: Still running well when reluctantly sent away for reincarnation, due to body & frame rust.
drcampbell is offline
Old 10-24-2009, 09:32 PM   #3 (permalink)
CATTC's Avatar
I still see this setup on new Peterbilts...any Pete DLR parts man worth his salt should be able to help you identify the p/n
CATTC is offline
Old 10-24-2009, 10:20 PM   #4 (permalink)
drcampbell, I have purchased a Turbo Temp. Monitor from Isspro. The instructions say to connect the control module to the ignition switch wire I believe you make reference to in a previous post. My question is; which wire is it, and where is it located? What color? I have a 2005 PSD.
BigBertha is offline
Old 10-25-2009, 12:35 AM   #5 (permalink)
My Photos: (5)
I don't know offhand, not to that level of detail, but it'll be on the wiring diagram.
