Interesting oil article - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
Old 10-03-2009, 09:34 PM   #1 (permalink)
rock_doctor's Avatar
I don't know if this has been posted before but it is an interesting read, since he rates Rotella T as one of the worst....and that is what i use.....Turbo Diesel Register Tech: Lube Oil, Religion, Specifications and the TDR
2005 Excursion w/ 6.0L PSD
2008 FX4 F250 CCSB w/ 6.4L PSD
rock_doctor is offline
Old 10-04-2009, 09:57 AM   #2 (permalink)
Very interesting article. Because of this I will probably change the oils I use in both my diesels. I was going to use Synthetic Rotella T in my '08. Simply because I put little milage on it, 5-6K per year, and it is a newer truck. My '02 I have been using Motorcraft 15W40. I buy it at Wal Mart and the price is cheap. I figure Ford makes it so it should be good enough. This truck I put more milage on. I also use 1 quart of Lucas Synthetic Stabilizer at each change with the Motorcraft oil. Blackstone Labs recomended Lucas for my race car, so I figured it would be good for my diesel. Now I think I will use the Valvoline Blue, plus a quart of Lucas, in both trucks. It would be good to see similiar testing on additives, like Lucas.
wheelhopper is offline
Old 10-04-2009, 11:21 AM   #3 (permalink)
dieselmankane's Avatar
I have heard Lucas is a BIG no no in Powerstroke diesels, as it causes foaming issues, and lack of lubrication. Also, he says oils 1 and 8 are his favorites, and since winters are failrly cold here in Idaho, I'll keep running Rotella Syn 5w40.
2003 F250 Super duty 6.0 PSD, was great in the beginning, but started to have major issues:
Traded, Oct 2 2008 for...
New truck: 2008 F250 Superduty Lariat 6.4 PSD Job 3, black, with ALL the goodies, very impressed so far...
[SIGPIC][/SIGPIC]
dieselmankane is offline
Old 10-04-2009, 04:38 PM   #4 (permalink)
I'm with you, i have been using rotella t for 30 yrs but from now on i'm using Valvoline Blue.
Old 10-04-2009, 07:32 PM   #5 (permalink)
OT
OT's Avatar
RDr..Interesting report. Althou kinda odd (for me) Delo 15W/40 not tested? Have you considered asking shell about this report & findings? My guess is they would respond, just a thought. Chevron tec. answered Q's I had about their delo. especially interesting on why adding additives not a good idea. change's chemistry etc. etc.
btw..this test LUCAS OIL additive is dated, but might be reason enough not to use in ANY brand? Like the man said..draw your own conclusions. RT report also surprised me.
03 F250 XLT SC/SB 4X4 6L (stock) A/T. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
Old 10-04-2009, 09:23 PM   #6 (permalink)
I did not notice that. Delo is a major player in the game. I do find these types of reports interesting and since i have always used Rotella T and since my GM diesel went over 700k miles on it (before the body was no longer legal) and still did not burn any oil you have to wonder if you are missing something when you read them... I also wondered if rotella has the lowest zinc because it is meant for the new generation of diesels with catalytic converters and dpf while the others are meant for more industrial applications like stationary engines which do not need to meet the same emissions requirements. I did look to see if "Bob the oil guy" had a similar comment on his site but he had not gone in that direction. I wonder, i would prefer to stick with the oil that i know.... The jury is still out, i likely will reach for the white bottle at the end of the month for the next oil change.
Old 10-05-2009, 08:20 AM   #7 (permalink)
t613's Avatar
Not to mention there was only one CJ-4 oil tested (the lowest-ranked). Without the typical additives found in CI-4, wouldn't the CJ-4 be "worse" (although mandatory for a 6.4L with a DPF)?
I would like to see all of the same brands tested with a CJ-4 rating to see how they all compare, apples to apples. But for now, same old Motorcraft for me!
2008 F-250 XLT Supercab 4X4 6.4L Auto, short bed
Toreador Red, 3.73 gears, Job 1, Huntsville motor
t613 is offline
Old 10-05-2009, 02:20 PM   #8 (permalink)
BeatMarti's Avatar
Very interesting -- however, I would love to see a comparison of CJ-4 oils as that is what I end up having to use for this engine.
BeatMarti is offline
Old 10-05-2009, 02:29 PM   #9 (permalink)
Rotellla T dino and Rotella T syn? The Rotella dino was rated 4th ot 5th (not too bad) and CJ-4 is MANDATED for the 6.4?
2008 Job-3; 6.4; F-350 Crew Cab Lariat;Black; short bed; 4x4; 20" wheels/tires; bone stock and will probably stay that way
yukondiesel is offline
Old 10-05-2009, 02:50 PM   #10 (permalink)
the number on the list isn't the ranking it is just its number on the list. You have to go through the text to get his comments on each brand. The new dpf diesels need to use CJ-4 oils which are low ash oils. Most of the oil you will find now a days are CJ-4.
Old 10-06-2009, 08:08 AM   #11 (permalink)
t613's Avatar
The Rotella syn was rated CI-4, not CJ-4. My point was that the Rotella dino was the only CJ-4 oil tested and was the "worst" ranked (read the text, not the reference number). Would love to see the same test with ONLY CJ-4 oil (because that's what we have to run, at least until our DPFs fall off). That would mean more to me than a mix of types.
t613 is offline
Old 10-06-2009, 10:51 AM   #12 (permalink)
My Photos: (27)
You're kidding. Rotella T is one of the best ones out their, the heavy trucking industry has been using it for years. Many of those oils are not even on an equal playing field, Castrol GTX Diesel is for diesel cars and light pickups, it's not even rated for heavy trucks which some of the others are. One of the REAL Castrol heavy diesel engine rated oils comparable to Rotella T, Delo, is RX Super 15-40. And most all heavy diesels, including smaller diesels require 15-40wt, and one of his favorites is the 5-40.
What say you, Believer 45, you've been in the industry quite a while?
'91 F-250 SC 4X4, 5spd. ATS Turbo http://sports.webshots.com/album/180135797kNEIOu
LMJD is offline
Old 10-07-2009, 03:18 PM   #13 (permalink)
Most of the logging trucks out here use Delo 15-40, the guys like Cat power.
So, I do not think you would see them using Delo if it was not up to spec for heavy truck diesels.
1999 7.3 F450 Cabriolet Crew Cab with Aluminum hauler bed (love the side storage!), Banks Power Pac, Donaldson Air Filter, Set up for Fifth Wheel, Gooseneck and bumper pull. ATS Billet Transmission, ATS Five Star Torque Converter, ATS Co-Pilot. Pulling a 34 ft. Silverado Aluminum Horse Trailer with Living Quarters.
This F450 will be replaced with a heavier truck, maybe a Freightliner or a Peterbilt around 25,000 GVW. AND with a big manual transmission.
SilveradoHauler is offline
Old 10-07-2009, 07:33 PM   #14 (permalink)
My Photos: (27)
Yep, Chevron Delo has a good rep and is one of the most popular in the diesel industry. Every diesel shop I worked in for over 25 years stocked only Delo 15-40 and Delo 30wt.
LMJD is offline
Old 10-12-2009, 08:11 PM   #15 (permalink)
Lucas "Oil Stabilizer" has a viscosity of 110 cSt @ 100 C., about as thick as 1000 weight gear oil!! In their MSDS they describe it as "residual oil", which is what the US Navy used to burn in warships till they changed to JP8. In ships it requires pre-heating to flow. I would only put it into a crankcase if I had a bad bearing and I just had to get somewhere to tear the engine down. It is absolutely bad for Powerstrokes due to the HPOP.
Their "Synthetic Oil Stabilizer" still has a viscosity >40 cSt at 100 C., which is about what 180 weight gear oil is rated at. Lucas says it's OK for Powerstrokes....I don't agree.
Incidentally, analyses of these Lucas products posted on BITOG show they are nothing but very thick oil.
Charlie
diesel Landcruiser & M37; 05 Unimog U500 w/Unicat camper
Charlie is offline
