International DT466E trouble codes. - Diesel Forum - TheDieselStop.com
post #1 of 15 (permalink) Old 05-13-2011, 10:51 AM Thread Starter
I am not sure if this is the right place to post this, but could not find anything more fitting.
I am the general manager an wholesale ice cream company, and we have a few International trucks doing our deliveries. I am having a problem with one of the, that my mechanic has been reluctant to address, and was wandering if some of you guys had some suggestions.
The truck is an International 2004-2006, Model 4300, Engine DT466E with an Allison MD transmission. The rated HP is 245.
The DTCs are:
1. DTC: 222, SPN: 247, FMI: 2 Break Switch Circuit Fault;
2. DTC: 353, SPN: 27, FMI: 5 VGT Over Duty Cycle;
After I got the DTCs from ServiceMaxx I was able to find some info on the 222 from the ISIS software. I could not find nothing on the 353 one.
I cleared the codes several times, but they keep coming back and are listed as Inactive. The yellow engine light is flashing occasionally when the truck is on the highway and over 55 MPH.
Any suggestions that you guys would be able to make in terms of what might be wrong and potential test/troubleshooting procedures would be greatly appreciated.
Thank you!
ser01 is offline
post #2 of 15 (permalink) Old 05-13-2011, 11:44 PM
You have ServiceMaxx and ISIS, and you're asking for help here? The descipitions are pretty self explanatory. Fix the brake switch issue and most likely your turbo is stuck. Depending on the part number, you may want to replace it rather than clean it.
Kevooo is offline
post #3 of 15 (permalink) Old 05-29-2011, 06:09 PM
on ISIS if you go to 466/570 EGR you will see 353
DTC 353 - VGT control over duty cycle
DTC 353 is set when the ECM overcompensates by increasing duty cycle to the VGT to achieve desired boost/back pressure.
Possible Cause
Comment
High intake restriction
Do "Performance Diagnostics" .
Intake / CAC system leak (pipes, loose clamps, hoses)
Exhaust system leak
BAP sensor bias low
Check sensor signal voltage. See "BAP Sensor" .
MAP sensor bias low
Check sensor signal voltage. See "MAP Sensor" .
EBP sensor bias low
Check sensor signal voltage. See "EBP Sensor" .
ICP sensor bias high
Check sensor signal voltage. See "ICP Sensor" .
Power cylinder integrity
ICP system integrity
Injector operation / part number
Check previous repairs. Do "Performance Diagnostics" .
EGR valve stuck open
VGT actuator or vanes sticking
VGT control circuit open or short to ground
Do VGT Pin-Point Diagnostics. See "VGT Actuator" .
VGT power and ground circuits.
90% of the time either the linkage is binding or the vanes in the turbo are seizing up. with key off you should be able to move linkage and let go and it should back bounce to the normal position, if it passes bounce test you have elec problems and you will need to check circuits to acutator. if you cannot move linkage International offers rebuild kits for most of those year turbos.
nhorn@windstream.net is offline
post #4 of 15 (permalink) Old 04-25-2015, 04:27 PM
need to get code list for 2008 ihc maxxforce engines
wtrulove is offline
post #5 of 15 (permalink) Old 04-25-2015, 06:59 PM
Your turbocharger is most likely having an issue.
It will either be the actuator that failed... the EBP Sensor... the linkage... or the Vanes inside turbocharger are stuck... without looking at the truck, i really couldnt give you more information, ive personally rebuilt well over a hundred of those turbochargers in my time...
the 222 code is nothing, dont worry about it, its literally inside almost every ECM ive plugged into to check codes.
Your truck needs to be brought to a shop before problem gets worse and you need a $2000+ turbocharger if it gets bad enough...
If its the vanes inside turbocharger they sell a kit to rebuild the internals of it for a couple hundred and afew hours of labor.. the linkage can be repaired usually by tearing it apart, cleaning pins, and applying anti-sieze to all moving components. The actuator can be replaced(turbocharger computer).
And the EBP (Exhaust Back Pressure) sensor only usually needs to be replaced if it is old part number style, they have new updated sensor to prevent false codes... your local Dealership can help you with that..
Hope this helps.
orjnlfarmertom is offline
post #6 of 15 (permalink) Old 06-03-2015, 02:28 PM
I have a 2007 International bus with a DT466. has a code 372. I have replaced the filter and the fuel regulator in the filter housing. still sets the code and light comes on.
Gbonewit is offline
post #7 of 15 (permalink) Old 06-03-2015, 07:53 PM
well sir the first and only question is... DO YOU have low fuel pressure? Thats most important thing to know before we can move further..
Could be a multitude of things but need to know if electrical issue or actual mechanical issue first.
post #8 of 15 (permalink) Old 06-08-2015, 07:12 AM
The pressure is 5 - 18 psi at an idle. 30 - 50 psi at highway speeds.
Gbonewit is offline
post #9 of 15 (permalink) Old 06-08-2015, 07:13 AM
The fuel pressure is 5-18 at an idle and 25 to 50 at highway speeds
Gbonewit is offline
post #10 of 15 (permalink) Old 06-08-2015, 07:21 AM
on a 2007 thats too low sir, on the newer DT's post 04, if they go below 50 or so PSI it will set that light on(dont quote me on number). So if you have already changed the regulator at bottom of housing and filter, might want to try a transfer pump. Its mounted on the side of the High Pressure Oil Pump.
post #11 of 15 (permalink) Old 06-09-2015, 10:58 AM
Thanks orjnlfarmertom. I have the pump and new rubber seals for the steel lines coming in next week. Thanks for you help
Gbonewit is offline
post #12 of 15 (permalink) Old 06-09-2015, 02:18 PM
I have been having EGR Cooler issues on the newer International Buses. DT466 engines. They are getting replaced under warranty but I am concerned about when the warranty runs out. Is there something I can do to prevent this problem? Type of antifreeze? Type of oil?
Gbonewit is offline
post #13 of 15 (permalink) Old 06-09-2015, 03:17 PM
any engine with a EGR cooler... should be refilled using vacuum method.. meaning you draw a vacuum on cooling system, then use that vacuum to suck in all the coolant the system needs. There is a special tool you can buy through the Dealership if you prefer, but i just bought mine from local SNap-on dealer, cost like 150 bucks (yea i know)
But some EGR cooler manufacturers are kicking back warranty claims because nobody is filling coolant system correctly.
On a EGR engine, there cant be a single air bubble in system ever... the EGR cooler gets so hot so fast, if it meets one of those air bubbles.. it will create a hot spot, and could either damage integrity of EGR cooler or melt some of the solders holding it all together...
ANd i worked at a dealership for a long time.. a lot really just dont care to fill cooling system properly.. if you fill it properly your EGR cooler life should double or more no joke.
post #14 of 15 (permalink) Old 06-11-2015, 07:29 AM
What type of antifreeze do you recommend? And is there a recommended oil that should be used? How many miles on a service? Sorry for all the questions. I have recently taken over a shop at a school and I'm trying to get up to speed on theses busses.
Gbonewit is offline
post #15 of 15 (permalink) Old 06-16-2015, 12:49 PM
2007 DT466 with a code 344, and 354. The turbo sounds like an airplane after the engine is shut down. Sounds noisy to me.
Gbonewit is offline
  Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
