international t444 - I need help interpreting diagnostic codes - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 06-21-2009, 08:44 AM Thread Starter
I just started to examine a temperamental 2000 international 4700 t444. (175 hp)
The check engine light is not on, but the truck has been running poorly so I decided to pull the flash codes. I am new to internationals so I have a few questions. 1. Does it look like the codes I pulled may just be old stored codes? 2. If so, how do I clear them 3. If not, but do you make of the codes I have pulled.
I dealership faxed me the "Electronic Control System Diagnostic Form EGED-185" which is what I have been using to interpret the flashes. Here is what I got
111 - NO errors detected
222 - Brake switch circuit fault
113 - Electrical system voltage out of range (low)
626 - Unexpected reset fault - ecm memory lost power
231 - ATA data Communications link error
525 - Injector driver circuit faulty -ECM can not supply sufficient voltage to injectors - Engine harness, injector harness, or ECM problem
I suspect that some of these codes are old and were never cleared. I know the truck recently had the alternator go which would explain 113, 626, and maybe some of the other codes. What do you guys think. Also, if anyone knows where I can find an engine or complete shop manual for this truck I would be interested in viewing/buying one.
eastcoast86 is offline
post #2 of 5 (permalink) Old 06-23-2009, 01:22 PM Thread Starter
I'm still looking for some help. Is there another place on this forum or another forum that you would recommend I post this?
post #3 of 5 (permalink) Old 08-14-2009, 10:03 AM
Hey eastcoast I have sorta the same issue. I got a couple of the same flash codes you have. Did you figure out how to clear them?
Newbie- 83 toyota rock krawler on 38 tsl's caged 20r,D44 open/14bolt detroit locker 5.13's.
95 chebi 1/2t 350 5spd mostly stock
82 celica gt bone stock old school carb engine.
rock krawler is offline
post #4 of 5 (permalink) Old 08-14-2009, 01:27 PM
Load test
Have your batteries load tested and check the alternator output, Check the battery cables and make sure you are grounded to the engine as well as the chasis...
Also check your glowplug controls and be sure your relay is not stuck.
Sounds like a low voltage problem to me.
FK000@aol.com is offline
post #5 of 5 (permalink) Old 08-14-2009, 09:51 PM
I know how to clear the codes on the newer internationals but wasn't so sure on the older body styles so I put "clearing t444e codes" in google and found a site that suggested putting the key to the run position, holding the diagnostic button under the dash and pumping the throttle three times slowly to clear codes. Try and clear codes and drive the truck and see if any of them come back.
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. Type 31 batteries. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. Heim joint clutch linkage. Adrenaline HPOP. BDP modded IDM. LUK SMFW. DIY Elec Fuel. FS1282, FF5320 fuel filters. SD starter. DP 80hp tuned PCM.
'04 F550XL reg. cab. ZF-6 speed. EGR delete. Coolant filter. Cat EC-1 coolant. LF777 bypass oil filter. Blue-spring fuel pressure regulator. ScanGauge II. Glowshift fuel pressure gauge.
'06 F350 xlt crew cab. 5R110 auto trans. 4x4. EGR Delete. DIY Coolant filter. Cat EC-1 coolant. Blue spring fuel pressure regulator. Open CCV. SCT X4 Gearhead Tunes. Dual SPA fuel/oil pressure gaugeWicked Wheel 2.
sdan27 is offline
  Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
