International Truck with DT466E engine - Diesel Forum - TheDieselStop.com
post #1 of 24 (permalink) Old 02-01-2007, 11:43 PM Thread Starter
I just picked up a 02 international box truck with the 195 or 210hp engine in it(have to check on which one). Is there and chips or tuners out there for these trucks. Main reason would be to remove the limiter penske had installed on it when it was theres. 65mph can get you killed on the interstate in alabama. Not looking for much on power just 25-35hp and 50-75lb tq mainly move the limiter to 75mph
latemodelracer2 is offline
post #2 of 24 (permalink) Old 02-02-2007, 12:31 AM
Re: International Truck with DT466E engine
75 can get you killed too. more than 15 over the speed limit ticket can do in your CDL as well. I'm quite content with the 65 limiter
and generally use the cruise control to keep it below that.
Rvannatta
rvannatta is offline
post #3 of 24 (permalink) Old 02-02-2007, 05:56 AM
alabama probably has a 75 speed limit ( does it).
1993 Ford IDI 7.3L
F-250
ZF-5 speed 4 wheel drive
Class 5 hitch
D load tires <img src="/ubbthreads/images/graemlins/frown.gif" alt="" />
super cab
18x,xxx miles.
Purchased 9-22-06
luckys420 is offline
post #4 of 24 (permalink) Old 02-02-2007, 07:23 AM
Depending on the gears a 4900 with 195 or the 210 can do 75 easily. If you have access to the Navistar program and the laptop hook up it's pretty easy to set the limit at any speed you wish. You can also go to the dealer and he will set it for you along with other parameters including desired idle speed and even more power. FWIW, we have 12 of these trucks and our own tuner program and we have set all trucks at 65 max speed. We have a few retards driving for us and if we set the limit at 75 they will drive 75. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
BTW on that same subject you can also bring in your F-250/350/450 and the Ford dealer can set your limit lower if safety and maintenance concerns you. One of my clients in south Florida has all his F-250's set at 75 and all the 450's set at 65 because they all tow equipment trailers. Generally towing equipment trailers at 85 mph is not safe and rakes havoc on the brakes and tires.
If I had a 4900 in real good shape and drove it ONLY long hauls I might set it slightly higher. Keep in mind that gearing plays in here, some are geared for hills and 65 or so is about red-line on the engine.
RE
Too much junk/toys to mention, ever changing due to too getting bored too quickly. I need a 10 step program!
Want to call? I'm in the book. Want to argue....First explain the square root of negative one....lol
roofeditor is offline
post #5 of 24 (permalink) Old 02-02-2007, 08:26 AM
No, the limit in Alabama is 70.
1998 Dodge 12v 5 spd 2wd dually, 275k on truck, bhaf, CPP 7x10 injectors, timing at 19 deg, 3k gsk, no fuel plate, htb2 64-13 turbo with stainless exh housing, wastegate set at 50 psi, southbend dual disk clutch, detroit locker, has broken 2 stock dana 80 limited slip units, has run 14.65 at 98 granny shifting the 5 spd, dynoed at 450 hp and 906 ft/lbs on REALLY STINGY dyno
v8440 is offline
post #6 of 24 (permalink) Old 02-02-2007, 08:29 PM
you know these trucks arent race cars, you should seriously reconsider adjusting anything, most people dont mind having to pass a truck on the interstate. i get pissed more when i have to pass a truck doing 75 than one doing 60
ASE Certified: Medium and Heavy Truck Diesel
Federally certified air brake technician
1990 F-250 7.3 IDI N/A 4x4 ZF5 Dana 60 front, LUK Clutch SMF, 215k
1991 Ford B700 6.6l School bus, Straight pipe
1987 Ford F350 Dump 4x4 c6, 38k miles, 8 foot meyers plow
2002 VW Golf TDI
1989 Festiva (my favorite)
1989 Saab 9000 Turbo
2002 Saturn SL1 (Daily Driver)
1950 Dodge Coronet
1996 F150 2wd 4.9 5 spd, 136k
90734x4 is offline
post #7 of 24 (permalink) Old 02-03-2007, 04:05 PM
The problem with the limiter at 65 is that if you have to pass someone doing 62 you can't get around them safely. Set it at 75 and you can cruise at 65 and still pass safely.
I used to drive for Schneider National, they had the trucks limited to 63 mpg, and the cruise control limited to 61 mph. Those trucks were so poorly maintained that even that was probably unsafe
1997 Ford F350 SRW 7.3L PSD
1985 Ford Ranger 2.3L 5 speed
1966 Mustang 200 I6, auto, 4 wheel disk, power brake retrofit, Corvette master.
Former vehicles, 1994 E350 7.3L IDI, 1985 International 1654 rollback, 6.9L IDI, (2) 1994 Ford E350 7.3L IDI, 1985 Ford F350 DRW 6.9L IDI, 1985 Ford F350 wrecker 6.9L IDI.
*dual ASE Master Certified, Automotive, Medium & Heavy trucks*
Owner / operator, Patriot Automotive, N Ridgeville OH
Mr_Roboto is offline
post #8 of 24 (permalink) Old 02-04-2007, 12:29 PM
fourhatz's Avatar
If the road speed max is all you want to change that is a very simple change with a pro-link or lap top. If you pulled into a dealership alot of times we do not charge customers to change it. Only takes a couple of minutes to change. I would call your local IH dealer.
96' F-250 4x4 SB Crewcab, 3.55 gears, rebuilt E4od, Air bags, 2" leveler kit, 10 disc cd changer, Tymar intake, Tymar 4 pos TS chip, 4590 cooler, boost, pyro(pre-turbo) & tranny temp AutoMeter gauges mounted in pillar, Diamond eye 4" exhaust with lost kitty, Tymar 3x4" downpipe, Warn hubs, Prodigy brake controller, Hypermax intercooler, CCV mod,17* HPOP, stage 1 injectors, fpr. Rebuilt tranny with pump and valve body mods, 3 disc torque convertor. Diesel mechanic 20+ years
fourhatz is offline
post #9 of 24 (permalink) Old 02-06-2007, 11:53 PM Thread Starter
like some have said I would like the higher limiter and more power for passing. I still plain to cruise around 68-70 which is the legal limit. SO the dealer is my best bet for having this done? What should i ask for when needing power just say i need more or tell them the increase i am looking for
post #10 of 24 (permalink) Old 02-07-2007, 07:50 PM
fourhatz's Avatar
Just tell them that you need the road speed raised up to 75 or 80, where ever you want it. This will allow you to go that speed only if the you have the power to go that fast. To get more power aftermarket would be the way to go as it is very expensive to have the dealer reprogram for more power. These engines are very prone to scoring cylinders so be carefull with the power upgrades.
fourhatz is offline
post #11 of 24 (permalink) Old 06-29-2010, 06:33 PM
i am a tech at an international dealer and yeah like they said the road speed is easy to change but the hp....may as well forget it the dealer has to get the ok from international and then have to send the engine file to tech services to get it changed and loaded back onto the truck....can be very expensive. your better off just leaving it the way it is. because we usually see that at 250,000 they are ready for an overhaul anyway so any other configuration other than stock is just asking for trouble.
jbthomp is offline
post #12 of 24 (permalink) Old 06-29-2010, 08:20 PM
lone_star_dsl's Avatar
I had an International 9200 that was a Walmart day cab in it's previous life. The road governor was set at 72 mph. Since the truck had a Detroit in it, I took it to the Detroit shop and had them remove the governor (I was the only driver) and I enjoyed every gain in MPH.
It's really nice to be able to keep up with traffic.
2016 RAM 3500 Big Horn, CC LB, DRW, 6.7 CTD, 4wd, Aisin trans
Gone but not forgotten...
2002 F-350 SRW
Lariat, Crew Cab, Long Bed
4X4, Auto Trans, Tymar Intake
Wicked Wheel, Zoodad Mod
DP Tuner - 60E, 80E, 40T, 80T, Decel
05+ Harley Headlights
6" Upper and Lower Windshield Brows
ISSPRO Gauges, Edge Insight CTS
Sold at 206,000 miles
lone_star_dsl is offline
post #13 of 24 (permalink) Old 06-30-2010, 05:59 PM
nevrenufhp's Avatar
This thread is kinda old to be digging up.
The 466E can be hopped up like a powerstroke can, but with a couple differences. In a nutshell, injecotrs, turbo, and possibly ECM work can get one to 300+hp. You should really be the only driver, because that much difference in power can really break stuff.
commuter: 08 VW R32, or 67 F100,300,offy intake,edel carb,274* cam,header
Work truck:'94 IH 4900, DTA466 lightly bombed(#0 fuel plate, timing at 22*, 3 clicks tighter gov springs), Allison MT653, Voith retarder, and straight piped
nevrenufhp is offline
post #14 of 24 (permalink) Old 09-15-2010, 11:46 AM
i have bought several of the internationals and had the speed sensor and cruise sensor set to 74, any international dealer and plug them in and set it up, can't do anything with the hp or torque.
dnl94 is offline
post #15 of 24 (permalink) Old 06-10-2011, 09:42 PM
Exclamation dt 466e
anyone know if a dt466e out of a 1997 school bus will fit in a 2003 rollback? thanks for your help
kenj1982 is offline
  Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
