John Deere 5520 Injector pump electric bypass - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 03-19-2006, 01:29 AM Thread Starter
I have a John Deere 5520 ag tractor with a Stanadyne fuel pump. The tractor does not deliver fuel pressure from the pump when cranking over. After i tested some wiring i found the electric fuel shut off is not working or wired properly. On top of the fuel pump there is a plate with two threaded studs coming out. When i crank over the engine and ground a screwdriver to the ground stud and the metal on the injector pump the tractor runs fine. There is two red wires coming off of one stud and a single black wire connected to the other stud running to the temperature sensor and another sensor on the side of the injector pump to complete a curcuit back to the pump with no ground. Should there be a ground wire going off of this stud along with the one that is attached to it or is the switch staying open where the switch should close and ground itself when the engine is turning over? [img]/ubbthreads/images/graemlins/shrug.gif[/img] thanks for any help. I am thinking about running a ground wire off of the stud to the frame and just running the tractor like that.
timr is offline
post #2 of 2 (permalink) Old 03-19-2006, 07:49 AM
Re: John Deere 5520 Injector pump electric bypass
there should be a small strap on that stud that mounts it to the lid of the pump.it will be a very tiny aluminum strip that goes right under that stud to under the nut on the stud.you can just jump it over to a new ground with a new wire as long as it starts and stops you should be fine.
2000 f250 4x4 lariate woodland green metalic and gold on the bottom.sharp looking super cab.100,000 miles .air heater mod,CCV mod,zoodad,80 econo DP tuner PCM ,cranked doun stock waste gate,cubie hole type gauge pod,k@n replacement filter.sonax/tricumulator, map sensor pop off valve,boost tube,BTM ,code eliminators ,wiked wheel,EBPV deleat ,hp oil cross over feul presure shimed and gauge, Heater core hose bypass valve .Wet Okole seat covers with Powerstroke logo ,.home made donaldson intake in the works parts on order.mounting bracket and 45* silicone elbo.piss on this homemade thing it will never be as good as the AFE stage II.thats what i'll get next.i am curently running my stock air box
WUNDERHOOT is offline
  Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
Gear in this thread - Powered by O'Reilly Auto Parts
