marine 3208 cat question - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
Old 01-08-2008, 10:15 AM   #1 (permalink)
i have to pull the front cover off of a 3208 cat marine engine 375hp, to change coolant sleeves from the cover into the heads.This engine has the plastic sleeves one is leaking, anyone know if injection pump has to be removed to take the front cover off?
2008 F-350 ex-cab shortbed lariat 4x4 6.4 torqshift 3.73L.S.dark stone w-two tone pueblo gold trim 8ft Fisher minute mount II
1997 F-350 4x4 DRW XL PSD auto, fisher 9ft minute mount, knapheide util body, 8ft SS buyers sander
Chrisb444e is offline
Old 01-08-2008, 10:44 PM   #2 (permalink)
Dave Haven's Avatar
My Photos: (16)
Re: marine 3208 cat question
The injection pump is fastened to the block. No need to remove the pump to remove the front cover.
"Big Red"-'89 F-250 4X4 reg cab; 7.3; Cat ELC (no problems, ain't skeered ; 4.10 axles; 5-speed ZF "Bolt-Action"; ATS turbo installed @ 158K; Holley "Red" pump; new injectors and 2nd Reman IP@ 234.5K; "Coffee Can" (4") downpipe-back exhaust....
6220#
"Trick Truck"- 1970 F-350 w/custom utility bed and cabover camper; Cadillac leather seat; CAT 3208 w/turbo from CAT 613 scraper; 5" straight pipe; 6-speed Allison "slush box"; 3-speed "Brownie"; 2-speed Eaton rear axle from F-600; Custom rear deck w/ air compressor, Lincoln arc welder, Oxy-Acetylene rig, and boom crane....
17,940# 26' Class C motorhome
"White Pony"- 2007 Mustang; 4 liter V6; "5-shot bolt action" (an automatic in a Mustang is just WRONG!)
Dave Haven is offline
Old 01-09-2008, 09:26 AM   #3 (permalink)
Thanks Dave for the response, much appreciated
Old 01-10-2008, 10:56 PM   #4 (permalink)
But I believe you have to pull the pan because the oil pickup is attached to the front cover......it's been 10 years so look it up before acting, but IIRC that is the way it goes.
Diesel Mechanic 28 yrs
Garbage_Mechanic is offline
Old 05-12-2009, 06:46 PM   #5 (permalink)
How do I post a new thread?
jmark470 is offline
Old 05-13-2009, 09:09 AM   #6 (permalink)
nevrenufhp's Avatar
On the 'General Diesel' heading, where you see all of everyone's threads, there's a 'new post' or 'post new topic' button on the top left of the thread list.
commuter: 67 F100,300,offy intake,edel carb,274* cam,header
swapping in a Ford/New Holland 6.6(12 valve). Ford engine in a Ford! 6.6 vid: http://www.youtube.com/watch?v=zcflwjpRHUQ
Work truck:'94 IH 4900, DTA466 lightly bombed(#0 fuel plate, timing at 22*, 3 clicks tighter gov springs), Allison MT653, Voith retarder, and straight piped
nevrenufhp is offline
