Peterbilt options - Diesel Forum - TheDieselStop.com
post #1 of 21 (permalink) Old 11-28-2006, 09:02 PM Thread Starter
brahamfireman's Avatar
Peterbilt options
I have been looking at a few Pete's with corvette dashes like mine and all of them have a voltmeter and a big pyro, mine has a small pyro and no voltmeter, some even have less gauges, like 12, if thats still not enough... so I was just wondering if there was anywhere I could find out what the available gauge options were.
Diesel Rod
Formerly Diesel Rod.
A
with 295K miles, 90 LED's and 5" stacks, among other things....
A
Reg cab with 210K miles, Needs to go away. PM me.
SHORT HOOD. The ongoing "project" it aint pretty but its got a
425 air to air Cat motor
.....13 speed Eaton. Corvette Dash, 17 gauges, 8" black stacks, 63" flat top---> 36" sitting here waiting for paint. 1.305 Million Miles.
I don't know what I am doing, I just know I don't have time to do it.
brahamfireman is offline
post #2 of 21 (permalink) Old 11-29-2006, 10:15 AM
Re: Peterbilt options
Depends on the year but the most gauges you could fit in the 2001-2004 dash was 21 I believe. That was less that what the factory offered.
Going strictly off memory I guess the available gauges were:
Air application -required
speedo- required
tach- required
air supply pressure- required
engine coolant temp -required
engine oil pressure- required
fuel gauge- required
voltmeter-standard
Options :
-2" or 3" pyro
-dash mounted air filter restriction (2 different ones were available)
-trailer reservior air pressure gauge
-trailer air application gauges
-up to two additional air appication gauges for wreckers and such
-oil temp gauge
-manifold pressure gauge
-PTO hourmeter
-dash mounted clock
-axle oil temp single (reads forward axle) or two axle oil temp gauges or three for tridems
-oil temp gauge auxillary tranny
-oil temp gauge main tranny
-additional 2, 3, 4, fuel gauges. One per fuel tank
-air suspension gauge or one gauge for each axle
-air suspension gauge for trailer
-fuel filter restriction gauge
-ammeter
-air suspension pressure gauges for each pusher and/or tag axle
Plus a few NPO (non-published options) that add a few more available gauges.
Also, auxillary trannies, 2 speed axles, road trip computers, etc often take up the space for 4 gauges each.
I'm sure I missed one of two.
Early '99 7.3 Superduty. Built 3-98
Built motor. Homemade "Big Oil", GT42R Big frame turbo. Rods and junk to keep it all together.
Suns_PSD is offline
post #3 of 21 (permalink) Old 11-29-2006, 09:24 PM Thread Starter
well thank you for the reply, that is quite the list....
more specificaly the old pete's, 80's like mine, an '87 with the corvette dash. mine is the only one with the small pyro, that I have seen anyway.
also are any of the older gauges still avaiable the only one I think I dont have is the voltmeter, which I would like.
Diesel Rod
A
A
post #4 of 21 (permalink) Old 11-29-2006, 11:07 PM
Diesel Rod
My 2000 379 had 2 fuel(one for each tank),2 air psi,1 applied air,volt,amp meter,4 oil(engine,tranny,both rears,pyro,fuel psi,boost,water temp,speedo,tach and a clock. Also had about 15 switches. Hard to find room for a stick on girly calender! [img]/ubbthreads/images/graemlins/smokin.gif[/img]
2003 X Limited 4WD 6.0,auto,55k mi. I'd buy another if FORD still made them.
1993 F150 4WD,5.8,auto,33s,315k mi.Never been stuck.YET!
New ride 1995 FRTLNR FLD120 Reman DD12.7 470hp,13spd,3.08 rears.Yeah I know,all the DD bashing I've done and I go and buy one.With the reman in it for $14,750 my mechanic said if I didn't buyit he would.
4 SALE 1993 FRTLNR coe N14 460hp,13spd,single axle,all aluminum wheels.
claytonr is offline
post #5 of 21 (permalink) Old 11-30-2006, 08:16 AM
My Photos: (9)
You can also get one more if you combine the two air reservoir gauges into one with two needles.
Birken
Birken Vogt is offline
post #6 of 21 (permalink) Old 11-30-2006, 10:18 AM
well thank you for the reply, that is quite the list.... <font color="blue">No problem! I sold Petes from mid 1999 to about mid 2003. I sell KWs now. </font>
more specificaly the old pete's, 80's like mine, an '87 with the corvette dash. mine is the only one with the small pyro, that I have seen anyway. <font color="blue">Sorry. I just assumed you meant the curved dashes that came out in mid 2000 when you said Corvette dash. I was in Jr. High in the 80s so I don't know much about the options that were available then! </font>
also are any of the older gauges still avaiable the only one I think I dont have is the voltmeter, which I would like. <font color="blue"> Buying them has never been a problem in the past. They typically run around $150 for just a gauge. You can also go aftermarket and then you will get mounting hardware, wiring, etc... </font>
Diesel Rod
<font color="blue">Good luck w/ the project! The new trucks are quickly becoming idiot proof which is important as the # of good knowledgable drivers has failed to keep pace w/ America's need for freight. For 2007, pyros will no longer be an option at all since the computer will prevent the driver from creating more heat than the motor can take. I complained recently to a driver about not being able to get a pyro any more and he said "I never could figure out what that gauge does anyway." lol </font>
Suns_PSD is offline
post #7 of 21 (permalink) Old 11-30-2006, 01:31 PM
My Photos: (9)
Yes as a matter of fact, I have no use for a pyro either as I am dead set against hot rodding any revenue motor.
Birken
post #8 of 21 (permalink) Old 11-30-2006, 02:08 PM
I sure wouldnt personally want one without a pyro myself, it would be like not having a water temp guage to me. I think a pyro is a necessity, whether the manufacture'ers think so or not.
2011 F250 Lariat CCSB 4x4....
catdiesel0631 is offline
post #9 of 21 (permalink) Old 11-30-2006, 03:57 PM
My Photos: (9)
Does the service truck in your picture have a pyro?
Birken
post #10 of 21 (permalink) Old 11-30-2006, 06:01 PM
If I had to guess I'd say not factory. However I bet he doesn't own it and if it broke he'd get paid to fix it, win\win in my book. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
The last truck I owned that I felt actually needed a pyro was a KW with a 3406B. All the electronic engines since then never get above 1000deg even on the hardest pull and the new one barely gets over 600. (I know these are post turbo but the B was the only one I felt could be killed easily with your foot)
Jfaulkner is offline
post #11 of 21 (permalink) Old 11-30-2006, 07:06 PM Thread Starter
mine does have a pyro, unfortunetly it doesnt work, so I will prolly get an aftermarket one, which will also be put in PRE turbo since the factory one in post.
17 factory gauges. 18 if you count the dual needle air pressure as 2. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Thanks guys.
Diesel Rod
A
A
post #12 of 21 (permalink) Old 12-01-2006, 09:00 AM
Birken
Yes right next to the transmission temp guage where the factory provides two holes for 2.5 ( its a auto )--dealer installed it to!! [img]/ubbthreads/images/graemlins/smile.gif[/img]
post #13 of 21 (permalink) Old 12-01-2006, 11:06 PM
Birken
[/ QUOTE ]Yep but is it CAT power under the Hood,If not Shame,Shame,Shame. [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img] Our CAT dealership runs 330 pete service tks C-7 power.
07,F-250 4X4 6.0 Torqshift, Lariat, Highline package, S/C LWB.
grounder is offline
post #14 of 21 (permalink) Old 12-02-2006, 04:11 PM
Birken
No more Cats in Paccar's Pete 335 or KW T300 for 2007.
The new motors are called the PX-6 &amp; the PX-8. ISB and ISC respectively.
Suns_PSD is offline
post #15 of 21 (permalink) Old 12-02-2006, 06:00 PM
Birken
Thats interesting,
And no unfortunately I have a outstanding duramax under the hood, I do industrial engine work and have no need for a "big" truck. If its anything to big we hire a crane to come to the rescue. As my crane is only rated 5K lbs. Which there are only a few of us with the smaller trucks(we travel ALOT all over the country mainly the neighboring states for me) the rest of the trucks in our fleet are bigger ones(for machine field service).
Anything bigger though is a FORD F-650/750's with C-7's
CAT INC. gives us guidelines on what vehicles we are and are not allowed to purchase and fortunately ford f-550 and under is off the list permanent. WAY to many problems for us downtime wise. Matter of fact all of our F-550/450's with 6leakers have been traded off for C-5500 duramax---there holding up GREAT--engine wise/tranny wise(we use autos as well).
  Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
