General DieselDiscussion about diesels in general. All brands are welcome, please refrain from brand wars. Discussions about types of diesel fuel also go here.
OK so far I have not been checked/diped/whatever you want to call it. People who have tell me they make the owner remove fuel cap then pull sample (about 1/2 cup) from each tank and squirt it into a container then check rear tank (is truck so equiped) then do same thing.
Is this right? Do they (take) the fuel and keep it? Seems kinda strange to me. I get asked dang near every time I fill up by truckers who often say they have been checked many times. One neighbor was checked and he has a GAS ENGINE. The person checking couldn't tell by sound (running) or by sight (Says V10 on side) or even the dang tag (Unleaded gasonline only) (something like that) and of course didn't believe driver. So do they take folks who fail the "do you want fries with that?" crowd or the TSA rejects?
Pretty sure the only time we got checked they pulled the fuel into a clear tube then squirted it back in. A giant syringe of sorts. I doubt many places would keep it unless it was red. It would get to be a pain to handle all the left over even at 2.50 a gallon.
Proud Recipient Of The \\\ 01 F-350 CC/LB 4x4 BTS Auto XLT Toreador Red W/Gray Lower Accent
10" Lift 38 PJs, EDGE Trac Bar Relocate, ORU X over, Weld Outbacks, AFE Stage 2,Hypermax 5", Hypermax Mod BJ Code Injectors, Hypermax H2E (broke, replaced with something bigger), Hypermax Rev Kit, ITP Fuel Sys, Aeromotive fuel pump, forged rods, main studs, head studs, billet intakes, WOP fire rings, BTS Trans & HPOS,
I got checked about a month ago. It was at a weigh station and I have farm plates. They guy just stuck a small tube in the tank and put his thumb on the end pulled it out just enough to see the color and took his thumb off and put a rag on the tube to wipe it off on the way out. Kurt
For anyone so inclined, it is possible to remove the powerstroke emblem and replace with a V10 Emblem on a diesel vehicle and drive it with red fuel................for a little while. But I tell you, don't mess with my powerstroke emblem or I'd be a mad hombre
Wolf
Kentucky built 2004 Silver F-250 XL Reg Cab PSD, 4X2, bench cloth seat,air conditioning, 6 spd Manual, 3.73 LS,Line-X , FORD receiver, Prodigy brake controller,towing option,( put together on Monday, March 29, del April 9 2004) 62000 miles
Once again ill bring up a myth. Anyone heard of pills that take the color out. I'm sure theirs some chemical that could do it but im no scientist.
2002 F-250 S/C Auto, 4X4, longbed, Dual Turboback Exhaust from Brighton Radiator, TS 6 position chip(Stock-Fuel7) Tymar Intake.Acetoned emblems. Boost pyro tranny C2 autometer guages with pillar mount(Follow the light)40000Miles
2004.5 Polaris 600 Sportsman. DONT FALL IN THE TRAP DEMOCRATS ARE FULL OF CRAP some call me redneck, some call me trash, some call me a true American that'll kick your... God bless the U.S.
Yeah, I think the noise/exhaust-smell is going to be noticed by the guys doing the checking long before they go looking for some badge stuck to your fender! You'd have to swap out the stickers inside the fuel door too, and then tell them you bought gas at Exxon the last fillup so it's just knocking. (Of course it might just be simpler to pay the tax, since you're, you know, using the vehicle on the road and legally owe it...)
Duncan
The 1997 F250HD Crewcab: Picture
The 2000 XLT Excursion <font color="red">(SOLD)</font>: Picture
The 2003 F250 Crewcab 6.0L: Web page
The 6.0L Bible: Web page
The 6.4L Bible: Web page
Sorry didn't mean to start the debate over red fuel/legality/etc. Just wondering about them pulling fuel sample/declaring it good and keeping fuel.
Now when they add the EXTRA $.75 a gallon they wanted to add to all road fuel on....... I think I might consider it.
"Yeah, I think the noise/exhaust-smell is going to be noticed by the guys doing the checking long before they go looking for some badge stuck to your fender!"
Their state workers, their to stupid for that.
I've been checked in my KW in several states, most of the time they use a syringe sort of thing and then just put it back in.
On big trucks if you get caught you pay for the capacity of the truck, NOT what is in the tank, mine holds 300 gallons [img]/ubbthreads/images/graemlins/shocked.gif[/img]
Usually the fine is per gallon, was $2 in NC I was told by Mr. Fuel checker [img]/ubbthreads/images/graemlins/eek.gif[/img]
2002 F-350 SC SRW long bed 4X4 7.3 PSD Auto, Island blue,
38 Chev sedan delivery all steel, 350, TH400,A-C PW PS PDB, Yellow,
2000 Kenworth W900 600Hp Cat 18 spd 3:70 green
Geeze, for only 2 bucks a gallon I'd take the gamble. [img]/ubbthreads/images/graemlins/vulnerable.gif[/img] In NV it's a state fine plus federal which can go to 10k. [img]/ubbthreads/images/graemlins/eek.gif[/img]
The fuel color only gives them probable cause to check the sulfur content. If they go to court it's required they have some sort of chemical analyses to make the case..
If heat creates boost and not velocity why not put a blow torch on the exhaust manifold?
96 F250 Hypermax H2 for now, WOP long block going in. Spearco from BWD, Terminator oil w/DP tuner, Fass, Bronco tank, 4" DP, safe to say motor is not stock. Thanks to Zane at WOP. :-)
99 F250 Lariat SCSB 7.3
98 Peterbilt 379 Cat 3406E 964ci 600hp+Pittsburgh Power and Stage III Michigan OR6051 turbo/boost blanket, Nathan P5 Amtrack Horn, 800 XCR Snowmobile Turbo triple, Avenger III instruments. The usual old mans toys. USAF Veteran
They are not checking for " sulphur content " They are checking for " road tax content "
Wolf
The inherent vice of capitalism is the unequal sharing of blessings; the inherent virtue of socialism is the equal sharing of miseries. -Sir Winston Churchill
Early 99 Blue/silver ext. cab 4X4 TS Perfomance flip-chipped PSD with Autometer pyro, and straightpiped duals w/stainless tips. All Audiobahn system with two 10" subs custom installed under backseat.
1992 F-250 xlt supercab 4x4 Longbed auto N/A IDI 7.3 Diesel; Straightpiped and loud.
Mercedes-Benz E-320 CDI DIESEL brilliant silver mettalic/charcoal
Mercedes-Benz; the world's first patented motor car
"was $2 in NC I was told by Mr. Fuel checker" Since running red fuel is a form of tax fraud your stiffing the feds. I would imagine thats who would come down on you, possibly the state would handle it for them?? And if i remember right, they will have a pretty hefty flat rate to go along with it.
[/ QUOTE ] "
he is right, unless your running train diesel.
Oh I see, the prosecuting attorney will tell the court the defendant had "no road tax content" in the motor fuel tank.. [img]/ubbthreads/images/graemlins/biggrin.gif[/img] At that point: CASE DISMISSED
