replacing a gasoline engine with a diesel engine - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 06-24-2005, 02:24 PM Thread Starter
Anybody know if it is possible to replace a gasoline engine with a diesel engine? Or where can I get info on that?
Uli66 is offline
post #2 of 7 (permalink) Old 06-24-2005, 02:52 PM
Re: replacing a gasoline engine with a diesel engine
Is it possible to remove a gasoline engine from a vehicle and install a diesel engine? Of course!
Is it practical, easy, or economical? Sometimes. Generally, if a vehicle was offered with a diesel engine, it's easier to just buy a diesel version than it is to convert a gasser. In those cases where a diesel was never offered (in this country), then you have to do a swap. These vary from pretty easy to really hard.
What are you thinking about re-powering?
Current vehicles
'83 Mercedes 300D Turbo-Diesel-the U 505 315,000 miles
A couple gas burners.
Shaffer is offline
post #3 of 7 (permalink) Old 06-25-2005, 04:26 AM
Something simple and easy to overlook. The brakes on a diesel are hydroboost. One more thing you have to change.
BigDaddyT is offline
post #4 of 7 (permalink) Old 06-25-2005, 12:39 PM
ta152h0's Avatar
In my own humble opinion, it would be easier to swap a gasoline engine truck with a dieasel engined truck.....the whole thing............and swapping bodies
Wolf
Kentucky built 2004 Silver F-250 XL Reg Cab PSD, 4X2, bench cloth seat,air conditioning, 6 spd Manual, 3.73 LS,Line-X , FORD receiver, Prodigy brake controller,towing option,( put together on Monday, March 29, del April 9 2004) 62000 miles
ta152h0 is offline
post #5 of 7 (permalink) Old 06-25-2005, 03:51 PM
there was a guy here that did about 1000 diesel to gas conversions from retired oil trucks. No IM. The Im got wise and now want to hear the truck run.
post #6 of 7 (permalink) Old 06-25-2005, 07:34 PM
Not always. Some systems use a vacuum pump. It probably wouldn't be too hard to set up a vacuum pump to work with a system that was meant for engine vacuum.
Something else to consider-the emissions legality of doing a diesel swap. If you live in an area that has emissions testing, you may have some trouble at the inspection station.
Current vehicles
Shaffer is offline
post #7 of 7 (permalink) Old 06-26-2005, 10:20 AM
Don't know about you strokers on here, but those of us with the older 7.3 and 6.9 IDI's have vacuum pumps and vacuum brake boosters.
I'm getting a 6.9 ready to go into my '85 Bronco. I have an entire donor truck, so it shouldn't be too difficult to make the swap. About the only parts I can't get off the donor are some heavier duty coil springs for the front. But I found a spring shop that will custom build me some for the diesel weight plus a 4" lift for under $500...
Sorry to all the loyal 7.3 guys, but I traded my '91 7.3 in on a 2002 F250 Ex cab V10 4x4. SCT Xcalibrator2 with tunes by Powerplay Performance. 285/75/16 Toyo M/T's. Took a long time to get used to the ping-pop of a cooling catalytic converter...LOL.
'85 Bronco swapped up to a 302 4bbl from the 300 I6, NP435 4spd, NP208, 32x11.50x15 Radial RVT's, Soon to be 6.9 turbo powered.
86 F350 Cab&Chassis with a dump bed. 2wd 6.9 and 4 spd tranny. No mods to engine.
2000 Volvo 660 N14 Cummins, 500hp 1650 ft lbs, Autoshift tranny 10spd.
What part of "SHALL NOT INFRINGE" do you NOT understand?
aceohearts is offline
  Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
