General DieselDiscussion about diesels in general. All brands are welcome, please refrain from brand wars. Discussions about types of diesel fuel also go here.
I would wait until your 500 miles from a change. I have never put it in the oil, but have used it in fuel and directly into intakes.
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
I have heard the guys that add to oil do it about 100 miles before they change it. I have used it by draining the fuel filter and filling it with seafoam, I haven't poured it into the intake. I am going to do it in the filter just before our trip next month and 1 can in each fuel tank..The stuff works good
1994 F-350 7.3 IDI Turbo, crew cab, E4OD, LB, Dually Photos
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
What exactly does it do if you put it in the gas tank?
94 F250 IDI turbo e40d with 353k on her.
Hypermax exhaust,cowl induction hood and AFE air filter added
It's suppose to clean your injectors and tank when put in the fuel.
I've just about finished my first full tank with it, but I'm still smoking quite a bit.
Putting it in engine oil is suppose to remove the carbon around the rings.
Wait! It makes your truck smoke until its gone or your truck was already smoking?
I will say that the seafoam is way to go!!! I emptied my fuel filter and then filled it with seafoam, restarted the truck and ran it for a few minutes. Each time I goosed the throttle it would have the foulest smelling puff of smoke I ever smelled. After I ran it for about 1/2 hr. I had to make a trip to the kids house 1/2 hr. away on freeway and I noticed about 100 degree drop in EGT's. a week later I pulled the trailer and It sure seemed like it had more power. I plan on doing another treatment before our trip in July and I will pour 1 can in each tank as we take off. BTW I also use Power service "diesel Kleen" in every tank.
Yea I agree it is good stuff. I do everything that has a engine every year. The neighbors must always think that I have blown up an engine when ever I do it.
With the stroke I put it in a sprayer bottle and mist it into the engine, not flooding it out, but allowing it make its way through.
my fireind yoda forum uses that in the oil those yodas crud up worse than diesels and this stuff cleans them out
and i havnt added seafoam to the tank but i run lucas in each tank each fillup and its great
i dont think seafoam is a fuel additive just a engine cleaner i think its not supposed to be run every tank
88 F-250 body,550 rear frame setup, 7.3 idi, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, brush guard with front mount hitch and off road lights, headache rack, 33" mudders, ac power converter,factory buckets from quadcab, power windows and locks now, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
i plan to add propane kit, stake body bed, gn hitch,western style mirrors, holset turbo 100mm intake, and a lot more
new motto: use common sense its a great gift
and if that dont work overkill it
