General DieselDiscussion about diesels in general. All brands are welcome, please refrain from brand wars. Discussions about types of diesel fuel also go here.
Hey guys, I was wondering if you could help me out with a question.
I just bought a yard truck to move trailers around at our trucking company. It is a 1994 Freightliner with a 60 series detroit, but it is a 11.1 Liter. All I am familiar with is the 12.7 liter.
What is the difference between the two?
Can you take a crank and rods from a 12.7 and put in a 11.1 and everything be cosher since the are supposed to be the same blocks?
Any info on the differences and simularities will be greatly appreciated.
A good example is if I take the engine out of this truck and put a 12.7 crank and rods, since the bore is the same and have a short block sitting in case a motor goes down in one of my trucks, will I be able to take everything else off the other motor and put it on this one and be in good shape?
Series 50 is only a 4 cylinder, basically a 12.7 Series 60 cut to 4 cylinders. The 14.0L, IIRC, is only available with DDEC V.
As for changing a 11.1 to a 12.7, I believe it can be done, but not sure exactly what parts would have to be changed out to make it all work. I would think at least the cylinder kits, and possibly crankshaft and camshaft.
Buddy
Former Ford Diesel Tech
ASE Certified Parts Counterperson, Automotive, Medium, & Heavy Truck Technician
1999 F250 XLT 4x4, Red, 7.3 6spd AWA5, 3.73LS rear, CCV Mod, APC Headlamps, Autometer C2 Gauges, (Boost,Pyro,Trans), 4" Turbo-back exhaust, XM Radio, AIS, ITP Regulated return, fuel feed lines, Airdog, & 4pos. chip. My Truck
2001 Ford Escort ZX2 - Black- 4cyl 2.0DOHC, 5spd.
1999 F350 4x4 XLT, CC/LB PSD, 6spd, Aluminum service bed, York Compressor Onboard air, CCV, Custom Intake & Exhaust, Strobes and a few other goodies
RIP Steph F. & Trista J., 4/27/07, you will be missed by many.
does the truck run good? if it's only gonna be used to move trailers around, why would you want to go throught the expense and hassle of swapping engines?? what is the HP rating of the 11.1L?
__________________ 2001 F-250 PSD Crew Cab short bed, 4x4 Lariet, only 97k miles bone stock for now
previous trucks: 2001 F-250 PSD CC SWB 4" lift, 315's, DP Tuner.. late '99 F-350 PSD CC LWB 4" lift, 315's, DP...... early '99 F-250 PSD SC SWB short shifted 6-speed, 5" stacks, 5.5" lift, 4.30 gears, DP Tuner, etc.... 1997 F-350 PSD 4x4, 4" lift, 35's, Superchips tuner
Since it is an older engine obviously since they don't make the 11.1L anymore there are a few differences between the 2. Just a few major ones in fact. Crankshaft,rods,pulse-wheel gear,turbo,oil cooler,cylinder kits,injectors,camshaft, to name a few. As for the comment on the block, basically the same, just different size liners/piston dome. So if you really wanted to just change the parts over from 1 BLOCK to the other one. Don't forget the programs in the computer are different also. Yes, the swap would be ok except that the transmission might not hold up to the torque, and radiator might not cool as needed.
95 F250,XLT, 4WD, Auto Trans,bbshimmed,synthetic trans oil,4:10 gears ,Truck Trunk ,Nerf Bars ,crome Mud flaps, Aux. trans cooler, front diff. drain plug. External trans.filter, trimmed snorkel. American wheels water temp guage, front fuel tank mod,Warn Manual hubs,Putman class 4 hitch 189k mi.
It is said if you sit by the river and watch the water flow by long enough, your enemies will pass by. This I believe to be true. It is also possible to watch your loved ones pass by as well.
Wife Candi 08/14/07 missing her always
I stand to be corrected on 2 points, 1- they might have the same piston assenblies,2- the large gear in frount of the engine we call the 'bull gear' is different. FWIW, there are 7 major differences in the 11.1 to the 12.7.
I thought possibly using it as a yard dog for a while and rebuilding it as a 12.7 to put in another truck if one went down.
I thin this one is 325 or 350, I looked but I cant remember. One of the two
Most Series 11.1 engine had the 320 hp in the computer, there were 350 programs and a few had a 365 hp program. Do NOT use the rocker cover for hp info, the ecm has the program inside and this where you have to look. DO NOT believe the sales man if he points this to you. What is inside is what counts not what is stated on the outside.
Have 92 volvo with 12.7 series 60 with 785000 miles.stopped running when stopengine lite came on.Could not get to start after new coolant sensor,new oilsensor checked all wiring,everything looked ok.Then thougt I would put in
new crankshaft sensor,couldn't get it out. Took cover above sensor off to try
to pry between gear and sensor,found gear real loose,and had bent sensor
so it couldn't come out.Took front cover off bearing in gear is real loose.Is
this a tapered bearing,that can be tightened by big nut. thanks 24U
That is the bull gear. Money is on that you don't have a torque wrench to tighten the nut. Shop has the tool but not the wrench. I'm thinking over 1K in torque. You need to go to a someone who has the gear assembly. Do that. Also get the sensors,front seal, oil pan gasket, special gasket eliminator,ect. Also make sure that the covers are in good shape on the R side. Now is the time to replace anything bad. Money it will cost but the truck makes you money when it's running. Usually the shops quote around 16 hrs labor. Volvo's run a little more due to the radiator package ect. neded for removal. Did you bend any valves?
I Got A 60 Series Detroit And Have A Overheating Issue. The Codes Are Saying Fuel Temp Sensoe And Coolant Temp Sensor. I Just Got The Heads, Rods, Liners All Done And Now This. The Temp Gauge Stays On 150 And Then Suddenly Goes To 230-240 For A Split Second And Then Back Down To 150. The Truck Is Old 1998 Freightliner Cc But There Is No Leaks. Any Feedback Will Be Greatly Appreciated
