Smoking dt 466 engine - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
Old 10-20-2009, 05:12 PM   #1 (permalink)
I have a 1981 dt 466 that is making black smoke. I know it is excessive fuel related from information provided by the service manual. I have checked the excessive fuel system and it pushes back with oil pressure. It is not the air filter as it is new and there is a air filter restriction guage on the truck and it works. The problem came on suddenly and I hae read all the service manual info and don't know what to check for next. Can anyone help?
mrcraneman is offline
Old 10-21-2009, 04:46 AM   #2 (permalink)
My Photos: (33)
Inspect the turbocharger and pluming, also check the air charge cooler (intercooler) for cracks in the header tanks. (Follow the oily mess)
95" Extd Cab F250HD 4x4 DRW, /86"6.9 T19 GV o/d 3.73 axles, Hypermax Pulse turbo, intercooled / Modified Hypermax ram air induction, PowerShot 2000 LPG system "first design". Ride rites @ all 4 corners, Dana 50 mono Beam up front, Ford 10.5" in rear with 4 wheel disk brakes. Other Truck, 1983 IHC "S" with 14ton NoMar wrecker body, 30,000 GVW, 229"wb with a 340hp Detroit 6V92TA, Eaton 13spd RTO9513, 3.70 ring & pinion and LPG kit. Alcoa 22.5x8.25 with Michelin XVE 255x70x22.5
Huff is offline
