Source for fuel buttons for Cummins 855 - Diesel Forum - TheDieselStop.com
post #1 of 15 (permalink) Old 03-15-2006, 11:17 PM Thread Starter
Texascadillac42's Avatar
My Photos: (10)
Does any one have a good source for fuel buttons so i can upgrade the pump in a big cam Cummins 855? Thanks.
99 F350 XLT 4x4, Crew Cab, 19.5s, Cummins 12V powered, with a few mods, SBC DD clutch
Texascadillac42 is offline
post #2 of 15 (permalink) Old 03-16-2006, 11:36 AM
Re: Source for fuel buttons for Cummins 855
Go to Cummins Engine Co. web page and check for a Cummins DISTRIBUTOR
( ie Cummins Mid South - Cummins Central Power ETC.) The dealers such as Kenworth, International, ETC won't carry the fuel buttons but the Distributors will probably have them. Let me know the number of the button you need and I may be able to get you one here locally at Cummins Central Power in Wichita,Ks.
96 F250 psd cc/4x4 3.55s shimmed/dead kitty K & N, intercepter & CCC,boost,pyro,trans temp gauges,hypermax downpipe,4" exhaust,sonnax & tricumulator kit,diablo chip,joeservo idm,intercooler
lightning31 is offline
post #3 of 15 (permalink) Old 03-16-2006, 11:41 AM
FSUPERDUTY's Avatar
Northern IL Cummins in Hodgkins will probably have what you need.
2010 F250 Lariet cc/sb V-10 auto 4.10ls,8.6 Western poly MVP Plus
FSUPERDUTY is offline
post #4 of 15 (permalink) Old 03-16-2006, 12:16 PM
Are the 855's easily upgradeable to higher HP levels or do they require turbo changes, piston upgrades, etc.?
IBUILD is offline
post #5 of 15 (permalink) Old 03-16-2006, 01:48 PM
GENERALLY
The the Cummins engines with the PT fuel systems could be modified with fuel Buttons and or throttle plungers. Basically these just dumped in more fuel and or raised fuel pressure to the injectors.
You could also change injector cups or complete injectors. If you wanted to spend lots of money you could upgrade turbos and or change pistons and exhaust manifolds. There were all kinds of tweaks that could be done in the " pump room" at the distributorships where the techs rebuilt the pumps and injectors!!!
post #6 of 15 (permalink) Old 03-16-2006, 07:58 PM
lww
In a nutshell, any of these types of simple fuel system modifications require a modicum of operator sensitivity in as far as how you choose to use the extra power, the addition or usage of an EGT gauge is the best insurance to avoid damage.
I have a bag of 20 or so left over buttons ranging from around 70 down to "zero" from that yesteryear of power plants, pretty simple to install too. Your idle adjustment cover is removed, and the adjuster screw seat internal snap ring comes out. The seat and spring jump out to expose the button - about a 5 minute job to put the new one in.
Enjoy [img]/ubbthreads/images/graemlins/smirk.gif[/img]
1990 F250 with 325oookm - ATS (non wasteGated kit ) on since 0km's / ZF / Single Cab Conversion to 6 seater keeps the family involved / Getting on, but running strong
lww is offline
post #7 of 15 (permalink) Old 03-16-2006, 10:51 PM Thread Starter
My Photos: (10)
Can anyone tell me how the fuel button numbering system works with these PT pumps? Thanks.
post #8 of 15 (permalink) Old 03-16-2006, 11:32 PM
CowKiller's Avatar
My Photos: (12)
smaller number, smaller hole
PLAY TRUCK
1986 F250 6.9,ATS turbo, np435, BW1356, hp 60,welded up sterling 10.25.
converted from 2wd to 4x4
sittin on 36x12.5 goodyears
GETTING CONVERTED TO SHORTBED AS WE SPEAK!
TOW RIG
2002 gmc 2500hd 6.6 duramax 5 speed allison
4x4 extened cab.
2000 F550 Lube Truck (Work Truck)
Certified PA Inspection Mechanic
i'd rather be 6.9'n than cummin or strokin'!
CowKiller is offline
post #9 of 15 (permalink) Old 03-17-2006, 10:09 AM Thread Starter
My Photos: (10)
I thought I read somewhere that the smaller the hole is (lower the number), the more power it makes, is this correct or no?
post #10 of 15 (permalink) Old 03-17-2006, 11:48 AM
CowKiller's Avatar
My Photos: (12)
replacing the button will not give it more power, just more fuel pressure. find somone who knows the pump well, they will know what to do. if i put in a smaller button, you also need to do other adjustments inside the pump. i just learned this pump in class, tore it apart. it is an eazy pump to dissasemble. but getting it off the enging can be a pain due to the back bolt. just donttouch the two bolts at the throttle linkage. u will most likly screw up your throttle leakage and the truck wont idle.
PLAY TRUCK
TOW RIG
4x4 extened cab.
post #11 of 15 (permalink) Old 03-17-2006, 01:31 PM
My Photos: (27)
That's not true at all, we've replaced many a scored sleeve due to a guy just putting in too "hot" of button, that's all it takes with the old PT system. We used to put them in, then Cummins or the trucking company mechanics would find out, remove them, next trip through, they'd stop at out independent truck shop, we'd stick another one back in.
One guy had such a hot one in he'd go through a set of driver tires in no time if he wasn't careful. But there again he treated his engine right and never let anyone else drive his tractor unless he replaced the button.
LMJD is offline
post #12 of 15 (permalink) Old 03-19-2006, 09:23 PM
lww
Like I said, "simple power" gain procedure. PT refers to pressure/ time. The smaller number depicts a smaller effective area the fuel pressure within the pump can work against, pushing against the button to relieve pressure much like a relief valve. Hence the smaller numbers hold on longer allowing the pump outlet pressure to climb higher before shifting over to curb the increase. Some guys would pinch off a return line to implement a crude sort of increase too. These potentially damaging procedures definately increase power to the ground, however some operators seemed to use the power carefully enough not to burn out their top ends and had a pretty good running unit. (strictly speaking from experience, going back a few years mind you.)
lww is offline
post #13 of 15 (permalink) Old 03-20-2006, 11:32 PM
Yes you can make a fire breathing monster, but if you don't put an exhaust temp. guage on it (pyrometer) you can melt the manifold right off of it. when thhe exhaust manifold is red hot you have over achieved.
Rvannatta
rvannatta is offline
post #14 of 15 (permalink) Old 09-27-2008, 12:38 PM
Anyone have pics of where this button is on the pump?
dieseldude5.9 is offline
post #15 of 15 (permalink) Old 09-28-2008, 05:29 PM
Hello! The proper name for a button is the idle plunger. The idle plunger seals the end of the governor and by changing the size of the recess in the idle plunger it controls the rail pressure. Adding shims to the high speed spring will also increase the rail pressure because the pressure is increased between the two plungers.
You should be able to get fuel pump parts from Cummins or any ADS pump shop.
After building pumps for 20 years I've seen a lot of home made hop up parts for the PT system. Like removing the idle adjusting screw and threading in anything for a stinger. Or the snap ring ears broken off from ssomeone trying to use two nails to remove it!
The mount bolts a re no problem if you have the right wrench!
See you later
Mike in Yak
Mike in Yak
444xt is offline
  Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
