Starting problem - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
Old 11-17-2008, 08:42 AM   #1 (permalink)
Starting problem
I have a 86 ford 350 diesel box van, the rear fuel tank went bad so I took it out and disconnected the fuel lines to the rear tank from the switch (where the lines split front and back). The tank got fixed so we put it back in and now it doesn't run....any Ideas??
KMA Krawler is offline
Old 11-17-2008, 11:46 AM   #2 (permalink)
luckuslucas's Avatar
Did you make sure you purged the air from the lines before trying to use that tank again?
'01 Dodge Ram 2500, Cummins HO, 4x4, 6 speed, homemade WVO system
'96 International/Bluebird school bus, DT466, homemade WVO system, www.thebiggreenbus.org
'04 Jetta TDI, Greasecar WVO conversion (chases the bus around the country)
'89 MCI 102A3, Detroit 8V92TA, Frybrid/Rover Hybrids custom system
luckuslucas is offline
Old 11-17-2008, 12:57 PM   #3 (permalink)
MarkEkberg's Avatar
My Photos: (13)
The pump should be able to pull the fuel through there.
If it was undone for a while I might suspect mud wasps or the sort.
Could simply be that you didn't get the line coupled back right. They go together like a female dog.
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
MarkEkberg is offline
