storing diesel car for extended periods - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 03-28-2006, 04:11 PM Thread Starter
my diesel benz doesnt get the run it needs to keep a fresh tank of fuel......i m worried that longer term storage of diesel fuel will cause problems with time.. any suggestions for additives that will extend storage of diesel ? thanks !!!!
'13 144 sprinter cargo van
'12 mercedes s350 bluetec, yes it s a diesel ! !
'12 gmc sierra slt cc, lb, duramax, carbon blk outside, blk leather.
'08 mb sl550, my little red its not a corvette
'77 450SL benz , sold 6/13, but still in jersey ! !
'91 350sdl turbo diesel benz
'90 560sel benz.
'89 560sl benz, only 57000 miles !
hapaschold is offline
post #2 of 9 (permalink) Old 03-28-2006, 07:07 PM
Re: storing diesel car for extended periods
double dose it with a marine algiside like biobor.and crank it up once a month or so and let it runn a little.and keep the tank filled to the top.you might want to drive it around the block if you can ever so often also to keep the brakes from freezing up and the tires from flat spoting to bad.those are very tough engines though.i fired one up in a old wagon that must of been siting for 5 years all i did was blead the feul system and it fired rite up it smokes like hell for a while but it cleared up.its still running around here somewere.
2000 f250 4x4 lariate woodland green metalic and gold on the bottom.sharp looking super cab.100,000 miles .air heater mod,CCV mod,zoodad,80 econo DP tuner PCM ,cranked doun stock waste gate,cubie hole type gauge pod,k@n replacement filter.sonax/tricumulator, map sensor pop off valve,boost tube,BTM ,code eliminators ,wiked wheel,EBPV deleat ,hp oil cross over feul presure shimed and gauge, Heater core hose bypass valve .Wet Okole seat covers with Powerstroke logo ,.home made donaldson intake in the works parts on order.mounting bracket and 45* silicone elbo.piss on this homemade thing it will never be as good as the AFE stage II.thats what i'll get next.i am curently running my stock air box
WUNDERHOOT is offline
post #3 of 9 (permalink) Old 03-29-2006, 05:35 AM Thread Starter
i hoping to get the car out at least every couple weeks for a little excerise, but tank of fuel probally will last a year at that rate.
thanks for the idea.
'90 560sel benz.
post #4 of 9 (permalink) Old 03-29-2006, 06:36 PM
olddieseldude's Avatar
My Photos: (16)
Keeping the tank full is generally suggested to combat condensation (tank collecting moisture) due to temperature changes. If your diesel is stored in a climate controlled building that should not be a problem and would allow you to store it with only small amounts of fuel. You could then start it up and add a small amount of fresh fuel at intervals.
RickN
(mods listed in comments under photo in above link)
olddieseldude is offline
post #5 of 9 (permalink) Old 03-29-2006, 09:12 PM Thread Starter
she ll be stored in attached garage on house.....50 degrees at worst winter day..... i ll roll back and forth a bit for the tires.
'90 560sel benz.
post #6 of 9 (permalink) Old 03-29-2006, 10:05 PM
you will be fine they build the finest cars end engines on earth.the top of the line the very first even.it's German!i know a guy with a field of these things in south carolina with grass growing over them and you can go out and just start them up.it is amazing.
post #7 of 9 (permalink) Old 03-30-2006, 06:07 AM Thread Starter
i found this car in penn late last year , was 2 owner car , only 73k on the clock. seems to be accurate. had some body work but nicely done. had a benz car specialist check her out and gave it two thumbs up. the ride is great on the sdl series.
'90 560sel benz.
post #8 of 9 (permalink) Old 03-30-2006, 09:00 AM
Nice to know there are other guys on here who drive diesel Mercs! You can use StaBil for the sitting tank - works great.
For me, I drive the Benz more than my Ford - better mpgs.
2005 Ford F350 6.0/TorqShift
1994 Mercedes E300D
FMBDiesel is offline
post #9 of 9 (permalink) Old 03-30-2006, 08:56 PM Thread Starter
i see lots of older 300d s for commuters on the parkway.....even a few 300/350 sdl s. nice riding car and gets almost 30 mpg....
i like the long body ride... my wife likes her e300 diesel.
'90 560sel benz.
  Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
