thermoking c201 isuzu diesel genset - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 12-15-2007, 08:02 AM Thread Starter
Hi! This is my first post on your great forum. I have read many old posts about using this engine in a genset. I need information on what generator and/or adapter plate was used to direct couple the generator to the back of the diesel. Any information would greatly appreciated.
Thanks Allan
acmech is offline
post #2 of 8 (permalink) Old 12-15-2007, 10:17 PM
Re: thermoking c201 isuzu diesel genset
The C201 should make a great genset engine. I probably rebuilt close to 50 of those engines back when I used to work on Thermo Kings. I always liked the C201's better than the later DI engines. I remember seeing many C201's going over 30,000 hours before overhauls. If I remember right (15 yrs.) the bellhousing was about the size of a SAE #5, and the flywheels had 5 or 6 steel drive pins which were pressed in. The compressor coupler had hard rubber insert bushings which were driven by the flywheel pins, and was about a 1" tapered keyed shaft drive.
bigk7223 is offline
post #3 of 8 (permalink) Old 04-07-2008, 11:24 PM
Thanks Allan
An old thread Allan but I am interested in the results of your project. I am in the same project. I will be using a Magnatron gen end which comes with the necessary bell and flywheel adaptors.
Oldntired is offline
post #4 of 8 (permalink) Old 04-09-2008, 03:45 PM
----same here---please expound--as i know where three of these are setting
94_turbo is offline
post #5 of 8 (permalink) Old 04-09-2008, 03:46 PM
i believe the ones i posted above are 201's--how to best identify?? thanks
94_turbo is offline
post #6 of 8 (permalink) Old 04-10-2008, 02:21 AM
Well it seems that I have run into a problem, not sure which way it will go. The bell housing on the 201 is fine. It is a standard SAE #6 with the two bottom holes not drilled, that is easy to cure. The measurements are fine. But the flywheel is special for the mounting of the compressor. It uses pressed in pins in the flywheel that drive a flex plate with grommets in it. There are also tapped holes but they are not in a diameter of a standard SAE flywheel. They are somewhat over 10 inches in diameter, eight holes tapped 5/16. Larger than a #7 1/2 but smaller than a #8. I may have to come up with a flywheel from a vehicle unit, maybe the Luv truck, not sure. Tech at Magnatron has the information been waiting for two days for their answer.
I am installing a 21 kw gen end. I don't want to be limited by the generator and if needed the 201 can be turned up some, maybe a turbo and a bit bigger injectors. I don't think that my use will be too much for the 201 as it is, but don't want to be limited by the generator. I will be using a 4 pole dedicated 120/240 single phase. My use is a shop trailer with the heaviest comsumpsion from a Airco 300 amp heliarc welder. It runs fine on a 50 amp breaker. It will also charge Surrite batteries. The trailer will be totally self contained with solar panels and its own water supply, 700 gallons. The water system, plumbing, electrical wiring is all in now along with the equipment, but not the solar panels and inverter unit yet.
I currently run a Freightliner Condo with deep cycle batteries, inverter, generator and everything but the kitchen sink, so I have some current experience with the systems. See even an ice maker and freezer. The trailer is a 53/102 reefer unit and will have living quarters in it also, will be in it a lot.
I would be interested in info that anyone has on the flywheel situation or other factors involved. The governor seems great, it is set at 1800 now and is staying
in its original location. Trailer will look like a totally stock reefer.
post #7 of 8 (permalink) Old 04-10-2008, 02:25 AM
Yeah, forgot to add... This engine was an operational unit and has 13,000 hours on the meter. Runs like a new one.
post #8 of 8 (permalink) Old 08-02-2008, 11:29 AM
does anyone know what model and years of reefer the c201 was used in? also any ideas where i can get a manual for this engine? pigpen
pigpen60 is offline
  Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
