Toyota with 3.9 turbo cummins - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 04-03-2008, 01:37 AM Thread Starter
sloate's Avatar
I am thinking about finding a Toyota with a bad motor in it and droping in a 3.9 turbo cummins, i would want to run a 5 speed but dont know what would be best? Nv4500 is to big and a zf5 to, nv3500?? any ideas?? I would just want some 33in tires, just want a good daily driver, I will never buy any thing that runs on gas or that has a auto, any one have any ideas for me?? may be i gave you one!!
1995
F350, CrewCab, 7.3 PSD Dyno at 390 HP, zf5, 3 in Down pipe with 5in straight pipe with stack, Tymar, DDP stage 2 injectors, Intercooled, Stole it at $2500! 400000miles! Going for 1/2 million
1989
L8000 Dump Truck, 7.8L , 6 speed Fuller, 315000miles
1964
F350, 24v 5.9 Cummins, New Nv4500, Np205, JD green paint "Built Not Bought" 0 miles,
sloate is offline
post #2 of 10 (permalink) Old 04-03-2008, 10:17 AM
Hmm, let me preface by saying that this is just my $0.04 (inflation). I haven't even done an engine swap like you're talking about, but have researched and talked to people a fair amount.
If you want a good daily driver with good mileage and reliability, you can get a front cut of a 4 cylinder Toyota from Japan and swap it in fairly easily. A guy I know who did this with two Toyotas is really pleased with the performance and reliability. It wouldn't produce near the power of the cummins, but its a great daily driver. Stock instrument cluster and all that will work with it. Lots more info is available on the net.
I'm just thinking off the top of my head, it sounds like what you're trying to do may be a challenge with space, weight, and torque. Unless you get a 1/2 ton Toyota pickup, which they didn't really make until recently (and even that is debatable especially here on a Ford truck forum), you'll probably have to beef up the front end, do some fabbing to make that tall motor fit, get a decent transmission behind it, and not stress the frame with all the torque that little monster will produce. Especially if you want to tow more than a few thousand pounds.
I'd love to build either a Toyota with the Toyota diesel motor, or put a 4 cylinder cummins into an OBS F-150 with a NV-4500 behind it. Either way, the purpose would be to get great mileage and good power in a 4X4 daily driver. Real towing would be saved for my real truck.
1994 F-350 CC LB SRW 4x4 5 spd. manual. Homebuilt vegetable oil fuel system coming soon installed. 253k, 1k on vegoil.
Dads truck - 1997 F-350 CC LB SRW 4x4 5 spd. manual. Stock except for the vegistroke fuel system, over 90k on WVO. 230k on the truck.
TWeatherford is offline
post #3 of 10 (permalink) Old 04-05-2008, 11:43 AM Thread Starter
sloate's Avatar
I guess the the 4bt would be a little big.. I did drop a 460 in a ranger and it twisted the frame.. just was thinking that, but the other motor sounds like a good plan, what are they called? It would almost just bolt right in would it or would it not? Run the stock trans to?
1995
1989
1964
sloate is offline
post #4 of 10 (permalink) Old 04-06-2008, 11:52 AM
I think the Toyota diesel is a 2.2 liter turbo, called the 2.2LT or something like that. Yes, if the truck you're putting it in is a mid nineties 4 cylinder it bolts right in, and I'm pretty sure you can use the same transmission. Either way, the front cut comes with the transmission as well. You do have to switch from right hand drive to left, but I don't think its that big of a deal. The guy I know who did it has a 5 speed in both and loves them, certainly a one of a kind deal. There's lots of info on the net, I've been on here too long to do a search, gotta get out into this great day we have going on!
post #5 of 10 (permalink) Old 06-19-2008, 02:27 PM
Are any of you familiar with swapping the 3.0 L V6 with a diesel in the Yota's? A sweet setup would be a T100 with a small displacement diesel...a bit more capable than a Taco.
thechad is offline
post #6 of 10 (permalink) Old 06-19-2008, 10:22 PM
I forgot the name of the company but there is a company here in the U.S. that does these swaps. They use Toyota diesels which are available everywhere but the U.S. and they will do the swap or sell you the motor and/or parts for you to do it yourself. Do some searching on Google and you should find it.
Dave
1997 F250 HD 4x4 5speed Reg Cab, 4" MBRP exhaust, 1.0 turbo housing, Tymar Intake , 17* HPOP,Swamps 150cc, TW 4 position chip, Dana 60 w/RSK, Crossover steering, sittin on 35's
bosefes is offline
post #7 of 10 (permalink) Old 06-21-2008, 11:02 AM
NickBeek's Avatar
One of the diesel mags Diesel Power or Diesel Builder had an article on a 4BT swap into a full size Bronco. I have also seen a GMC 3500 dually long bed with a 4BT in it. Guy claims 30 MPG from it. If I were to do a Toyo with a diesel I believe I would use a Toyo engine and trans for ease of installation.
2006 2500 SLT Mineral Grey, 6 speed, 4x4, Thunder Road Package, MBRP Muffler + 6" dual Stacks, Fast Idle Enabled. Silencer Ring MIA, CFM+ intake horn, Smarty POD, SB Con OFe.
Traded:2004 F250CC FX4 XLT Long Bed Torque Shift, $5.00 AIC.
NickBeek is offline
post #8 of 10 (permalink) Old 06-22-2008, 04:06 AM
My Photos: (18)
Now that's one issue I would have loved to read.... the 4BT swaps.
1999 E-350 Cub Wagon, 7.3L Power Stroke, E4OD, 3.55
1990 E-350 Club Wagon, 7.3L IDI, E4OD, 3.54LS
x2
1994 Chevy C2500 6.5L TD, 3.42
1983 F-150 2x4, 4.9L, C-6 w/GV-OD, 3.55 Farm pickup
1981 C-8000, 3208 CAT, RT-6510, Rockwell SSHD Tandems (Swap)
1981 VW Rabbit Pickup 1.6L diesel (project)
1978 VW Rabbit 1.5L diesel (project)
1977 K100C, NTC-350, RT-1110, Tandem
1977 Transtar II, NTC-290, RT-9509 Single
1977 Transtar II, Formula 290, RT0-9513, Tandem (project)
1974 C-750, 391CID, Clark 5 speed, Eaton 2 speed
Kaliburz is offline
post #9 of 10 (permalink) Old 06-23-2008, 12:43 PM
I did a bit of research on the NV3500 about 12-13 yrs ago. Dodge used them in RAM 1500's....they were undersized for the 318 V-8's built at the time, They're only rated for about 200#/ft or torque. The little Cummins would tear them apart. They were made to compete with the T-5 B-W transmissions.
Denny
'96 F-250 Reg. Cab 4X4 5-sp POWERSTROKE
298,500 mi & NO Problems, LUK Clutch
Dr.Evil is offline
post #10 of 10 (permalink) Old 07-05-2008, 01:31 PM
One of the diesel mags Diesel Power or Diesel Builder had an article on a 4BT swap into a full size Bronco.....
Unless there was a second article the swap was into an Early Bronco (66-77) and I know of several people that have done it.
To clarify Broncos are broken down into 3 categories. There are Early Broncos (called EB for short) that were produced from 1966 to 1977, the Full Size Bronco (also known as FSB) was a two year run 78-79 and was the largest Bronco due to being built on the pickup chassis and finally there was the OJ Bronco (or OJB) which went back to a dedicated frame and ran from 1980 to 96 (with a couple of sheetmetal changes) when production ceased.
The BroncoII was NOT a Bronco as it was based on the Ranger mini truck.
Steve Urban
Semper Fi!
2007 F350, Lariat High Line, SRW, SC, LB, 4x4, 6.0/auto, FX4, Camper Pkg, HD alt, Red w/custom black two-tone, Buckstop bumpers F&R, Warn 16.5ti winch, Line-X, F550 coils, 305/70R18 ProComp XtremeMTs
2007 Apex9.5 truck camper
1973 Bronco (stock), wife's
1973 Bronco (HEAVILY modified), mine
2006 Mustang V6, Screaming Yellow, wife's
2006 F350, Amarillo, SRW, CC, 4x4, SB, 6.0/auto (traded)
2004 F350, SRW, CC, SB, Sport, 4x4, 6.0/auto (bought back by Ford)
SteveIn29 is offline
  Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
