Go Back   Diesel Forum - The Diesel Stop.com > Other Topics > General Diesel
Old 03-08-2007, 01:37 PM   #31 (permalink)
Re: ULSD Fuel
I was,nt trying too preach on my soap box, just made a observation a while back getting fuel. I run power service in it, and it sounds a whole lot better. Besides working full time here at the body shop I doe all the maintance at the farm where I keep my horse. We have a New Holland tractor, I put some powerservice in it over the weekend and noticed it was a lot quieter when I dragged the arena. So i,m sure we just have to keep up with putting it in our trucks which is still a lot cheeper than injectors, pumps thoughs kind of things. this just my thought on the subject. Dan
03 F-250 XLT oxford white\Arizona beige met. exc cab, 4x4 SCT Excal II, AFE stage II intake, CCV mod, Foil deleat mod, Reg fuel return system, Hutch mod, Harpooned, Boost fooler, 4" diamond eye turbo back exhaust, Chrome step bars, 06 American Spirit 2 horse trailer. Other go fast goodies that can't be mentioned
" Here kity kity "
skylinedan is offline
Old 03-08-2007, 07:43 PM   #32 (permalink)
olddieseldude's Avatar
My Photos: (16)
Re: ULSD Fuel
How much do you put in? I put it in per the instructions and it changes nothing. My main reason for putting it in is to take care of any condensation that might be created due to the wide temperature changes here. But I can't hear any difference with or without it.
olddieseldude is offline
Old 03-09-2007, 12:58 PM   #33 (permalink)
Re: ULSD Fuel
If you are concerned about lubricity of the new ULSD, check out the chart below. Basically, you can obtain all the lubricity needed with as low as 2% biodiesel. I run 5% biodiesel and the truck loves it!
biodiesel wearchart
1999 F-350 - CC/LB, gauges, 40K trans-cooler & external filtration & drain, 203 t-stat mod, Mag-Tech Trans & Diff. cover, AIS filtration, zoodad, HPO x-over, Jody Tipton 40HP tow PCM, Hutch mod and harpooned, Baldwin prepump fuel filter
"Better to be judged by 12, than carried by six!"
nlemerise is offline
Old 03-09-2007, 01:25 PM   #34 (permalink)
Re: ULSD Fuel
A 32oz bottal will treat 100 gal., so I just guess about a thid of a bottal when I fill up usally about 28gal. I did notice a change, not huge but a change noe the less.
" Here kity kity "
Old 03-09-2007, 05:11 PM   #35 (permalink)
Re: ULSD Fuel
I have noticed a considerable drop in fuel mileage since they switched to the ULSD around the first of the year. I have also had other fuel system issues such as the drain **** on my filter going bad and my inline fuel pump leaking on startup. When I mentioned these things to my local Ford Dealer he was able to pull up how many he has sold every year for the past several years, interestingly he said that in the past 6 months he has sold more of the drain ****s for the 99-03 fords then he had previously combined. There is little I can do about the ULSD now that it is here but equip my truck for it. I have heard that different type seals like those used for bio-diesel help and there are several additives as well. A personal favorite mixture of mine that I have used for the past 8 months with sucess is 20 Oz of Power Service mixed with 20oz of Marvel Mystery oil and 1 Quart of two stroke (injector quality). I usually mix these up ahead of time and have several containers in my truck at all times. I have notices a slight increase in mileage but more noticably because I started using this once I bought the truck, a drop when I dont use it. A old timer got me hooked on the two stroke, this is what he said when I told him about using ATF for lubrication. He asked me if I would run a two stroke engine on ATF, his point was that two stroke is MADE to lubricate fuel systems whereas ATF isnt. The two-stroke oil makes sense to me. Just be sure that it is safe for injection systems.
2000 F-350 Super Duty XLT, LB. TS 6 chip, 4" turbo back, oversize intake, 133K, 6 KC dylightrs
Draw17 is offline
Old 03-09-2007, 06:54 PM   #36 (permalink)
Re: ULSD Fuel
You proble could use 2 stroke oil the sled guys use, a lot of them are fuel injected these days. Stop some place that sells 4 wheelers and snowmobles ask the guys there, I know you can buy it in 1 gal. jugs. The milage thing is interresting though I have'nt heard anyone comment about any milage loss. AS far as atf goes I agree its not intended too be burned so why would you put in your tank? I have heard that some of the truckers have used it, but if someone dips there tank only to find red tinted fuel theres gona be some quetions asked. Dan
" Here kity kity "
Old 03-10-2007, 09:00 PM   #37 (permalink)
Re: ULSD Fuel
I think the Feds should pay to have all our trucks converted to the new 6.4L engine! [img]/ubbthreads/images/graemlins/grin.gif[/img]
And just who do you think these "Feds" might be????? [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
test pilot for Acme products
wileecoyote985 is offline
Old 03-19-2007, 05:33 PM   #38 (permalink)
Re: ULSD Fuel
I have 300 gallons of home heating oil in my house. We have changed to gas heat. Can I run the home heating oil in my 1999 7.3 Diesel?
Quazimotto is offline
Old 03-19-2007, 06:40 PM   #39 (permalink)
klhansen's Avatar
My Photos: (107)
Re: ULSD Fuel
Not legally, unless you pay the road tax on it up front. And I don't know how you would go about doing that. You're probably better off selling it to someone who still heats with oil.
99.5 F250 PSD Supercab LB 4x4, 6spd, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, Jody's 80 HP Econo PCM (classic version), AIS, coolant filter w/"hokum" bracket, regulated return, heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check here
klhansen is offline
Old 04-09-2007, 01:56 AM   #40 (permalink)
rms0726ea's Avatar
Re: ULSD Fuel
I've heard of using tranny fluid to lubricate and also help clean the motor. How much would be appropriate to use? Anyone know?
The use of automatic transmission fluid will not only raise the sulfur content of the diesel fuel significant but it also can cause the formation of injector deposits and fuel system deposits as the fuel is burned. These deposits can cause poor spray patterns, incomplete combustion of the fuel and increased emissions.
You will probably notice a slight decrease in fuel milage since the BTU level of ULSD fuel is lower than the LSD.
Schaeffer's Diesel Treat (http://www.schaefferoil.com/diesel_treat_2000.html) 1 gallon container treats 2000 gallons compared to power services' 3/4 gallon container which only treats 300 gallons.
www.totaldieselperformance.com, Tony Wildman 4 pos chip, 2003 7.3L F250 Lariat, Swamps 175/146 single shots, MBRP exhaust, AIS w/fender sleeve & Zoodad, ISSPRO A-pillar 3 gauge kit(pyro/boost/tran temp), DiPricol HPOP & Fuel, oilguard bypass filter, CCV mod, extreme duty tranny (by Jon Faubion-Richter69), BTS (PI) Torque Converter, AIH delete, 6.0 trans cooler, van turbo w/wicked wheel, Gutted EBPV, DI Intercooler, ITP Overboost Kit , HX mod, Bilstein Shocks, Firestone Ride-Rite air bags w/compressor, Dieselsite Coolant Filter, Schaeffer's 15W-40, ITP in tank mod/pre-pump filter, Harpoon mod
rms0726ea is offline
Old 04-10-2007, 03:27 AM   #41 (permalink)
szalkayw's Avatar
My Photos: (11)
Send a message via ICQ to szalkayw
Re: ULSD Fuel
I have only used HOWES LUBRICATOR Diesel treat which can be found in any NAPA store...at least up here in AK that is. I would imagine it would be the same in the lower 48
http://www.howeslube.com/site/
I cannot say if its better than anything else because its the only product i use.
2000 White/Tan F-350 7.3L Lariat 4x4 Crew Cab Long Bed * DOM 9/99 * Mobil Delvac 1 * OilGuard Bypass filter * MBRP 4" Turbo-back exhaust * Brakesmart Controller * Kenwood DVD player (DDX7019) w/ Kenwood GPS navigation (KNA-G510) and a Directed 12" overhead video/dvd player in rear * Pro Comp Ultra Lite Pyro, Boost and Trans gauges * Husky 16K FW hitch * Firestone air bags w/ dual air command setup * Tru-Cool 4739 MAX Trans Cooler
Trailer - 2006 Jayco 325BHS
szalkayw is offline
Old 04-22-2007, 10:04 PM   #42 (permalink)
FLATBED ED's Avatar
Re: ULSD Fuel
I use Seafoam fuel additive now instead of Power Service.. Seafoam works better. Better MPG and cold starts. Frees sticky injectors.
I now swear by it..... [img]/ubbthreads/images/graemlins/grin.gif[/img]
FLATBED ED,99 F-450(May she rest in peace)
2008 F-550 w/16-ft. Flatbed
FLATBED ED is offline
Old 04-25-2007, 04:56 PM   #43 (permalink)
Re: ULSD Fuel
dieselmech50s,
would you suggest that everytime I fill up my precious '03 7.3 that I add some lubricity additive to the fuel? I am all for it, if it is recommended.
Thanks in advance,
Rich
2003 F250 7.3 PSD Lariat, CC FX4 off-road, born on 07/02. Tymar air intake, 6pos chip with stock, hi-idle, 40,80,120, and no-start settings, Silverline TB 4" exhaust. BEAN'S DIESEL ROCKS! Purchased used with 51k miles. Daily driver and gets me to the track.
rjarvis is offline
Old 04-25-2007, 11:25 PM   #44 (permalink)
rms0726ea's Avatar
Re: ULSD Fuel
I do, personal preference, with Schaeffer's Diesel Treat it turns out to be about $1.25 a tank full [img]/ubbthreads/images/graemlins/cool.gif[/img]
Old 04-29-2007, 10:36 PM   #45 (permalink)
Re: ULSD Fuel
I ran this stuff and noticed that my 7.3 ran better quiter, and cranked faster!
https://www.amsoil.com/storefront/acb.aspx
Im thinking about running this stuff as well!
https://www.amsoil.com/storefront/adf.aspx
Amsoil has some good stuff!
TurboBack is offline
