General DieselDiscussion about diesels in general. All brands are welcome, please refrain from brand wars. Discussions about types of diesel fuel also go here.
Yep. For the last couple of years it has nickeled and dimed me quite a bit, but all the fixes were relatively simple and the old workhorse was back on the road again.
Not so this time.
Late this summer it started getting air in the fuel lines somewhere and then the starter mysteriously crapped out. I didn't have the time to fix the darn thing, so it sat for a month or two. Well, I replaced the starter today, expecting it atleast turn over (and whine about the air in the lines), but all I got was an unearthly sound emanating from the starter/ring gear/engine. I turned the ignition off, and the thing kept on trying to turn over with the switch off...but it wasn't turning over very well, it was making that screeching, grinding noise instead, again, with the ignition switch OFF. I fiddle with the keys and finally the thing stops. Not sure if I had anything to do with it shutting down or not, though.
Then the smoke starts billowing from the engine bay. No fire, but a bit of acrid smoke.
Perhaps the day has finally come. I wanted to get one more year out of the thing, too.
[img]/ubbthreads/images/graemlins/frown.gif[/img]
2003 F-350 SRW XLT 7.3L 4R100 PSD 4x4 Supercab SB 3.73
1985 Chevy K20 6.2L Turbo-400 3spd auto 4x4 4.10
2003 Ford Explorer XLT 4.0L V-6 5-spd auto 4wd 3.55
16' American Hauler tandem axle cargo trailer
NRA Life member
Re: Well, fellas, my '85 6.2L just might be DOA now
Now what? Stranded? Engine swap? Part it out?
commuter: 67 F100,300,offy intake,edel carb,274* cam,header
swapping in a Ford/New Holland 6.6(12 valve). Ford engine in a Ford! 6.6 vid: http://www.youtube.com/watch?v=zcflwjpRHUQ
Work truck:'94 IH 4900, DTA466 lightly bombed(#0 fuel plate, timing at 22*, 3 clicks tighter gov springs), Allison MT653, Voith retarder, and straight piped
I went out for a walk tonight to help wind down the day and clear my head some. One possibility I came up with was to swap out the 6.2L V-8 for a Cummins 5.9L I-6. The truck itself is still in very driveable condition, it's what's under the hood that is driving me crazy.
Not sure how to make the Cummins swap work in a Chevy, though. Maybe it's a pipe dream.
That's too bad. I really like this truck (I just put new exhaust and tires on it in the spring, too).
[img]/ubbthreads/images/graemlins/vomit.gif[/img]
NRA Life member
Sounds like an internal starter melt down. Were there any shims on the old starter when you took it out? Even if there were no shims on the old starter you may still need to shim the new one. The noises coming from the starter and ring gear were probably from the starter bendix gear engaging the ring gear without the proper clearance thus binding the bendix gear onto the flywheel and creating so much resistance that it overheated the starter causing it to stay engaged with the key in the off position.
Let us know what you find.
Good luck, Tim
06 3500 QC/LB/SRW/4.10/48RE/5.9/ Inferno red pearl
04 Hitchhiker 34.5 RLTG, Kubota B7610
if the engine is toast, drop in a SBC. the engine mounts are the same. we just had a teacher do it here at my school with an old 6.5. reoved and installed a 350
PLAY TRUCK
1986 F250 6.9,ATS turbo, np435, BW1356, hp 60,welded up sterling 10.25.
converted from 2wd to 4x4
sittin on 36x12.5 goodyears
GETTING CONVERTED TO SHORTBED AS WE SPEAK!
woblin,if you stick a cummins in it you'll be on a slow boat to china. 4.10 and no od,a cummins would be slow. my vote is to fix the starter/fuel leak,and keep on truckin.. my '02...
the fleet; ferds ,02'f350,01'f450.the generals ,82'2500, 82'2500 4x4, 82' blazer, 86' blazer ,93'3500, 96'3500, and a 99' 3500hd with 12 valve cummins power. the goats, 90'd250, 91'd350 4x4, 05'3500. all are diesel powered. a list of bigger stuff, as well as gasser's, got lucky, wife comes from a family that collects junk iron too!
A guy can swap in a cummins-seen several on e-bay, even saw one that was a 67 k-20, had it painted hemi orange. That thing was sweet. Dont know how well the tranny would fit but if it were me, i would try to swap it too.
2000 F-350 Super Cab,Long Box,4x4,7.3L PSD, Bully Dog Chip,6 sp. LEVER ACTION, Camper Pkg.,200k,Lariat, Clearance lights, White on top,Gold on bottom,Gold interior. 285/75/16 BFG's, Dieselsite.com 203* T-stat, alum. T-stat neck and coolant filter kit with Fleetguard WF2077 filter added.
1993 F-250 Reg. Cab 4x4. XLT. 7.3L IDI, E4OD, 4.10 rear, Fleetguard WF2077 coolant filter. Born: 9/92, 163k, Lumbar bench with armrest. White on top, blue in middle, white on bottom. Clearance lights,DeeZee diamond plate running boards to back of cab. True dual exhausts with glasspacks and 4" stainless tips. Pretty well stock except for Pioneer CD player.
