Go Back   Diesel Forum - The Diesel Stop.com > Other Topics > General Diesel
Old 07-01-2008, 08:44 PM   #1 (permalink)
What engine in a 1980 Ford C-8000 fire truck?
Just picked up a 1980 Ford C-8000 Fire truck from a local fire department... Does anyone know what motor these use? Its got an allison auto... Its a cabover style, very nice shape, only 20,000mi. I'm still figuring out how to tilt the cab so I can look things over..... Thanks
Thompsy is offline
Old 07-02-2008, 12:12 PM   #2 (permalink)
FarmallBobM's Avatar
My Photos: (9)
If it's a diesel most likely you have a Cat 3208 or 3208T. Seems to me the Detroit 8.2 "Fuel Pincher" was also offered for a year or two but I've never seen one.
A gasser would have a 391 (or larger) Ford V8.
Regarding the tilt cab we had a similar early 70's 10-wheel farm dump. That one had two large cab latch handles at the rear of the cab on the passenger side. To tilt you'd operate both handles together - one operates the main latch, the other a secondary "safety catch" - while giving an upward heave on the cab. The cab would then tilt forward with miminal effort. (There's a pair of big honking counterbalance springs beneath the cab that provide most of the lifting force.)
Suggestion: Remove everything loose inside the cab before you flip it!!
(Incidentally farm dump had the 391 gas V8. The rate at which it consumed fuel was absolutely terrifying!)
...FB
'99 F250 PSD - bone stock.
My other diesel ride: The "Collosus of Roads": '79 Kenworth K100, tandem axle, 27' dovetail flatbed, NTC290 Cummins, 15 speed Roadranger.
Old tractors: '53 Farmall Super M, '53 Farmall Super H, '47 Minneapolis-Moline UTU.
My stuff
FarmallBobM is offline
Old 07-02-2008, 12:17 PM   #3 (permalink)
If it's diesel, then the most likely one is a Cat 3208 or 1160.
commuter: 67 F100,300,offy intake,edel carb,header
Project truck: 99 SD F250 2WD, waiting for a DT466
Work truck:'94 IH 4900, DTA466 lightly bombed(#0 fuel plate, advanced timing,& tighter gov springs), Allison MT653, Voith retarder
nevrenufhp is online now
Old 07-02-2008, 11:21 PM   #4 (permalink)
Could be a 92 series 2 cycle also. Hate2 engines were to small hopefully for your sake. If it is a hate2, junk the engine and replace it with a clatterpillar.
95 F250,XLT, 4WD, Auto Trans,bbshimmed,synthetic trans oil,4:10 gears ,Truck Trunk ,Nerf Bars ,crome Mud flaps, Aux. trans cooler, front diff. drain plug. External trans.filter, trimmed snorkel. American wheels water temp guage, front fuel tank mod,Warn Manual hubs,Putman class 4 hitch 22 ft. Komfort 5th wheel/sold, 170k mi.
Death leaves a heart ache no one can heal, Love leaves a memory no one can steal. -robert ingersol-
Candi 08/14/07
Gone Fishen is offline
Old 07-03-2008, 01:12 PM   #5 (permalink)
Having driven an early '80's vintage F-700 single axle tractor with the 8.2 I have to laugh at Your comment......but agree 100%.....They were a worthless POS even when they were brand new. I'd hate to try to keep one running now after 25 yrs!
Denny
'96 F-250 Reg. Cab 4X4 5-sp POWERSTROKE
294,000 mi & NO Problems, LUK Clutch, and the Cat is buried in the back yard!
Dr.Evil is offline
Old 07-04-2008, 10:54 AM   #6 (permalink)
My Photos: (9)
Does it have an extended cab? If so tilting can be a challenge, as the springs are usually not strong enough. If it is a standard cab then it's pretty easy, there is a big over center handle that releases the main cab lock, then two smaller ones made out of rod to form handles that you pull to release safeties on the way up. Sometimes it takes a little bouncing and pulling different handles to get it to go up.
Birken
Birken Vogt is offline
Old 07-11-2008, 02:50 PM   #7 (permalink)
It may even be a 6V-53 Detroit
DetroitDiesel671 is offline
Old 07-13-2008, 09:41 PM   #8 (permalink)
Well, if you get the cab open, you'll be able to tell. IF it's a Cat, it will say 3208 and usually be painted yellow. The early 3208's were actually renamed to the Ford designation, 646 something... it is a 10.4L engine and I think 646 is the cubic inches.... And I think painted blue.
If you look under it, if it's the 3208, the starter will be on the passenger side (mine is) and it will have a dual oil filter up toward the driver front.
1999 E-350 Cub Wagon, 7.3L Power Stroke, E4OD, 3.55
1990 E-350 Club Wagon, 7.3L IDI, E4OD, 3.54LS
1983 F-150 2x4, 4.9L, C-6 w/GV-OD, 3.55 Farm pickup
1981 C-8000, 3208 CAT, RT-6510, Rockwell SSHD Tandems (Swap)
1977 K100C, NTC-350, RT-1110, Tandem
1977 Transtar II, NTC-290, RT-9509 Single
1977 Transtar II, Formula 290, RT0-9513, Tandem
1974 C-750, 391CID, Clark 5 speed, Eaton 2 speed
Kaliburz is online now
