What's the opinion on mixing kerosene with diesel? - Diesel Forum - TheDieselStop.com
post #1 of 23 (permalink) Old 11-19-2007, 10:29 AM Thread Starter
On our old 1978 Ford diesel tractor, my dad always used to mix kerosene with the diesel to make the tractor easier to start in winter.
He told me he put in 1 gallon of kerosene for every 5 gallons of diesel.
Is this a good idea or no?
- IDI Turbo, 5 speed, 4x4, manual hubs. ATS upgrade, 3" downpipe, 4" exhaust. Autometer pyrometer & boost gauges. More coming.
Lots of mods & pretty quick.
ghunt is offline
post #2 of 23 (permalink) Old 11-19-2007, 10:31 AM
Re: What's the opinion on mixing kerosene with diesel?
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: ghunt</div><div class="ubbcode-body">On our old 1978 Ford diesel tractor, my dad always used to mix kerosene with the diesel to make the tractor easier to start in winter.
Is this a good idea or no? </div></div>It's OK to do this. This is really all that #1 diesel is (but with more kerosene than a 1:5 ratio). Two down sides: less lubricity of fuel & you milage will go down a little.
'04.5 Dodge Ram, 600/325 5.9 Cummins, 4X4, NV5600, 3.73LS
'01 Excursion, 7.3 PSD, 4X4, 4R100, 3.73LS
'91 23' Bayliner Trophy, MerCruiser 5.0LX/AlphaOne GenII
Mark Hodowanec is offline
post #3 of 23 (permalink) Old 11-19-2007, 04:28 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Mark Hodowanec</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: ghunt</div><div class="ubbcode-body">On our old 1978 Ford diesel tractor, my dad always used to mix kerosene with the diesel to make the tractor easier to start in winter.
Is this a good idea or no? </div></div>It's OK to do this. This is really all that #1 diesel is (but with more kerosene than a 1:5 ratio). Two down sides: less lubricity of fuel & you milage will go down a little. </div></div>
What vehicle are you talking about? A tractor or your truck?
2009 F150 Lariat, Crew, 4x4
Previous - 2004 F350, Crew, 4x4, 6.0l
newtodieseling is offline
post #4 of 23 (permalink) Old 11-20-2007, 05:28 PM
The refineries in this area are adding 15% kerosene to Diesel right at this time. That gives a cloud point of about -18.
Later in the winter, they will increase the ratio to 20%. They also add a lubricity agent to compensate for the lack of kerosene's lubricity.
2003 KR F-250 4X4 CC SWB, 6.0, 5 Speed Auto, 3.73 Axle, no Limited slip. Rhino bedliner, Unicover bed cover.
Built on February 19, '03
#2 93 F-150 XLT, 5 Liter, Auto, 4X4, X Cab. 251,000 miles. Uses no oil between changes.
montanafan is offline
post #5 of 23 (permalink) Old 11-20-2007, 06:01 PM
dakotajeep's Avatar
It doesnt get cold in Montana...lol...
2003 F350 6.0 Lariat Crewcab 4x4 SRW 285/75 16's Treadwright Retread MTG's
Sold:
1994 F350 XL Crewcab 4x4 SRW 7.3 Banks Turbo
Dana 60 Sterling 10.25 3.55, ISSPRO EV Guage and Pyro
PICS of my rigs and random stuff:
dakotajeep is offline
post #6 of 23 (permalink) Old 11-28-2007, 12:02 AM
Is this a good idea or no? </div></div>We used to do this years ago when I was trucking. There were times when we would end up with too much summer fuel from a southern area when headed north into cold weather. It worked well but not sure I would do it with the newer technology engines.
2008 F-250 Lariat SRW 4x4 CC SWB...
KEM tuned Minimaxx
... S&B CAI / MBRP Cool Duals
Dark Stone Metallic / Pueblo gold
Readylift 3.5" levelling kit
... Toyo MT 315/70/18(bigger than 35-12.50-18)
--- BIG$HOW -------<տլ
Bigshow is offline
post #7 of 23 (permalink) Old 11-28-2007, 09:03 AM
drcampbell's Avatar
My Photos: (32)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: montanafan</div><div class="ubbcode-body">The refineries in this area are adding 15% kerosene to Diesel right at this time. That gives a cloud point of about -18.
Later in the winter, they will increase the ratio to 20%. They also add a lubricity agent to compensate for the lack of kerosene's lubricity. </div></div>
This deserves more emphasis:
If you're buying pump fuel, and you're not talking about a leftover tankful from another season or another region, the blending has already been done for you.
It's not necessary to do any more blending on your own.
Douglas Campbell, P.E.
1986 Isuzu P'up, 177,673.8 miles.
- Hella headlights (highly recommended)
- DOT C-2 back end (also recommended)
- R-12 air conditioner converted to R-406a. Saved ozone and money
- 4.1:1 final drive converted to 3.4:1. Quieter, better mileage but it's a good thing I live in the flat Midwest.
- 9/22/2007, age 21: Still running well when reluctantly sent away for reincarnation, due to body & frame rust.
- Never did get around to converting it to french-fry oil, which is why I originally stumbled upon this site.
drcampbell is offline
post #8 of 23 (permalink) Old 11-28-2007, 09:43 AM
Exactly, we are talking about mixing kerosene with #2 (or summer) Diesel. Winter fuel is already blended when you buy it. (Usually) It is possible to find #2 Diesel year around so one needs to know what he's dealing with. However, with proper lubrication added, straight kerosene would probably run great and be safe in the machine that he wants to use it in.
post #9 of 23 (permalink) Old 11-28-2007, 10:25 AM Thread Starter
Can a diesel truck run on straight kerosene?
Didn't know that...
Anyway I probably wouldn't bother mixing kerosene with diesel, considering that a gallon of kerosene is $3.20 here, and most of those diesel additives that treat 35 gallons or so are around $5.
ghunt is offline
post #10 of 23 (permalink) Old 11-28-2007, 12:49 PM
Kerosene is pretty similar to Diesel, but the Cetane number is different and there are no lubricating qualities in it. Without researching, I would say that there are other properties that are different. I wouldn't use it in any modern rig.
post #11 of 23 (permalink) Old 11-29-2007, 08:46 PM
It will run fine, and in fact can be used to clean injectors, I would run it heavier than 5-1 and maybe add some power service or a similar lubricating additive. Newer rigs will run even better than older units due to the lack of sulphur in the systems.
docsdiesel is offline
post #12 of 23 (permalink) Old 11-30-2007, 08:31 AM
I wouldn't run straight kerosene or even a high ratio of kerosene to diesel in any diesel engine. John Deere used to make two cylinder spark ignition tractors that started on gasoline but once warmed up, switched to kerosene. This shows us two things. That kerosene is sufficiently volatile enough to ignite with a spark plug and lacking enough in oiliness to foul out a spark engine. Which means it has properties somewhere between gasoline and diesel, making it an unsafe bet in a diesel motor. A diesel engine's fuel system relies on lubrication provided by the fuel and it has an extremely high compression ratio in order to ignite a compressed mixture of diesel and air, meaning that the engine was engineered to run on diesel or a similar fuel, not something akin to gasoline.
2001 Excursion PSD LTD 4x4
2003 VW Jetta TDI 5sp
2006 John Deere 3320
DieselFan is offline
post #13 of 23 (permalink) Old 11-30-2007, 08:41 AM
You are right in that I don't think I'd want to use straight kerosene, either, BUT kerosene is about as close to Diesel as you can get without being Diesel. It is "drier" than Diesel and definitely needs some added lubricity. The John Deere tractor of which you speak may have depended on the presence of heat in the cylinder to ignite the kerosene, and not entirely on the heat generated by compression.
post #14 of 23 (permalink) Old 12-07-2007, 04:18 PM Thread Starter
So I got another question of curiosity to add to this post.
Considering that kerosene is 40-50 cents per gallon cheaper than diesel, what if you did this-
Filled truck with kerosene (saving $15 on 35 gallons), added some two stroke oil, and added Diesel Kleen. You'd still end up saving almost $10 even after buying the additives.
On my old diesel, makes me wonder how it would run. Not sure if I'm brave enough to try it though. It is only $10 difference.
ghunt is offline
post #15 of 23 (permalink) Old 12-07-2007, 05:39 PM
AlH
</div></div>
Around here kerosene is MORE than diesel [img]/forums/images/%%GRAEMLIN_URL%%/shocked.gif[/img]
96 F350 CrewCab BTS-E4OD 4.10 4x4 / Banks Git-Kit / 99-Intercooler / 99 Tahoe 25TB ToyHauler / 00 FourWheelCamper Pop-up
2015 Transit T350HD 3.2D
AlH is offline
  Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
