what year cummins are the good ones and the bad ones - Page 2 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
Old 04-23-2007, 10:16 PM   #16 (permalink)
Kanman's Avatar
Re: what year cummins are the good ones and the bad ones
The 12V I am putting in a 97 F250 has "53" on the block, does it affect 12V's too? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Not all 53 blocks crack. If the block didn't crack in the first 20-50,000, then it probably (no promises)will not crack. If it came from a donor truck with some miles you should be ok.
My bone stock 99 24v cracked at 108K [img]/ubbthreads/images/graemlins/phoney.gif[/img] lucky me
If it was me, I would be looking at 12v all the way. Less sensors and other crapola to deal with. You can even do a 12v block with a 24v head, but I think its a PITA.
Also, 94-98's had dowel pin problems, its a fairly simple repair, but I believe ALL of them had to be repaired at one time or another.
Kanman is offline   Reply With Quote
Old 04-23-2007, 10:18 PM   #17 (permalink)
The pistons have to match the cylinder head. The bowls are in different locations.
'00 F350 CC SWB 4x4
13.35 @ 98.95mph
'07 Z06 Black/Black 2LZ
10.48 @ 136.86 w/1.65 60' on 17" drag radials...
faster67 is offline   Reply With Quote
Old 04-24-2007, 12:50 AM   #18 (permalink)
All of the engines from the "1st Gen" Dodge (1989+) to around 98 had the "Killer Dowel Pin" which is an easy fix. Yes, a 24v head will fit on a 12v block(blocks are/ nearly are identical). It would be easier to get a 24V engine and hang a mechanical pump on it converting the engine back to all mechanical than trying to put a 24v head on a 12v engine.
There are also basically two different versions of the 12v that are found in Dodge trucks. The early engines had a Bosch VE rotary pump. This is a good pump and driveability is excellent, but the pump physically is too small to pump enough #2 to support more than about 325HP +/- 25. The second version of the 12v is more commonly known engine with the P-7100 inline pump. Of any engine the desirable components are the ones cast in the Brazil foundry. Although any non-53 block is of a decent quality, the Brazilian castings are a bit heavier than other versions.
Although I've had several Cummins 6BT powered trucks, two factory Cummins powered Fords, I still like my 7.3 and will continue to run it. The 6BT's are a good engine for sure, but they have their problems too. 53 block to name one, head cracking is another. If you want to put a 6BT in a Ford it's getting fairly easy to do. If you want cheap HP get a CR and spend the time (if yours it's free) to get all the electronics to work. The 12v is a simple and reliable engine and can make very big HP reliably, but it will cost more.
pmurray is offline   Reply With Quote
Old 04-24-2007, 05:32 AM   #19 (permalink)
The 97 and rare 98 motors are the mostly popular ones because to the P pump being the higher hp rating 215hp stick and 180hp auto. Change out the delivery valves and basically you have the same pump.
Early 99 F250 PSD 2WD,6B DDP4s,HTT66SP/SS13,Oringed,studed,ported
Trapper is offline   Reply With Quote
