What year diesel trucks would you guys prefer? - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 03-19-2017, 09:48 PM Thread Starter
What are preferred years as far as reliability goes and cost of ownership
I am asking this because I have owned older diesels and newer diesels, and I know that sometimes with newer diesels everything is electronic creating a lot more headaches and costly repairs. Sometimes stuff isn't made as it used to. How about driver comforts and convenience..?
What would you guys prefer if you were going to invest in a daily driving heavy diesel truck, late model/newer... or pre-a certain year? For stuff such as cost of ownership, parts availability, comfort, user-ability, etc..?
I'm thinking of investing some good money into something that will serve me for the next 10 years plus, and swapping my nice service body/dump/arbor body over to a cab & chassis of my choice.
Thanks for reading, and for any advice!
greenstar is offline
post #2 of 9 (permalink) Old 03-19-2017, 10:55 PM
96-97 model, mid level mods put it at the same level as the new trucks and WAY easier to work on
-OEM sensor replacements are plentiful (500.00 will replace EVERY sensor on the engine with genuine motorcraft replacements, includes glowplugs)
-said sensors are easy to change out
-only a handful of sensors to wory about (all sensors/solenoids can easily be kept in glove box for backups, yes that few)
-almost everything is easily replaceable with a small under-seat tool kit
-aftermarket support is VAST for these years
-97 has the has forged rods vs powdered metal rods of 99+ powerstrokes
-interchangibility of the 7.3 with 6.0 parts, 7.3 international parts gives a vast support network of parts
-KNOWN dependability of very high millage if properly maintained
-no head bolt issues or head gasket problems
-HPOP is easily replaced, same for fuel bowl (argue the relocation / aftermarket, im only talking oem placement)
-mods for systems are easily done, no computer programing to change when relocation of oem pieces throws the computer into fits cuz it's not stock
- NO DEF FLUID OR DPF!!!!!
yes these years have their faults
-lack of cupholders are a rather big deal... (no im not kidding, not having somewhere to set ur drink is freakin annoying)
-they are rather simple and plain when compared with the 99 superduty's
-they don't ride as well (can be changed to superduty springs which ride FAR better than the log wagon springs they came with)
-they aren't computerized (so you know which glow plug goes out, you must check each pin on the harness to find out which is bad)
-rear drum brakes (I honestly have no problem with drums, there are just some tricks to working on them)
-lower gross towing than newer ( mainly due to power if I understand it correctly)
-stock radio/speakers SUCK (face it, you upgrade the speakers in the stock newer ones also... it's not rocket science to upgrade these older trucks)
-louder ambient noise from the road due to less insulation vs newer trucks
-you will have to replace virtually every wear point in the truck (4x4 especially bad due to so many u-joints)
-rust... although I think Ford has been bad overall on this point in all years, these years WILL have medium to heavy rusting on the undercarriage
-limited fuel range (easily upgraded though with bronco fuel tank mod to 58 gallons total)
I am trying to be unbiased here with my limited knowledge of the overall, im rapidly learning though and hope this helps some
narmalee is offline
post #3 of 9 (permalink) Old 03-20-2017, 12:40 AM
I prefer the 99-02 7.3 with six speed and manual transfer case. Mostly because I have had three of them and know how to work on them. If you have the money the 2012 and up have been getting good reports. Lots of power no need to hot rod and the tranny is good.
DENNY
1999 F350 CC SRW LB 4X4 SIX SPEED.
DENNY is offline
post #4 of 9 (permalink) Old 03-20-2017, 01:21 AM
DENNY
what transfer case did most earlier ones have? mine is manual, havn't actually found the model of it yet, I know it's a big sucker, tons of long ribs off the output tail to the mainbody
narmalee is offline
post #5 of 9 (permalink) Old 03-20-2017, 12:11 PM
You could get ESOF or Manual. Lots of dealers ordered ESOF as a selling point, I prefer manual for several reasons. One of which is you can shift to neutral and tow the truck with all 4 wheels on the ground. With ESOF you would have to drop the rear driveshaft or flatbed the truck.
DENNY
DENNY is offline
post #6 of 9 (permalink) Old 03-20-2017, 12:26 PM
Texkenusmc's Avatar
I would say 99-03 7.3 for reliability. Parts are plentiful and don't have to worry about all the EPA crap. I would also go with the manual transmission they are stronger than the automatic. There are also plenty of mods and upgrades available to increase power and performance. They are also easy to work on in my opinion. I have 300,000 miles on mine with no major issues. I plan on keeping it another 300,000 miles or more. I plan on doing a full body off restoration at 500,000 miles.
Texkenusmc is online now
post #7 of 9 (permalink) Old 03-20-2017, 02:51 PM
Go to Powerstrokehelp.com you will find all the info you need here to make your decision!
maultman34 is offline
post #8 of 9 (permalink) Old 03-21-2017, 09:22 AM
Domenic's Avatar
I bought a 2003 4x4 6-sp 7.3 manual t-case and hubs new on 11/2002 and it has been trouble free and the best vehicle I've owned in 40+ years of driving.
I've been thinking about replacing it recently with a gas F150 (don't tow) but still haven't been able to part with it yet.
2003 F250 SBSC 4X4 7.3 6spd..Great Truck!!
2004 Jeep Wrangler Unlimited built for the rocks
Domenic is offline
post #9 of 9 (permalink) Old 03-24-2017, 08:31 PM Thread Starter
Guys, I don't know how this turned into a conversation about 7.3's. I know all about 7.3's. I've had two of them, and still have a 2000 7.3 and love the truck (minus the crap turning radius). It's served me well. I wasn't asking about 7.3's. Normalee just went off about 7.3's
I've been looking at 1999-2001 T6500's with the Isuzu motors...and am prepared to invest some good money....But wondering if I will be better off investing in one that is newer and maybe even taking a minor payment if I have to.
**disclaimer::
I'm not going to lie...I've owned many Ford F-450's 550's... Three different International DT-466's a 1986, a 1995, and now a 2000 dt466E... And a Ford F800 w/ a 5.9 Cummins. I do A LOT of work in the city where parking can be tricky and roadways are narrow...so I WANT A CABOVER truck I have decided. I want a 25,500gvw cabover (I need a class 6 25,000 gvw truck)
  Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
