Winter Fuel vs Summer Fuel? Need a little help here... - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 02-22-2007, 10:12 PM Thread Starter
A few questions:
1) What is the difference?
2) Which would yield better fuel economy?
3) Is there a way to identify it when pumping? Color maybe?
Thanks.
-Rob
2007 F-250 Lariat CC, 6.0L
2005 Excursion 6.0L (Wife's)
robhilts is offline
post #2 of 6 (permalink) Old 02-22-2007, 10:26 PM
Re: Winter Fuel vs Summer Fuel? Need a little help here...
Hello,
1. Winter fuel is cut with kerosene to give it a lower gel point.
2. Summer fuel - No.2 diesel will yeild better economy
3. None that I know of, no color differences
Thompsy is offline
post #3 of 6 (permalink) Old 02-22-2007, 10:33 PM Thread Starter
Hello,
Thank you.
robhilts is offline
post #4 of 6 (permalink) Old 02-22-2007, 11:43 PM
FamilyRide's Avatar
However, as I understand, the ULSD we're getting now does not get blended with #1 hence, no more winter blend as we knew it. That would defeat the point of ULSD. Supposedly it gets an additive to keep it from gelling, but from what happened all over New York State with school buses shutting down, schools closed, municipal vehicles parked etc. etc. from fuel gelling, appearently the additive didn't do the job it's supposed too, at least in severe low temps.
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, bubba lights and newly added so called bullet proofing, including PMax turbo.
FamilyRide is offline
post #5 of 6 (permalink) Old 02-23-2007, 10:25 AM
bugman's Avatar
My Photos: (12)
[/ QUOTE ]I believe that may of been a local problem. All that I have been getting for diesel the last 6 months is ulsd and I have not had any problems here in Colorado. Even with a few weeks of below zero tempatures, also I have not heard of any real problems with the new fuel around here.
Jim
bugman is offline
post #6 of 6 (permalink) Old 02-23-2007, 12:03 PM
drcampbell's Avatar
My Photos: (32)
ULSD we're getting now does not get blended with #1 hence, no more winter blend as we knew it. That would defeat the point of ULSD ...
Um, how, exactly, would blending #2 ULSD with #1 ULSD for the winter defeat the point of ULSD? If each component contains less than 50 parts per million sulfur, any blend of the two also will.
You can differentiate #1 Diesel fuel from #2 Diesel fuel by weight. A gallon of #2 weighs more. That's why the mileage and power are down; there are fewer hydrogen and carbon atoms to burn in a gallon of #1. The gas mileage per kilogram is pretty close to the same.
Douglas Campbell, P.E.
1986 Isuzu P'up, 177,673.8 miles.
- Hella headlights (highly recommended)
- DOT C-2 back end (also recommended)
- R-12 air conditioner converted to R-406a. Saved ozone and money
- 4.1:1 final drive converted to 3.4:1. Quieter, better mileage but it's a good thing I live in the flat Midwest.
- 9/22/2007, age 21: Still running well when reluctantly sent away for reincarnation, due to body & frame rust.
- Never did get around to converting it to french-fry oil, which is why I originally stumbled upon this site.
drcampbell is offline
  Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
