Problem with trailer TPMS/Camera dealer installed System 2017 Super Duty - Diesel Forum - TheDieselStop.com
 4Likes
post #1 of 36 (permalink) Old 10-26-2016, 09:35 PM Thread Starter
I picked up my 2017 F350 CCLB King Ranch yesterday and I ordered it with the dealer installed trailer camera and trailer TPMS system. For some reason the kit came in a box shipped to the dealer and not with the truck and it took the service department a bit to find it.
The dealer swapped the factory delivered 7 pin over 4 pin trailer connector on the bumper for the 7 pin over 12 pin setup that is used with the remote camera and TPMS system. The printed instructions say to take the tailgate wiring harness and unplug it from the body harness and plug it into the 12 pin connector. The dealership did this and afterwords the tailgate would not unlock or open manually or via the key fob or button on the dash.
The body harness they unplugged from the tailgate was just left uncapped and unused according to the instructions but that seems wrong.
Does anyone know if there is something wrong with this kit or when you install it there is an extra Y cable needed or you have to update the computer on the truck for the tailgate to work?
The tailgate camera did continue to work which we found odd. I guess the wiring for that goes from the 12 pin connector back through the 7 pin connector or what the dealer told me about it working is wrong.
I had them move the wiring back such that the tailgate works since I don't need the trailer camera or TPMS right away. the dealer is looking into this but my guess is I will end up having to figure it out myself or with the help enthusiasts like you guys.
Problem with trailer TPMS/Camera dealer installed System 2017 Super Duty-7pin-4pinsuperdutyconnector.jpg
Problem with trailer TPMS/Camera dealer installed System 2017 Super Duty-7pin-12pinsuperdutyconnector.jpg
Problem with trailer TPMS/Camera dealer installed System 2017 Super Duty-passengersidesuperduty.jpg
whypave is offline
post #2 of 36 (permalink) Old 10-29-2016, 12:07 PM
VermontWayne's Avatar
Whypave, I have an F350 KR due at the dealer in a week or so that I ordered with the same trailer camera option you're having trouble with. I don't have any answers but am now concerned I'll have the same issue you're experiencing. Good Luck! Wayne
VermontWayne is offline
post #3 of 36 (permalink) Old 10-30-2016, 09:03 AM Thread Starter
Hopefully your dealer is faster at responding than mine. I plunked down a substantial chunk of change with them on Tuesday and I didn't hear anything back the rest of the week. I plan to raise some hell on Monday (tomorrow) I've seen a number of videos with this trailer camera feature in use but I don't think any of them show the tailgate down etc.
I really think a Y cable is needed that plugs into the tailgate harness, the body harness and the 12 pin connector on the tailgate for this system. it was not provided in my kit.
The other excitement you may have is that Ford shipped the camera/trailer tpms kit separately from the truck so my dealer took awhile to find that.
Your kit may already be at the dealer.
Enjoy your new truck delivery and hopefully your dealer gets it all figured out and you can share it here
whypave is offline
post #4 of 36 (permalink) Old 11-01-2016, 06:14 PM Thread Starter
The dealer called me and said they talked to Ford accessory engineering and there is a different harness under the truck that they have to run to the 12 pin connector on the bumper. I am taking the truck in Friday to have them do it. The Ford corporate folks said the instructions are not clear at all. I will keep everyone posted and take pictures.
whypave is offline
post #5 of 36 (permalink) Old 11-03-2016, 03:21 PM
Is there a connector for the camera and TPMS in the bed also for a 5th wheel or gooseneck trailer to plug into or does it have to plug into he bumper plug.
2015 F450 CC DRW, Lariat Ultimate, Bronze Fire & Caribou
2012 KTM 500 XC-W
2009 INFERNO 3912 Toyhauler 43'
DRKnecht is offline
post #6 of 36 (permalink) Old 11-04-2016, 06:39 AM Thread Starter
It would make way too much sense for the trailer camera/tpms system to also have an in bed plug for gooseneck/5th wheel towing. There is only the plug on the bumper. Here is the in bed plug. I am headed to the dealer this morning to put the truck on a lift and find the correct wiring harness for this setup. I will post pictures
whypave is offline
post #7 of 36 (permalink) Old 11-04-2016, 09:06 AM Thread Starter
I stopped by the dealer and with the help of Ford Accessory engineering they learned the plug on the body harness for the 12 pin trailer camera setup is hidden above the back of the spare tire.
The mechanic was able to feel above the tire and disconnect the female plug from the plug cap that is tied to the main truck wiring. Then it can be pulled down and plugged into the back of the new 12 pin bumper plug. I tested the trailer camera and wiring that goes to the trailer and it works great. Here are a couple of pictures.
I hope this makes someone else's install a lot smoother and faster
ID:	101449   Click image for larger version
ID:	101457   Click image for larger version
ID:	101465   Click image for larger version
whypave is offline
post #8 of 36 (permalink) Old 11-04-2016, 08:17 PM Thread Starter
I put together a video of what comes in this kit and how it is installed on the truck and wired to a trailer.
https://youtu.be/IWu9MICBt38
whypave is offline
post #9 of 36 (permalink) Old 11-15-2016, 11:56 AM
manowell's Avatar
Man, thanks for putting that up! You have to see all the parts to believe it....
Current:
  • '17 Ford F-350 King Ranch Crew Cab long bed 6.7l V8 (440/925)
  • '06 Yamaha FJR1300AE motorcycle
  • '03 Thor Jazz 2850BH Fifth Wheel
Past:
  • '11 Ford F-350 King Ranch Crew Cab long bed 6.7l V8 (400/800)
  • '08 Ford F-350 King Ranch Crew Cab long bed 6.4l V8 (350/650)
  • '04 Ford F-250 King Ranch Crew Cab long bed 6.0l V8 (325/560)
  • '01 Ford F-250 Lariat Crew Cab short bed 6.8l V10 (310/425)
  • '99 Ford F-250 Lariat Crew Cab short bed 6.8l V10 (275/410)
  • '97 Ford F-150 XLT Supercab short bed 4.6l V8 (220/290)
manowell is offline
post #10 of 36 (permalink) Old 01-30-2017, 09:12 PM
New TPMS & camera
2017 ford 5 wheel TPMS 12 pin for camera package that ford does not sell or make for 5 wheel set up we have new harness extender and a split harness that supplies bumper and 5 wheel set up for the 12 pin hook up
B23842384 is offline
post #11 of 36 (permalink) Old 01-30-2017, 09:22 PM
New TPMS & camera
Not good with computers trying my best to post pics of install and harnes
ID:	104202   Click image for larger version
post #12 of 36 (permalink) Old 01-30-2017, 09:56 PM
Where did you find this? It's exactly what I need to finish the install on my 2017 F-350. I've got a 5th wheel, and purchased the TPMS and camera, but don't want to plug the camera into the receiver hitch. I want to plug it into the trailer connector I've got in the bed.
Pete
PeteNel is offline
post #13 of 36 (permalink) Old 02-09-2017, 02:15 PM
manowell's Avatar
I think it's part of the dealer-installed 5th wheel prep kit. It comes with the underbed hardware and the adapter harness, new plug. I have one on order.
Current:
Past:
manowell is offline
post #14 of 36 (permalink) Old 02-14-2017, 05:05 PM Thread Starter
This is the web site I got in a PM from him.
https://nicholsmanufacturingandweldingservices.com/
I plan to order the plate from him and I think I will only have the 12 pin up in the bed, not on the bumper. Going forward my car trailer for long trips will be a gooseneck and I will bumper tow a boat trailer I don't need a camera or tpms for.
Last edited by whypave; 03-04-2017 at 04:24 PM. Reason: Edited to provide his updated web site, not the GoDaddy one.
whypave is offline
post #15 of 36 (permalink) Old 02-15-2017, 09:42 AM
manowell's Avatar
https://nicholsmanufacturingandweldi...addysites.com/
That's the direction I'm thinking, too, for my setup. I'm wondering if the harness that comes with the Ford TMPS/Camera kit will reach that far (doubt it). The link you have above, they have a cable that "bypasses the TPMS plug for bumper pull setup.", which makes no sense to me.
Current:
Past:
manowell is offline
  Diesel Forum - TheDieselStop.com > 2017 & up Ford Super Duties > 2017 & Up General Questions
