Other Technical QuestionsDiscussion of other technical topics. Please see the sticky post at the top of the thread listing for specific rules. The rules for this forum are more restrictive than they have been in the past.
grand pa has a 1988 chevy c1500 it started and ran fine one day and the next day he starts it drives to church and it will not start after church. finally got it started after pouring gas in to the intake. so we were thinking a fuel problem. no not a fuel problem. when we got it home we tested the pump the book he has said the pump should output between 9-15psi, the pump puts out 14 psi. then we tested the coil according to the book it passed. then we replaced the cap and roter (they were pretty bad). that did not help. then he took tin ignition module off and had it tested and it tested good. we are at a loss.
when the truck sits over night it will start right up in the morning, but when you cut it off and try to start it again it will not start.
so this is what we tested and replaced so far:
1. fuel pump tested good at with a pressure of 14psi
2. replaced cap and roter
3. had the ignition module tested and it tested good.
what else could it be. we dont know what else to try.
thanks for the help.
anthony
1997 F-350 2WD SRW White Crew-Cab Bought in 3-05 w/196,xxx miles 280,xxx miles, 4" exhaust, tymar, oil bypass changed oil at 10k, TW 6 pos chip, stage 1 DIY injectors, fully build racerx trans, B & W turn over, coolant bypass filter, intercooler.
Parts Replaced:
Water Pump 213,000 $120.00 Napa
Alternator 224,000 $64.00 Ebay
Fuel Pump 221,000 $64.60 Ebay
Radiator Core 252,000 210.00 (All Alum) Preference Radiator
Fuel Bowl 262,000 NEW from Ford $348.00
rebuilt trans my self with racerX parts. 265,000 $2800.00
DIY Stage ones 267,000 $350.00
Waterpump 265,250 $70 Thedieselstop
Flexplate 280,000 $85.00 autozone
1997 Ford F350 2WD SRW Green Crew cab bought 06-07 with 232,000 miles, Now 238,xxx miles, AFE exhaust, oil bypass, coolant filter, , 6pos Tony Wildman Chip
Parts Replaced
Fuel Pump 234,000 $65.00 Ebay
Ford Reman Trans 234,000 $2100.00
Assuming it is cranking over, just not firing, it sounds like an electrical issue when the motor is relatively hot (or warmed up).
When you checked the ignition module, was it when the truck was cold, or had it been running (and warmed up), and then taken out to be tested?
I had a 1984 Nissan truck that had a cold solder problem on the fuel pump. When the motor was cold, it would start fine. When it was warmed up and shut down, it would not pump gas from the tank to the motor. Traced it to a cold solder joint on the electronics on the fuel pump. Cold, it tested fine. Warmed up, no power in the pump. I replaced the fuel pump and problem solved.
Maybe your fuel pump is testing ok when cold, but not when warmed up?
I would be suspicious of the ignition module or the fuel pump.
Also, with a truck that old, be sure and check all of the vacuum lines to make sure they aren't cracked and sucking in air when they shouldn't be. I've seen that cause problems in the past with my parent's mid-80's Oldsmobile. When the lines were cold, the car would start. Once it was warmed up, it would stumble for a while (especially if you put the gas on it to go), then it would just about die. after it warmed up, there was too much air being sucked in from all of the cracks, and it would just spin without firing.
Have you tried to see if there are any codes being thrown out?
just some things to ponder.
short_stuff
Y2K F250 CC PSD Auto, Short-bed Lariat, Woodland Green/Gold, ordered 07/10/99, born 09/12/99, delivered 10/08/99, Access bed cover, Bed Rug, Zoodad mod, Viper Remote Start Alarm, Fumoto valve, 103K somewhat error-free miles (so far) [never back to dealer for anything]
Repairs: CPS, Water Separator Valve assembly, rear axle bearings, VSS, batteries, brakes, alternator, serpentine belt (x2), driver door pwrlock actuator, water pump
2009 VW Tiguan 2.0 l turbo 200 hp gas engine (TDI engine not available for it yet)
I am aware you stated "not a fuel problem"but I didn't notice if you have tried adding gas or starting fluid at intake since getting it home. Therfore I relate a past experience where I spent months testing and replacing parts while the problem was a tiny fuel filter in the carb inlet which I failed to notice. Look very close.
I would say that it is the control module. I had a 89 GMC company truck that would run fine until you shut it off then it wouldn't restart until it cooled off for a while. My problem was that I had to drive it 70 miles one way from town to town. I used to call a repair shop and tell them if I didn't check in with them to come find me, then on the return trip I would do the same with another shop. It finally died and wouldn't restart and they got to check it while the truck was hot, problem solved.
I'd be curious to hear a solution to this as well. I have a '90 Chevy 1500 with a 350 and it does the same thing. On mine, I can pour a tablespoon full of gas into the throttle body and it starts right up.
I've been suspecting gummed up injectors...
-Evan
2000 Vermillion F250, 4X4, SC, LWB, PSD, 6sp. Autometer Sport Comp 2 5/8" Boost and EGT, Tekonsha Prodigy brake controller, Retrax bed cover, LED tail conversions, electronic flasher, Rotorpro brake disks, homemade open element intake, Pioneer SYS 900 navigation system, Kicker RMB8 Subs, Rockford Fosgate 200M amp, Clifford Matrix Rs3 Alarm, Rancho RSX shocks, Relocated parking brake release, Home Depot regulator on the MAP sensor, DP Tuner chip 40, 80, 120 HP - 312 RWHP / 600 Lb-Ft Tq. on the Dynojet. Her name is Xena - a rolling test bed for my crazy ideas...
"Doing my part to control the mosquito population..."
Which "module" are you talking about? Would you describe where it's located?
Thanks!
-Evan
This is not the cap mounted coil, right? It's the electronic module in the base of the distributor? The one the wiring plugs into.
-Evan
