Go Back   Diesel Forum - The Diesel Stop.com > Other Topics > Other Technical Questions
Other Technical Questions Discussion of other technical topics. Please see the sticky post at the top of the thread listing for specific rules. The rules for this forum are more restrictive than they have been in the past. Topics will expire automatically in 60 days.
Old 09-14-2008, 06:52 PM   #1 (permalink)
2001 GMC Sierra 2500 HD 4x4 issues
I bought a 2500HD with push button 4x4 about 2 months ago. I started having intermittent trouble with the 4x4 about a month ago. I was getting a service 4x4 light and the problen just mysteriously went away. A couple of days later I lost everything to do with 4x4. There is no service 4x4 light, no indicator light that i am in 2 wheel drive, and it will not change into 4x4. I am looking for guidance on what to check. I have a feeling that power is not getting to the transfer case control module in the dash but I don't have a wiring diagram. Thanks in advance for your help.
1997 f350, 5 speed, 4x4, 4.10
bigredflatbed is offline
Old 09-15-2008, 02:23 PM   #2 (permalink)
PSDfreak's Avatar
I am sorry I dont have any advice to offer....but a guy I work with has a 2005 Silverado 1500 and he experienced pretty much exactly what you are describing..I'll be curious to see what you find out!
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Tymar HPX●Wildman 3 Pos. Chip (Econo/Tow/Xtreme)●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●LuK SMFW●4” Rancho Suspension Lift●Ride Rite Rear Bags●Bilstein 5100 Shocks●Rancho Stabalizer●Energy Poly Bushings●Hella 550’s●Line-X●315/75/R16 BFG A/T●Pro Comp XTreme Wheels●Diamond Plate Rails, Gate, & Bulkhead●Ford AIC ●Cobra 25 w/ Wilson 1000 Ant. & RK-56 Mic●Sirius Sat. Radio●
PSDfreak is offline
Old 09-15-2008, 05:31 PM   #3 (permalink)
MarkEkberg's Avatar
My Photos: (13)
If it the same set-up they have had for years it soiunds like the 4x4 actualtor is shot.
It is a gas filled piece. When you put it in 4x4 it heatrs the gas and the plunger is pushed out engaging the 4wd. When the seal goes the gas leaks out and the plunger can not move.
It would make sense that there are no lights becasue it is not actually engaging.
This of course is only if gm is still using the same system.
MarkEkberg is online now
Old 09-16-2008, 10:17 PM   #4 (permalink)
I have been told by someone else that it may be the actuator. I do not even have the light indicating 2x4 but they said a bad actuator could cause that.
