Re: 2003 Monte Carlo Check Engine Light
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: fordboy424</div><div class="ubbcode-body">The wife's 2003 Monte Carlo SS 3.8 v-6 65000 miles all stock has been getting a p0440 (evaporative emission control). This is the first problem with the car, we have had it since new. Not really sure where to start looking. Anyone have any ideas? Thanks
By the way I have the AE domestic package, just not sure how to use all the fetures on a gas engine. </div></div>
Evap codes can be a real PITA to pinpoint what the problem is.
I would start by looking at the evap lines where they connect to the intake manifold, then check the lines to the fuel tank from the engine compartment. Make sure none of the lines are cracked.
If you don't see anything obvious I would recommend replacing the fuel cap. Make sure to use a Delco fuel cap as I have not been impressed with the quailty of some of the aftermarket fuel caps.
2002 F-350 CrewCab Lariat Auto 4X4 7.3L PowerStroke Diesel, DRW, 4.10LS, Camper package, Auto-jet muffler delete pipe, Digital Pyro, Trans Temp Gauge, True Blue, SCMT, DELPHI SKYFi XM Radio
