60 Series MTU Heat exchanger (Marine) - Diesel Forum - TheDieselStop.com
Old 06-14-2009, 08:10 PM   #1 (permalink)
DIESELDUTTON's Avatar
Has anyone removed a heat exchanger on a 60 series MTU? I have done several, just not on a MTU, I'm not sure if you remove the entire heat exchanger or if you remove the front cover / fuel cooler and pull the plate cooler out. Any input would be great. Thanks guys
Frank
http://community.webshots.com/user/dieseldutton
2004 Pitbull Motorsports rigid chopper
121 TP 130rwh 250 avon
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyones
1998 27.5 Wilderness 5th wheel
DIESELDUTTON is offline
