Aluminum cleaner? - Diesel Forum - TheDieselStop.com
post #1 of 14 (permalink) Old 02-24-2008, 12:19 PM Thread Starter
Aluminum cleaner?
Trying to clean some aluminum engine parts like a timing cover and therastat housing and stuff like that. They are aluminum and have some discoloration and corosion after all the grease is removed. Is there a chemical or spray I can get localy that will take any of this off and give me a uniform finish? I think I'll clearcoat it when its done, my only other option if all else fails is to sandblast them but that may be too rough.
Thanks,
-Rob
'94 F250 XLT 7.3L. Turbo Diesel 4X4 "OFF ROAD" package, X-Cab, 4.10 grears, Now a 5 speed, original IP, just did injectors,"Wallace mod" 3.5" turbo outlet housing and 3.5" DP and straight piped exhaust, 113K on the clock. Repainted it black. Ispro pyro and boost gauges, turned up pump.
ClassicFordGuy is offline
post #2 of 14 (permalink) Old 02-24-2008, 12:50 PM
I used to use a paste called 'Simichrome' on my motorcycle aluminum parts. Works well, takes quite a bit of effort, but aluminum will shine very well with it. Don't know where you would get it these days. I used to buy it from the motorcycle dealer. The stuff isn't cheap, but a tube of it will last a long time.
Just looked on EBAY and see that the stuff is still in existence.
2008 F-250 Lariat, Supercab, Long bed, 4x4, 5.4L non-diesel
Bassman349 is offline
post #3 of 14 (permalink) Old 02-24-2008, 01:32 PM
bugman's Avatar
My Photos: (12)
You can get some "Mothers Aluminum Polish" at your local NAPA. It is some good stuff.
Jim
bugman is offline
post #4 of 14 (permalink) Old 02-24-2008, 01:50 PM
Bluepowerpoky's Avatar
there is polish called speedy clean works the best i think truck stops sell it or at least arond here
96 f-350 6x4, aFe cold air intake, 3" down pipe, 3 1/2" in straight pipe, super chip, air horns
, billet tork converter, perma cool trans cooler, cobra cb, 8 1/2' antenna, pacific dually covers, good year work horses, sold. In search of an 04 dodge 3500 cummins dulley
Bluepowerpoky is offline
post #5 of 14 (permalink) Old 02-24-2008, 04:51 PM
Hook'em Horns!'s Avatar
Send a message via Yahoo to Hook'em Horns! Send a message via Skype™ to Hook'em Horns!
Thanks,
-Rob
I’ve been using Home Page for years on the Harley. If it’s on any metal and shouldn’t be, this takes it off, and it makes aluminum look like chrome. Cotton wadding base won't scratch. Nevr-Dull cleans and polishes:
Aluminum
Copper
Pewter
Brass
Gold
Silver
Chromium
Nickel
Zinc
Just a pinch of wadding goes a long way and no residue. Get it at Wally*World, Hm Day-Pot, Ace and the like.
2007 Chev Duramax LBZ/6-spd Allison 3500 LT3 DRW CCLB, Sulastics, Putnam XDR 15K, B&W 30K-Turnover GN, Ride-Rite Air, Roll-Top Cover
2006 Chev 6.0L/4L80e 3500WT DRW Ex-Cab 9'Flat-GN
A/T Revos
Use-ta-Haves
2005 Chev Duramax/Allison 3500LS DRW CCLB
2002 Chev Duramax/Allison 3500LS DRW CCLB
DON'T STEAL! The Government Hates Competition
Hook'em Horns! is offline
post #6 of 14 (permalink) Old 02-24-2008, 10:20 PM
I have used Nevr Dull , works great and no mess
fieldtrialer is offline
post #7 of 14 (permalink) Old 02-25-2008, 11:00 AM Thread Starter
Sounds good, thanks for the imput. I already have some never dull so I'll give that a shot first.
Thanks,
-Rob
post #8 of 14 (permalink) Old 02-25-2008, 07:58 PM
My Photos: (33)
do you want them cleaned or polished? If you just want to brighten the aluminum finish then what you want is aluminum brightener. I have 5 gallons of the commercial stuff they use to clean cattle trailers. Its mean stuff!
My local Napa store sells "aluminum brightener" in a gallon jug. works Ok nothing like the commercial stuff but good enough.
all the items listed above are more polishes than cleaners. Also if your trying to strip an anodized coating off, oven cleaner seems to work best for small parts.
00'F350 psd CC Drw 2wd Bright Amber Western Hauler, exhaust brake transfer flow 50 gal tank tool, 30K Cody goose neck hitch, hawk pads, cryo'ed rotors, stainless lines, 380,000 miles
02' Psd Excursion Limited ultimate Estate Green 7.3L Auto 2x4 hellwig swaybars and rancho 9000's. 381,000 miles.
1993 F-superduty (F-450) 7.3L Gutless non turbo 2x4 Auto, Tire eating S.O.B. 12,750lbs 80,000miles lincoln Vantage 500 Duetz bolted in the back.
1994 7.3 I.D.I.T. factory turbo, auto 2x4 DRW with lots of upgrades, 11 transmissions under 100K factory warranty. 280,000 miles Currently Cavitated and parked.
96 F-800 24'flat 5.9L cummins, 4spd allison juice brakes.
89 F-800 6.6L 5+2 27,00lbs light weight with National 556A crane behind the cab.
2006 T800 KW 550 C-15 18spd 22K front, 52K rears murray ramps, 195" W.B. CA spec heavy haul SOLD
2006 Murray 16 tire professional lowbed SOLD
1996 fetherlite 4 horse GN, Walton 18' 14K tag tilt equipment trailer.
Dualie is offline
post #9 of 14 (permalink) Old 02-26-2008, 01:47 PM
[quote=Dualie;1518668]do you want them cleaned or polished? If you just want to brighten the aluminum finish then what you want is aluminum brightener. I have 5 gallons of the commercial stuff they use to clean cattle trailers. Its mean stuff!
Dualie,
Where/how do you get the industrial-strength aluminum brightener?
strelnik is offline
post #10 of 14 (permalink) Old 02-26-2008, 02:02 PM
I have used Flitz, it is a good cleaner/polish. I have used it on alcoa wheels, stainless fuel tanks, chrome etc. The trick to removing the wax/polish is using flour, regular stuff used in cooking. I take a small bucket/ container, put the flour in the bucket, use a soft cotton towel, cover the towel with the flour. The polish, and residue will come off with ease. I would polish large areas at a time, without worry of removing the polish. This sounds crazy, but I learned this from a professional wheel,and fuel tank polisher. It is amazing how this works. An air hose helps to blow off the flour, then buff for the final step.
Sold 02 F350 Lariat CrewCab Toreador Red/ Silver DRW LB AT 4X4 4.10 gears, BTS custom chip, and tranny. built BTS and Ford Tough! 859,532 miles
SOLD: 02 F350 Lariat CC Toreador Red, DRW AT 4.10 gears, BTS custom chip, and Tranny 214,550 miles,Built BTS, and Ford Tough!
Sold 94 F350 XLT SC DI DRW 5Speed 314,000
Lifetime Member "BTS BUBBA" Association
"Ain't no feelin like BTS mobilin"
SLAPS Member
Sold 62 Corvair 95
Bus
92 Buick deuce and a quarter
03 Ford Windstar- Granny Hauler
HighwayPrisoner is offline
post #11 of 14 (permalink) Old 02-28-2008, 01:49 AM
My Photos: (33)
[quote=strelnik;1519358]
Dualie,
I make custom metal plating tanks. The major west coast distributor of the acids for metal plating is a great customer of mine. it would be very difficult for most people to get this stuff. Its pretty nasty stuff.
IF left on too long it will eat its way through 1/4" aluminum no problem. even diluted it will still turn polished aluminum snow white in seconds of you don't know what your doing.
Dualie is offline
post #12 of 14 (permalink) Old 02-29-2008, 06:02 PM
Like someone said the truck stops or maybe a Fleetpride if they have them in your area is sure to have what you need.
Zep purple degreaser will etch aluminum pretty good also.
early 99 F350 4x4
DieselDeaf is offline
post #13 of 14 (permalink) Old 02-29-2008, 06:10 PM
Unless you have experience with the Aluminum brightener, do not use it. Notice I did not equivocate. You need to be taught how to do it, and need to understand the hazards. IT WILL KILL YOU IF YOU GET AS LITTLE AS A TEASPOON ON YOU! It is Hydroflouric acid and will seek out calcium and you will not feel a thing while it does it. Read a little about it here. Professional Carwashing & Detailing Online :: Brought to you by Grand View Media If you are still not worried about it, then knock yourself out. Just make sure you wear protective gear.
New addition:
2006 f-550 service body with a 20 foot stellar crane.
Arrest me red 2006 F-250 6.0 Even more loaded
Black 2000 F-250 4X4 PSD Lariat, loaded.
Green 2001 4x4 Excursion Limited with PSD, loaded
White 2004 F-250XL, it is loaded with just a LS. I can't find the other options.:P
Just how many superduty's does a guy need?
The-washer is offline
post #14 of 14 (permalink) Old 02-29-2008, 09:28 PM
" Killed by Alumabrite " ????
After reading that, my B.S. meter just ran on up to Full Tilt.
I have used this and similar products that are much worse for years.
YES! they are hazardous when used improperly. They will give you acid burns on exposed skin, but only slight irritation if just a mist or splashed on you. I have had it happen many times over the years. If you wish to soak your hands in it, it will eventually remove a fingernail or two and burn your skin like a deep sunburn. Voice of El Stupido experience here. But I have never been killed by it, (at least last time I checked) and I have been soaked in much more than a tespoon full more than once. In full strength it "WILL" most definately strip the shine off of aluminum if used improperly. It removes paint a minuscule layer at a time also if left on very long. Makes an oxidized paint job look like new as long as there is enough paint that it can afford to loose a layer.
2005 F-350 CrewCab Lariat, 6.0 Diesel, Automatic Transmission, Shift on the fly 4X4, 3.73 Limited Slip Rear, Dark Toreador Red / Medium Pebble leather, Lariat Luxury Group/With Auto Temp Control, Heated Power Captains chairs, Premium Sound AM/FM 6CD, Camper Package, Rear Stablizer Package W/Heavy Reciever hitch, Tow Command System, Power Rear Slider, Adj Pedals, Reverse Sensors, 18" premium wheels, Viper Liners spray in bed liner, Bremen Composites full flare Runningboards.
Dutchman1 is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Other Technical Questions
