The generic part will work on anything (except Chrysler products - they use a different DTC connector
). For really working on anything, you'd need the enhanced package for that manufacturer, which you can add on at any time by calling AE, sending them money, and they'll send you an activation code. Actually, the Chrysler interface is available too, if you need it.
99.5 F250 PSD Supercab LB 4x4, ZF-6 w/SB Con OFE, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, DP 80 HP Econo PCM (classic version
), AIS,
coolant filter w/"hokum" bracket, regulated return,
heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check Here
