blown head gasket...what possible collateral damage? - Diesel Forum - TheDieselStop.com
Old 12-21-2007, 10:52 AM   #1 (permalink)
muntu's Avatar
motor is a 4 banger 1989 renault...this is happening to my boy stuck in finland..he just finished changing the gasket and now the motor is smoking...he did an oil change and said oil looked like chocolate milkshake...could the coolant have fouled the rings? the gasket was breached on the #1 cylinder only.would giving it a hard run maybe clear things out? car has to go for immissions test in a week and he needs to drive it another 2 months.does any napa gunk stop smoking??.....any help appreciated.
2008 6.4 extended cab 8ft box auto with timbrens and goosenek hitch plus 100 gal aux.tank in bed.
muntu is offline
Old 12-21-2007, 11:37 AM   #2 (permalink)
MarkEkberg's Avatar
My Photos: (13)
Re: blown head gasket...what possible collateral damage?
Did he change the oil after the gasket change? If so the gasket is still leaking.
If not you can try to change it and see what happens
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
MarkEkberg is offline
Old 12-21-2007, 11:45 AM   #3 (permalink)
My Photos: (27)
Not to do a computer screen diagnosis, but many times I've seen engines run for a period of time with a blown head gasket and the coolant will gum up the rings badly enough they'll be stuck in the lands.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body">would giving it a hard run maybe clear things out? </div></div>
He might give that a try but usually if they're stuck, they're stuck. I've seen some so bad that you had to break them in pieces to remove them. After using a ring groove cleaner the piston is most always good as new.
'91 F-250 SC 4X4, 5spd. ATS Turbo http://sports.webshots.com/album/180135797kNEIOu
LMJD is offline
Old 12-21-2007, 01:03 PM   #4 (permalink)
muntu's Avatar
thanks for the replies....guess he's gonna doa ring job.
muntu is offline
Old 12-21-2007, 10:55 PM   #5 (permalink)
pwrtrip's Avatar
well if he was burning coolant before he changed the gasket his muffler and cat could be full of antifreeze and will take some driving to burn it all out.
1996 crew cab 4x4 black psd
BDP 250cc hyrbids
BDP fuel system
Stealthhinator dual ipr hpop
H2E
TDP tuning
515hp 1158tq
99.5 psd reg cab 2wd
334hp 740tq
rdrcm #29
"New opinions are always suspected, and usually opposed,without any other reason but because they are not already common" John Locke
Truck and misc pics
pwrtrip is offline
