Buried wood decay rate? - Diesel Forum - TheDieselStop.com
Old 03-20-2009, 11:39 PM   #1 (permalink)
My Photos: (11)
My daughter and son-in-law bought a house in the mountains outside Blue Ridge, Virginia, a few years back. When the land was cleared for the house and yard a bulldozer was used to push all the stumps and overburden to the bottom of the yard and left it in a pile. It looks like a pile of dirt covered by vegetation but I am sure it is filled with roots and stumps. The pile has been there for about 7 years and I'd like to get rid of it. The heaviest equipment I will have available is a large Skidloader/Bobcat. I'm hoping the stumps and roots will have decayed sufficiently that I will be able to break them up and move them with the dirt in the skidloader's bucket. If I can do this there is a nearby wash that I'd like to fill. What are the chances that the wood will be sufficiently decayed to break it up and move it with the dirt? BTW: I expect most of the stumps to be hardwood.
2010 Ram 3500 Cummins, AT, 4x4, CC, LB, Line-X, B&W Turn Over Ball, RBW Lil Rocker modified to fit B&W, Milemarker hyd. winch. Elkhorn 9VS slide-in, Nomad 24 ft. fifth/w slide, Century topper, old classic Sooner 18' 4 horse stock trailer. StarFlyte by DynaMax 6.8 V10.
Formerly: 97 F-250 SC LB PSD. 4x4, With lots of Goodies. Twas a good truck.
If you don't care where you are, you ain't lost.
Larry
Larry S. is offline
Old 03-21-2009, 09:22 AM   #2 (permalink)
MarkEkberg's Avatar
My Photos: (13)
It might have, but it takes a long time for wood to rot while it is burried. My folks burried a bunch of stumps when they built their house in 86. it is now just starting to show a depression in the ground.....
Good luck.
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
MarkEkberg is offline
Old 03-23-2009, 06:25 PM   #3 (permalink)
My experience is that buried lumber (even treated) lasts about 1 year less than what you planned or needed it to. :-)
I think it depends on how wet/dry the area was, and whether any termites were able to do their job or not.
short_stuff
Y2K F250 CC PSD Auto, Short-bed Lariat, Woodland Green/Gold, ordered 07/10/99, born 09/12/99, delivered 10/08/99, Access bed cover, Bed Rug, Zoodad mod, Viper Remote Start Alarm, Fumoto valve, 103K somewhat error-free miles (so far) [never back to dealer for anything]
Repairs: CPS, Water Separator Valve assembly, rear axle bearings, VSS, batteries, brakes, alternator, serpentine belt (x2), driver door pwrlock actuator, water pump
2009 VW Tiguan 2.0 l turbo 200 hp gas engine (TDI engine not available for it yet)
short_stuff is offline
Old 03-24-2009, 04:43 AM   #4 (permalink)
Fence posts usually rot within a few inches of grade as the rotting process requires air. Down a foot from grade the post is solid. Stumps buried at any depth will stay solid for a long time. Once unearthed, stumps are really hard to get rid of as they don't burn worth a darn and most landfills don't want them either. We bury all of our stumps as there's nothing else to do with them.
'93 F-250, - most original at 252K miles, rebuilt E4OD 220K miles
Greenie is offline
Old 03-24-2009, 11:10 AM   #5 (permalink)
Unless the stumps are absolutely HUGE you ought to be able to move them with the skid whether they break or not. This past summer I dug out a maple stump for a client that the trunk was at least 2 1/2' in diameter that I was able to pick up and move with my Cat 248 skid. If you can't pick it up you ought to at least be able to shove it around, if that's not an option if you chain it up in the bucket you can lift an item that is way beyond the machine's rated capacity just a few inches.
God, Guns & Guts made America free!
Lagrangeville, N.Y.
'97 F-350 DRW dump (sold)
'01 F-350 SRW flatbed
'02 F-550 Dump
Redneck_Steve is offline
Old 03-24-2009, 12:35 PM   #6 (permalink)
RightWingNutJob's Avatar
Depends on the oxygen. They pull well preserved 500-8,000 year-old oak logs out of peat bogs in the British Isles
English bog aok: rare bog oak is buried treasure. - Free Online Library
'01 F350 XLT, CC, 4x4, V10, SRW, LWB, Auto, 3.73LS, Island Blue, Off Road Package,
Auto Hubs & Cab Clearance Lights. Autometer water temp, tranny temp, & vaccuum
gauges. Line-X Bedliner, & the "incredible self-locking tailgate." White Night Backup
Lights & Volvo-eating Class V Hitch. Reverse Sensors.
RightWingNutJob is offline
