Other Technical QuestionsDiscussion of other technical topics. Please see the sticky post at the top of the thread listing for specific rules. The rules for this forum are more restrictive than they have been in the past.
The main floor in the cabin is to have tile so I am going to install 1/4 backer board on the entire floor. Now the question is the top floor or upstairs. I am going to install carpet there so I want to place a plywood top on the sub-floor. I am going to install the plywood at 90* to the current flooring and install the plywood in a 'brick' fashion. Now the question is what type of sealeant should I place on the plywood before installing the pad and carpet? I would ask the guy's at HD but sometimes I get funny answers. Ideas? Thanks.
95 F250,XLT, 4WD, Auto Trans,bbshimmed,synthetic trans oil,4:10 gears ,Truck Trunk ,Nerf Bars ,crome Mud flaps, Aux. trans cooler, front diff. drain plug. External trans.filter, trimmed snorkel. American wheels water temp guage, front fuel tank mod,Warn Manual hubs,Putman class 4 hitch 189k mi.
It is said if you sit by the river and watch the water flow by long enough, your enemies will pass by. This I believe to be true. It is also possible to watch your loved ones pass by as well.
Wife Candi 08/14/07 missing her always
I've never heard of anybody who has applied a sealant to underlayment (plywood). Only if there was an excessive gap between sheets they might lay down some aluminum flashing so you don't feel the gap through the carpet and padding.
Go with 5/8" underlayment. Around here it's known as 5/8" AC/PTS.
On edit: I'd lay down the underlayment the same direction as the subfloor which should be perpendicular to the floor joists. Leave about 1/8" between sheets on the butt ends and about 1/16 on the sides between sheets. Cut about 1/2" short of wall plate. The trim will cover the gap and you need the spaces for expansion. You don't want the underlayment to buckle.
Stagger the first sheet of underlayment over the joints of the subfloor below and go from there. Use ringshank nails and nail every 5 - 6 inches. If you can, borrow or rent a nail gun and go at it good. You won't regret it later (at least that's the way I do it with my own house).
2005 F250 XLT SC, LB
6.0 Torqueshift 3.73LS 4x4 ESOF
A/C, T/C, Upfitters
Truck Build: 02/05/05 Kentucky
Engine Build: 02/03/05 Indianapolis
1910 Hrs, 75K Miles - No Major Problems
ZOODAD, SEIC Mods
4" Banks Turbo-Back Duals
3.5" Ready Lift
Bilstein 5100's
315 - 70R17 Goodyear Duratrac's
Boss 4" Wheel to Wheel S/S Nerf Bars
Bodiak Front Receiver
ScanGauge 2 w/Blend Mount
New Motorcraft 850CCA's @ 67K
Coolant Bypass Filter
HFCM Plug Upgrade
Blue Spring Fuel Pressure Upgrade
GlowShift FP Gauge/Strictly Diesel Adaptor
Zerex Red ELC
2 Stroke TC-3W Oil added 1oz/Gallon Fuel
I had not heard of the sealeant either so I ask questions. New question. What do I do about the stairs? I have no problem installing the 5/8 sheets but the top deck of the floor will be 5/8 inch higher if I do this at the stairway. They recommended the 90* to the subfloor panels. Thanks for the reply.
I would throw down some liquid nails. It will stop squeeks.
Use screws that are long enough to go through both flooring material and into the joists.
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: MarkEkberg</div><div class="ubbcode-body">I would throw down some liquid nails. It will stop squeeks.
Use screws that are long enough to go through both flooring material and into the joists. </div></div>
Everywhere else use nothing longer than a 2" undelayment nail otherwise you risk hitting anything that may be attached to the underside (pipes, wires, etc.) especially if the original poster's cabin is post and beam construction and the underside is exposed.
Case in point, recently we nailed off some underlayment for a tilejob in an older Lindal Cedar Home. The setting on the gun left a few of the 2" nails about 3/32 below the bottom of the subfloor. Just sio happened one nail perforated the hot lead in a 14/2 Romex. A few days later the tile guy's helper found out about it when he was grouting and touched up against the gas line. [img]/forums/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
The few nails that were protruding through were not an issue because it occurred in the basement ceiling in a utility area (thus the wire nailed to the underside of the floor). You couldn't really even see them.
A/C, T/C, Upfitters
ZOODAD, SEIC Mods
3.5" Ready Lift
Bilstein 5100's
HFCM Plug Upgrade
Zerex Red ELC
My son-in-law installs tile and carpet for a living and he says he doesn't use a liner or sealer on tile except for showers. The grout needs to breath, so no liner or sealant on regular tile floors like kitchen, halls, etc. He does use a liner/barier on wood floors.
2002 F-350 SRW Lariat,4X4, PSD with too many goodies to list. 182k and a very strong 7.3. SOLD
2008 F-250, SC Lariat, 4X4,Shortbed, Pueblo Gold/black, V-10, 4.10, auto, Delivered on 9/7/07, great looking rig. South Texas bumpers front/rear, Air Raid Intake System, Diablosport Predator, Magnaflow, Husky's, JJ's, Ford alarm/remote start, Marathon seat covers, Sirius, PIAA, Access cover, Weatherguard tool box, Rhino liner, Michelins, Duraflap mud flaps, Escort 9500i, MagHytec rear dif cover.
2007 Lincoln LT (wifer's grocery getter),Superchip,Magnaflow duels, K&N dropin, Leer Browning Special
1996 Ford Bronco EB; almost stock
2007 Kubota 900 RTV diesel with goodies. pappy's truck
