Calling All Electricians - Diesel Forum - TheDieselStop.com
Old 12-20-2007, 02:42 PM   #1 (permalink)
I need to have my main panel on my 30 year old house replaced. It is a 200 amp main and mounted on the exterior of my house. Does anyone out there have a guess on how much this should cost? Any referrals in Fort Worth, TX?
96 F250 SC E40D. Full Force Stage I's, Tymar intake DP and HX, ISSPRO on the a pillar. Tony's tunes.
68 Mustang FB "S"Code - Currently getting a heart transplant and upgrade to a 427/500HP "center oiler"
jmontes is offline
Old 12-20-2007, 04:49 PM   #2 (permalink)
Re: Calling All Electricians
Do have underground or OH electrical service?
What size was the old service?
Does the meter & socket need to be replaced? Will the meter socket (terminal) hold a large enough wire to feed a 200 amp panel?
($2500)
'93 F-250 IDI, 4x4, K&N, no soup bowl, stock, with 265,XXX miles 5 speed, 3.55, kind of new LUK clutch, runs great, starts great, it is great. The truck is getting old.
BuilderBob is offline
Old 12-20-2007, 05:08 PM   #3 (permalink)
1. Underground
2. 200 amp
3. Do not know, but can't see why it would. / I think so since it has been 200 amp since new.
I am wanting to replace due to the box being 30 years old, it's an outside box, and I think I may have some loose breakers.
jmontes is offline
Old 12-20-2007, 05:49 PM   #4 (permalink)
About $1000 if you buy the parts at Home Depot and do it yourself.
If not like BB said about $2500.
Call the city and the utility and find out if the Code has changed about the grounding required. You will need to probably set 2 ground rods six feet apart and bond the water and if you have it, gas.
You can also find out how much the permit will cost when you call the city. should take two electricians 3-6 hours to do.
2OOO F-250 4WD Crew Cab, 248,000K miles,
Stock. Replaced #1 Injector/harness, Starter Relay,CPS(twice), GPR, VSS, S-Belt, Alternator H2O Pump. AIS Severe Duty Filter, Switched 10K MOD, Bilsteins, Heater shutoff valve, Rotella Syn, Nitto TG's 305/55 on Eagle 20x10's, Mobil 1 ATF,Walker BTM, Optima Redtops,Mesa, Arizona
PRDATR is offline
Old 12-20-2007, 09:57 PM   #5 (permalink)
Where I live you have to have a licensed electrician do the hook up to the Utility Company. Once the main feed is connected, you can do the rest yourself.
2004 F-250 King Ranch CrewCab ShortBed 6.0L
kc2kgt is offline
Old 12-21-2007, 07:32 AM   #6 (permalink)
Try Lectric Ray's His name is Ray Jones. Great Guy, Great work, good prices.
817-903-1117
Andy
Early 99 5-98, F350 extended cab, DRW LB 245,000 miles and counting, Hood insulation delete (Soaked with fuel), Hutch mod, Harpoon mod. Otherwise, pure stock (for now)
You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
arisley is offline
Old 12-21-2007, 08:04 AM   #7 (permalink)
Just had mine updated from who knows what to 150amp. Had to use the inside old panel as a junction box and put the new main outside. Two eles about six hours and $2000.
Paul B
2001 Excursion Limited PSD,2wd,Auto. Toreador Red,10/2000,4.5 Racor,unTAGed,203*,DP-Tuner,AIS Filter,Riley Coolant Filter,6.0 cooler,Cat ELC,Son/Tri,Underdash Lunar Gauges,Hadley Air Horn,On Board Air,Fumoto,2006 31' Flagstaff TT 6.5K,Prodigy
2000 Honda CRV EX
PIC'S
pabrannan is offline
Old 12-21-2007, 04:54 PM   #8 (permalink)
I went through the same thing at my lake house 8 or 9 years ago. I had the power co-op run 200 amp service for 110 feet underground a new meter and meter box ($600), and the electrician charged me another $600 to pull out the old 100 amp box and install a 200 amp box and hook back up all the existing circuits. The electrician's price included the Cutler Hammer box and all the circuit breakers he needed. I was very, very pleased to get everything done for $1200. just my .02 cents worth.
short_stuff
Y2K F250 CC PSD Auto, Short-bed Lariat, Woodland Green/Gold, ordered 07/10/99, born 09/12/99, delivered 10/08/99, Access bed cover, Bed Rug, Zoodad mod, Viper Remote Start Alarm, Fumoto valve, 103K somewhat error-free miles (so far) [never back to dealer for anything]
Repairs: CPS, Water Separator Valve assembly, rear axle bearings, VSS, batteries, brakes, alternator, serpentine belt (x2), driver door pwrlock actuator, water pump
2009 VW Tiguan 2.0 l turbo 200 hp gas engine (TDI engine not available for it yet)
short_stuff is offline
