Ya figured drilling the TC was a bad idea, just thought I'd ask. So is there a way to find out if a rav4 has a plug on the tc?
Wait, couldn't I do it the same way? Unhook the cooler lines, let one dump into a pan while pouring new fluid into the other via funnel??? I would think the car would have to be in drive?
With the shops using a machine like that do they just not change the filter?
Thanks,
-Rob
'94 F250 XLT 7.3L. Turbo Diesel 4X4 "OFF ROAD" package, X-Cab, 4.10 grears, Now a 5 speed, original IP, just did injectors,"Wallace mod" 3.5" turbo outlet housing and 3.5" DP and straight piped exhaust, 113K on the clock. Repainted it black. Ispro pyro and boost gauges, turned up pump.
Reason: combine posts
