Go Back   Diesel Forum - The Diesel Stop.com > Other Topics > Other Technical Questions
Other Technical Questions Discussion of other technical topics. Please see the sticky post at the top of the thread listing for specific rules. The rules for this forum are more restrictive than they have been in the past. Topics will expire automatically in 60 days.
Old 01-22-2008, 07:26 PM   #1 (permalink)
Silverlode's Avatar
Can you shock a cell phone battery?
Can you shock cell phone batteries back to life? I'm tired of paying as much for them as a new phone would cost!
03 F-350 6.0PSD SRW / Supercab / Short Bed / Rhino Liner / DR 3" Hanger Level Kit / DR Shocks / 18" Moto Metal 951 / BFG TA-KO 305-65-18 / Kahr K40 Elite98 in console/
NRA Life Member
Silverlode is offline
Old 01-22-2008, 10:35 PM   #2 (permalink)
I've wondered that too. I did quick shock some button batteries for the garge door opener. It gave them another month's worth of life. I think you'd have to figure out on the battery which tab is positive, and which is negative, so that you don't zap it too badly. And I would do it for just a couple of seconds or so, to see if the charge takes.
short_stuff
Y2K F250 CC PSD Auto, Short-bed Lariat, Woodland Green/Gold, ordered 07/10/99, born 09/12/99, delivered 10/08/99, Access bed cover, Bed Rug, Zoodad mod, Viper Remote Start Alarm, Fumoto valve, 103K somewhat error-free miles (so far) [never back to dealer for anything]
Repairs: CPS, Water Separator Valve assembly, rear axle bearings, VSS, batteries, brakes, alternator, serpentine belt (x2), driver door pwrlock actuator, water pump
2009 VW Tiguan 2.0 l turbo 200 hp gas engine (TDI engine not available for it yet)
short_stuff is offline
Old 01-22-2008, 10:57 PM   #3 (permalink)
Not a good idea, some battery chemistries can violently ignite. People have been badly burned. How much life are you getting out of the batteries? I have never worn one out but I don't keep phones for too long.
2000 F250 CC, PSD, Lariat, 4X4, DP Tuner 80HP PCM, AIS air filter, 4" Magnaflow SS Exhaust, Isspro Overhead Gauges, Evans Coolant, in-tank mod, homemade CCV, AIH delete, velvet-ride shackles
2004 Honda Pilot EX-L for the wifey
1992 Honda Accord LX
2003 Yamaha Kodiak 450
2002 Yard Machines 22" Mower
"Extremism in the defense of liberty is no vice. And moderation in the pursuit of justice is no virtue." - Barry Goldwater
"They that can give up essential liberty to obtain a little temporary safety
deserve neither liberty nor safety." Benjamin Franklin
"What you want is irrelevant, what you have choosen is at hand." - Mr. Spock
RenoF250 is offline
Old 01-22-2008, 11:40 PM   #4 (permalink)
My Photos: (9)
It is true, that the lithium batteries used in most cell phones have a propensity to explode. Zapping batteries is for older ni-cads that worked specifically because of the way their chemistry works.
Birken
Birken Vogt is offline
Old 01-23-2008, 08:36 AM   #5 (permalink)
Birken is right. Look at all of the laptop batteries that caught fire under normal use. Last thing I would want is my cell catching fire in my pocket or on the counter while I was sleeping.
I have had cell phones like most since they came out and have never had a battery go bad and tend to keep them for 2 - 3 years.
But recently had to replace the one in my sons Verizon Krazer after 7 months because it swelled up and would only stay charged for a few hours.
The kid in the Verizon was "nice enough" to pro-rate it down to $32.
2OOO F-250 4WD Crew Cab, 223,000K miles, replaced brakes, #1 injector/harness, Starter Relay,CPS(twice), GPR, VSS, S-Belt, Alternator. AIS Severe Duty Filter, Switched 10K MOD, Bilsteins, Heater shutoff valve, Rotella T, Nitto TG's 305/55 on Eagle 20x10's, Mobil 1 ATF,Walker BTM, Optima Redtops,Mesa, Arizona
PRDATR is offline
Old 01-23-2008, 08:55 AM   #6 (permalink)
Silverlode's Avatar
I have had five phones in my life. Three of them now I would have kept but the batteries don't stay charged (two Motorolas one LG) after a couple of years and it ends up being cheaper getting a new phone than buying a new battery (although I haven't looked around online). Oh well, just wondering if there was an easy fix. Don't want any fires or explosions. Thanks for the help.
NRA Life Member
Old 01-23-2008, 09:01 AM   #7 (permalink)
MarkEkberg's Avatar
My Photos: (13)
Batteries have a life span. Unless you have the equipment to take it apart, get rid of all the growth which shorts it internally and put it back together I thing your out of luck.
Check e-bay I am betting you can get some serious deals from there.
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
MarkEkberg is offline
Old 01-23-2008, 09:17 AM   #8 (permalink)
spg
Try the cellphoneshop.net web site
2001 International 4700LP T444E 210HP Allison AT545 3.38
spg is offline
Old 01-23-2008, 10:46 AM   #9 (permalink)
My Photos: (6)
Agree on the cellphoneshop.net recommendation.
2004 F350 SRW Lariat CC LWB FX4 6.0 6spd 3.73 LS, weighs #8040 wet 73,314.4 miles as of 10/10/08 PICS
2005 F350 C&C CC 4WD XLT PSD Auto 3.73 open rear. Custom/home made body.
2000 F350 SC C&C XLT 6 spd PSD 4.11 rear. SOLD @80K
1995 F250 XLT PSD SC Auto. 3.55 rear end. SOLD @ 149K
DieselDennis is offline
Old 01-23-2008, 12:35 PM   #10 (permalink)
Shocking a single nickel-cadmium cell (NOT a multi-cell battery) is effective because Ni-Cd batteries form semi-conductive dendrites. (resistive filaments that "grow" from one plate to the other through the electrolyte separator and create an internal discharge path. Shocking cells destroys dendrites by burning them out, like fuse wires.
I don't know whether lithium cells form dendrites or not. If they don't, shocking them won't have much effect.
If you use a controlled amount of energy - say, by using a charged capacitor to provide the juice - the risk of ignition should be reasonably low.
But once lithium does ignite, it's a special hazard. Burning metals often react violently with water instead of extinguishing, dry-chemical extinguishers aren't effective, and CO2/Halon* extinguishers don't prevent re-ignition. You'll need a Class D extinguisher or a large quantity of dry, chemically-inert sand to smother and cool.
And to make life more interesting, lithium (along with sodium and potassium) is a Group I alkali metal which forms highly-corrosive lithium hydroxide when exposed to moisture.
*Yeah, yeah, I know they don't really contain Halon(tm) anymore. But everybody knows the name.
Douglas Campbell
November 5, 2008: The fat lady sang. Back to actually working for a living.
1986 Isuzu P'up, 177,673.8 miles. Hella headlights, (highly recommended) DOT C-2 back end. (also recommended) R-12 air conditioner converted to R-406a. 4.1:1 rear axle converted to 3.4:1.
9/22/2007, age 21: Still running well when reluctantly sent away for reincarnation due to rust.
Not affiliated with the Campbell Soup Company.
drcampbell is offline
Old 01-23-2008, 09:55 PM   #11 (permalink)
But once lithium does ignite, it's a special hazard. Burning metals often react violently with water instead of extinguishing, dry-chemical extinguishers aren't effective, and CO2/Halon* extinguishers don't prevent re-ignition. You'll need a Class D extinguisher or a large quantitys. you mean like getting magnesium to ignite???? and when it does----yehahahaaaaaa
94_turbo is offline
Old 01-23-2008, 10:26 PM   #12 (permalink)
My Photos: (33)
Mine do! wouldnt have it any other way.
1994 7.3 I.D.I. Navistar 444 CI
ATS Factory TURBO E4OD Red On white Crew Cab DRW 4:10 w/ AUBURN LIMITED SLIP
3" ATS Exhaust and turbo housing, Banks Trans Command, calibrated pump, K&N filter, Gruss style coolant filter, 203K+MI not a lick of trouble with the motor. now on 16th trans. 10 under factory 100K mile warranty
Alpine CVA-7878 XM radio 6cd changer 3 8" phoenix gold subs 75x4 Sony mobile ES gold 4ch amp, Sony 500W 1ch amp MB quart components in Q forms kick panels. 1 farad cap.
Pro car parts jewel cut headlamps and turn signals
APC clear cab markers, suvlights.com harness silverstar bulbs and L.E.D.'s in the fenders. IT's paid for and its MINE!
Family Toys and tools,
00'F350 psd CC Drw 2wd Bright Amber Western Hauler
SOLD 01' Peterbilt 330 4Dr. Texas trucks conversion cAt 350hp
02' Psd Excursion Limited ultimate Estate Green helliwig swaybar 101K miles
1996 fetherlite 4 horse GN, 2003 sooner 6 horse GN with midtack
Dualie is offline
Old 01-23-2008, 10:53 PM   #13 (permalink)
Originally Posted by 94_turbo View Post
You mean like getting magnesium to ignite???? and when it does----yehahahaaaaaa
Yeah, sort of like that. Except that lithium ignites more easily and magnesium doesn't form a corrosive alkali.
On the other hand, there isn't a great amount of lithium in a phone battery. It'll be intense, but it'll also be short lived.
Douglas Campbell
Old 01-25-2008, 01:31 AM   #14 (permalink)
Kanman's Avatar
eBay $10 including shipping for a new cell phone battery. They last a couple of years and die, chunk it and go get you a new one for that price...
01 F350 dually 4x4 CC auto.
311 hp 610 torque a while back.
My Pickup
Some Photos and Sound Clips
Diesel Power & Performance Derby Ks.
#46
Kanman is offline
Old 02-03-2008, 12:12 AM   #15 (permalink)
My Photos: (12)
Quit using your car chargers and your batteries will last forever!!!! I have an LG 8300 that is 2 years old with over 2000 hours on the original battery and it has NEVER had a car charger plugged into it. I use a house charger with an inverter in the truck if i need charged throughout the day but most of the time i unplug it at 5:30 am and plug it in at 10:00 pm and the battery lasts all day. I don't plug it in on Friday as i don't get work calls on the weekend and i'll let it get really low, then plug it in saturday night.
05 Expedition 5.4 3 valve. (It does better in the mileage catagory on the interstate than my 6.0 EVER did!!!!)
GONE!!!!!!2003 F250 CC 4x4 <font color="red"> 6.0 PSD</font> 6 Speed, 3.73 XLT Dark Shadow Gray ,Moonroof, Camper Package, Skid plates ect. (Gutless PIG from idle to 1800) May 12th 03 build week. 122,000 miles as of 01/01/07......... 4" exhaust and AFE intake b&w turnover ball.
Flashed 6 times, EGR cooler replaced, VVRT solenoid replaced, Turbo Ped Replaced, EGR valve replaced 2X NO LEAKS!!! 8 new injectors, new fuel pump, new FICM, new ball joints, Exaust manifold gaskets, both front wheel bearing assy's, The list goes on and on!!!
Former trucks:
89 F250 2wd 7.3 5spd with 256K when sold
94 F250 4X4 IDI Turbo 7.3 5 spd 160K when sold
95 F250 S/C 4x4 PSD 5 spd with 146K when sold
00 F250 C/C 4X4 PSD 6 Spd with 126K when sold (160K now)
None of these trucks EVER spent a day in the shop!!!!
mjstef is offline
Similar Threads
Cell Phone through the Stereo??? catguy3 Upgrades and Aftermarket - General 13 11-29-2006 09:45 AM
Anyone know what the cell phone harness does? cturrisi Power Stroke Excursions 3 11-19-2004 10:02 PM
wire cell phone cliebold Power Stroke Excursions 1 09-10-2001 06:40 PM
Cell Phone location pmichael Power Stroke Excursions 5 08-18-2000 10:54 AM
