CB Tuning Question - help! - Diesel Forum - TheDieselStop.com
Old 11-15-2008, 07:32 PM   #1 (permalink)
Question CB Tuning Question - help!
Hey there, I have a question for y'all. I have a cobra 29 cb, its stock and a fiberglass antenna on the bed. I have a chevy silverado and The mount is on the Aluminum cargo management system which is mounted to the bed behind the left corner of the cab, the antenna is 8 inches from cab and its 3 ft long. It comes about 6 inches above the cab itself. I have an swr of 3 and a little higher. It is higher on 1 but only by a little bit. I tried to run a ground wire 12gauge to a couple different points under the hood and it did nothing. Help please.
Joe from NE PA
z71chev is offline
Old 11-15-2008, 08:24 PM   #2 (permalink)
My Photos: (60)
1) Ground your antenna - the cargo management system may or may not have a good ground to the body. You want to run your ground wire from the mount bracket on the antenna to a good body ground.
2) I would look for a taller antenna. 6 inches above the cab is not very much. Higher is better, closer to the center of the truck is better.
I have had good luck with the Francis antennas since I came across them 15 years or so ago.
Dave / Believer45
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
LINK TO LIST OF THE FALLEN
'95 F250 ext cab long bed, PSD, 5 speed, 2 wheel drive, 3.55 gears, 286,000 miles, Edge Evolution CTS (LINK TO MY REVIEW), LUK clutch, homemade REAR BUMPER, open element AIR FILTER, 36" ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
Believer45 is offline
Old 11-15-2008, 08:37 PM   #3 (permalink)
OT
OT's Avatar
Z71..maybe others will chime in cause I'm rusty..meantime JMO...
You need longer/swr adjustable antenna..2/3 should be above cab top. You can tune fglas BUT its tricky/time consuming & require's various parts.
Move mount to good metal contact. You might need diff. type depending on where you put it..ready made or make your on. I assume coax is ok & around 18' long for starters. Good luck!
03 F250 XLT SC/SB 4X4 6L (stock) A/T. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
Old 11-15-2008, 08:49 PM   #4 (permalink)
So ground from the mount to the chassis. I tried to use a 12 ga wire and ground it to a couple different bolts under the hood and nothing...what gives?
z71chev is offline
Old 11-15-2008, 09:24 PM   #5 (permalink)
My Photos: (60)
Most likely antenna location. Not high enough above the cab.
Dave / Believer45
Old 11-15-2008, 09:26 PM   #6 (permalink)
oh and my coax is 18 ft. I had to put a coupler in the middle and add 12 ft to the 6 that was on there already. Its not looped.
z71chev is offline
Old 11-15-2008, 09:58 PM   #7 (permalink)
CDX825's Avatar
My Photos: (11)
Send a message via AIM to CDX825 Send a message via Yahoo to CDX825
Your antenna should be 2/3s above the cab as mentioned before. Thats probably the biggest problem your having. Also ground wires must be kept short as possible. Try a longer antenna. I would recommend a fire stik 2. I have had good luck tuning them to all sorts of things that should have never worked. Once tunned one to an upside down filling cabinet drawer on my friends roof. We managed to get a 1:3 SWR on it. He was not able to have a big base antenna so it worked pretty good.
-Justin
1984 F250 6.9 C6 2WD Push Button Wellman GPs, No Soup bowl. Wix 33439 Water Separator, Carter P4594 fuel pump, Custom 3" Exhaust, NTZ Oil Bypass Filter, VDO Vision water temp gauge, ISSPRO EV Pyro
http://photobucket.com/CDX825
CDX825 is offline
Old 11-15-2008, 10:31 PM   #8 (permalink)
So ya think im getting a good enough ground on the aluminium which is attached to the bed? Because when I attached a ground to misc. bolts nothing changed. I bet I need a longer antenna. Any other thoughts??
z71chev is offline
Old 11-16-2008, 11:52 AM   #9 (permalink)
My Photos: (60)
All three who have responded suggested a longer antenna or move yours so it is above the cab. I would start there.
Old 11-16-2008, 04:11 PM   #10 (permalink)
In addition to the ground, you need a ground plane.... not just a cargo management system AKA Roof Rack.... the footprint of it is not large enough. Think square feet not square inches in area. An RF ground is not the same as an Electrical ground. RF does funny things and does not follow the same properties as DC or AC power. 30+ years in component level RF technology.
2008 F-450 Lariat loaded on order 7/3/07 delivered 9/13/2007 Pueblo Gold and all the goodies except Nav radio and moonroof and Fisher 8'6" X-blade
2005
F-350 Lariat LOADED CC SRW LB 6.0 SOLD
Med. Wedgewood Blue
All Options except moon roof
8'6" Fisher X-blade SS
2003 PSD 6.0 Lariat CC SB SOLD
All options but the moon roof
Scottb NY is offline
Old 11-16-2008, 04:47 PM   #11 (permalink)
the cargo management system are rails on the bed of the truck on the inside. Its for tie downs. Just to clarify
z71chev is offline
Old 11-16-2008, 05:19 PM   #12 (permalink)
Band_Member's Avatar
My Photos: (63)
The metal truck body is the ground. if the base of your antenna is located below the highest point of your truck (ground) it isn't going to radiate properly. Locate the base of your antenna at the highest point of your truck. the best is to drill a hole in the roof of the cab and mount it that way.
2005 F250 XLT SC, LB
6.0 Torqueshift
3.73LS 4x4 ESOF
A/C, T/C, Upfitters
Truck Build: 02/05/05 Kentucky
Engine Build: 02/03/05 Indianapolis
1910 Hrs, 75K Miles - No Major Problems
ZOODAD, SEIC Mods
4" Banks Turbo-Back Duals
3.5" Ready Lift
Bilstein 5100's
315 - 70R17 Goodyear Duratrac's
Boss 4" Wheel to Wheel S/S Nerf Bars
Bodiak Front Receiver
ScanGauge 2 w/Blend Mount
New Motorcraft 850CCA's @ 67K
Coolant Bypass Filter
HFCM Plug Upgrade
Blue Spring Fuel Pressure Upgrade
GlowShift FP Gauge/Strictly Diesel Adaptor
Zerex Red ELC
2 Stroke TC-3W Oil added 1oz/Gallon Fuel
~driver like ya stole er~
Band_Member is offline
Old 11-16-2008, 09:18 PM   #13 (permalink)
OT
OT's Avatar
Band..brings back old memories. I certainly agree..mount on top of roof. Best set up was my old E150 van. 5/8 Drilled/mounted top dead center of roof..great send/rec.
But, you don't need to drill thru cab roof to get good results. Current ride I use mag. mount on top/center of cab. If carrying boat, I move mag. over to side of carrier. Both ways I get very low swr's. Using adjustable one's..even both my francis give real low swr's.
2/3 of antenna above cab. is what I found worked best for me when I had mount on bed rail (behind cab) I figured out how long mount needed to be to get my 6ft francis 2/3 above cab roof. Surprising at time..got really low swr's with no adjustments. I did use string to cab (lense screw) to keep it more vertical OTR. Used with mag. on cab top (while stopped) really increased send/rec. So...
Would imagine Z71 has the idea by now.
OT is offline
Old 11-17-2008, 06:42 PM   #14 (permalink)
thank you all for the great info and reply's.
z71chev is offline
Old 11-17-2008, 07:44 PM   #15 (permalink)
VCRacing's Avatar
Make sure the radio is grounded properly also
Ya'll buckle up and pull them belts tight, its gonna get rough..
Mine :01 F-350 CrewCab Lariat 4x4, 7.3 PowerStroke, auto, ShortBox. Mods: 3-Gauage A-pillar W/ Autometer Lunar Guages: boost,pyro,trans; DIY Tymar, Muffler Delete, Galaxy DX-33 Radio W/ Wilson 1000, and Optima RED TOP's, Centramatics, Lund Soft Tonneau
Play:
'82 Ford Bronco 302, auto, Galaxy 33v, Wilson 1000
04 Yamaha G22 E , Jake's Long travel lift kit, Fairway Alloy "Hazard " wheels , 23" EFX Blade tires, Jake's SST Safari Bar and Rear Tube bumper.
Color : PPG Orange Crush Pearl w/ Hi- Gloss Black trim ....
Hers: 00 Pontiac Trans Am, (stock)LS1, auto, T-tops.
VCRacing is offline
