cold galvanizing - Diesel Forum - TheDieselStop.com
Old 12-31-2007, 12:14 PM   #1 (permalink)
cold galvanizing
Looking into galvanizing the outside of a gas tank before it goes back onto a Landcruiser. Has anybody ever used cold galvanizing where you buy stuff in a gallon or arasol can? Does this work well? Any recomendations on what to use?
Thanks,
-Rob
'94 F250 XLT 7.3L. Turbo Diesel 4X4 "OFF ROAD" package, X-Cab, 4.10 grears, Now a 5 speed, original IP, just did injectors,"Wallace mod" 3.5" turbo outlet housing and 3.5" DP and straight piped exhaust, 113K on the clock. Repainted it black. Ispro pyro and boost gauges, turned up pump.
ClassicFordGuy is offline
Old 12-31-2007, 12:23 PM   #2 (permalink)
GEARJAMMER's Avatar
My Photos: (10)
Re: cold galvanizing
This is good stuff! <span style="color: #6633FF">CLICK HERE!</span> [img]/forums/images/%%GRAEMLIN_URL%%/cool.gif[/img]
Shawn
2008 F-450 JOB-1, 4 X 4 with 4.30's, auto with manual transfer case with factory cup holders. All options except sunroof and nav. Line X with Extra. 24K Draw-Tite Signature Series Fifth Wheel Hitch. 65 Gallon KSH Marine fuel/tool combo in bed. Viair 480C compressor with 8 gallon tank. Hadley Air Horns hooked up to Auto Mate alarm. Chime/Light Killer Mod. Polished Job-1 exhaust tips. Transmission upgraded to JOB-2 filter, pan, and lines. External filter eliminated.
PICTURES
GEARJAMMER is offline
Old 12-31-2007, 03:55 PM   #3 (permalink)
Band_Member's Avatar
My Photos: (63)
How about getting Rhino Liner applied to it ?
2005 F250 XLT SC, LB
6.0 Torqueshift
3.73LS 4x4 ESOF
A/C, T/C, Upfitters
Truck Build: 02/05/05 Kentucky
Engine Build: 02/03/05 Indianapolis
1910 Hrs, 75K Miles - No Major Problems
ZOODAD, SEIC Mods
4" Banks Turbo-Back Duals
3.5" Ready Lift
Bilstein 5100's
315 - 70R17 Goodyear Duratrac's
Boss 4" Wheel to Wheel S/S Nerf Bars
Bodiak Front Receiver
ScanGauge 2 w/Blend Mount
New Motorcraft 850CCA's @ 67K
Coolant Bypass Filter
HFCM Plug Upgrade
Blue Spring Fuel Pressure Upgrade
GlowShift FP Gauge/Strictly Diesel Adaptor
Zerex Red ELC
2 Stroke TC-3W Oil added 1oz/Gallon Fuel
~driver like ya stole er~
Band_Member is offline
Old 12-31-2007, 06:22 PM   #4 (permalink)
My Photos: (33)
If your dead set on cold galvanizing forget trying to spray it in a gun from a gallon can.
If you must use the cold galvanizing use the spray cans. Before use put them in a bucket of hot water for 15 min for the contents of the can to warm up then SHAKE THE HECK OUT THEM! put them back in the bucket for another 5 min then shake again and use.
if its too cold the cold galv will plug the nozzle up in no time flat. My shop goes through 5-10 cases of cold galv a month.
00'F350 psd CC Drw 2wd Bright Amber Western Hauler, exhaust brake transfer flow 50 gal tank tool, 30K Cody goose neck hitch, hawk pads, cryo'ed rotors, stainless lines, 380,000 miles
02' Psd Excursion Limited ultimate Estate Green 7.3L Auto 2x4 hellwig swaybars and rancho 9000's. 381,000 miles.
1993 F-superduty (F-450) 7.3L Gutless non turbo 2x4 Auto, Tire eating S.O.B. 12,750lbs 80,000miles lincoln Vantage 500 Duetz bolted in the back.
1994 7.3 I.D.I.T. factory turbo, auto 2x4 DRW with lots of upgrades, 11 transmissions under 100K factory warranty. 280,000 miles Currently Cavitated and parked.
96 F-800 24'flat 5.9L cummins, 4spd allison juice brakes.
89 F-800 6.6L 5+2 27,00lbs light weight with National 556A crane behind the cab.
2006 T800 KW 550 C-15 18spd 22K front, 52K rears murray ramps, 195" W.B. CA spec heavy haul SOLD
2006 Murray 16 tire professional lowbed SOLD
1996 fetherlite 4 horse GN, Walton 18' 14K tag tilt equipment trailer.
Dualie is offline
Old 01-01-2008, 06:06 PM   #5 (permalink)
I like the rhino liner idea. If you do use the cold galv. spray, it is <u>all</u> in the prep.
1996 F250 4x4 ext. cab, long bed 5 spd. 3.55ls, Tymar Intake, Tymar 4" downpipe and 4" exhaust. AIC, B&W turnoverball, EBPV brake, tranny temp gauge, boost gauge, and egt gauge. 2.5" axle drop bracket, F350 springs up front, and F350 rear axle blocks. 260k miles. RETIRED.
NEW (to me) 2005 F350 FX4 Crewcab shortbed, SRW, Lariat, auto, V10. 5600 lbs front end.
NickKent is offline
Old 01-02-2008, 01:24 PM   #6 (permalink)
Rhino liner is the other option, the cold galvanizing would give the gas tank a stock look I'm going for. Dualie, what is the stuff you guys use exaclty? Can I get it localy or on the internet?
Thanks,
-Rob
Old 01-02-2008, 02:51 PM   #7 (permalink)
Company I used to work for used a stainless steel paint called "Steel It", used 304 SS powder instead of alum. powder like in alum. paint. I painted the battery tray in My old '87 F-150 with it when I replaced the battery and it was starting to rust. Hit it with a wire cub brush on My 4-1/2" angle grinder and sprayed it down. Also painted the wheel for the spare tire on My F-250 that hung under the back fuel tank for 12 yrs and over 250,000 miles. Wheel didn't rust either. Good Stuff!
Denny
'96 F-250 Reg. Cab 4X4 5-sp POWERSTROKE
298,500 mi & NO Problems, LUK Clutch
Dr.Evil is offline
Old 01-02-2008, 04:53 PM   #8 (permalink)
Rob,
Hands down the best cold galvanizing I've ever used is ZRC http://www.zrcworldwide.com . It's the only cold galvanizing compound that I know of that's recognized by UL as equilivent to hot dip galvanizing. The key to getting the full benefit of the compound is to get the steel very clean, i.e., sandblasted. ZRC makes two different compounds, that differ in appearance only. Galvalite is the lighter gray version commonly used to touch-up fresh galvanizing, and the original ZRC is a darker gray color. I've used both and they work equally well. The really cool thing about ZRC cold galvanizing compound is that it offers true cathodic protection, and will keep steel from rusting even if the coating is scratched through.
Hope it helps,
K.N.
3/94' F-250XL 4x4,PowerStroke Diesel power, DP-tuner flashed to MLE1, H.D ZF 5-Spd. w/SBC Con-O clutch, Std. cab, 3.55, Mobil 1 syn. in T-case, Castrol TranSynd in tranny, Chevron's DELO 400 & Fleetrite Anti-Foam Additive, Valvoline's Durablend 85w-140 in rear, LT265-75R-16 Mickey Thompson Baja ATZs, 339,000 miles, Tymar Intake, TS 6-pos chip, Banks 3" 409 Stainless Downpipe, S.D. 409 Stainless Cat Delete, Hidden Hitch, Stock
http://community.webshots.com/user/kn94psd
K.N.94PSD is offline
Old 01-02-2008, 05:42 PM   #9 (permalink)
My Photos: (14)
I am in the business of selling hot dip galv fitting,flanges,pipe, etc.
When it is necessary to tough up a HDG job, I use a product called Brite Zinc, from Brite Products. It is not cheap, but it is the best I have found.
current trucks -
2003 dodge dually 4 door 4x4 6spd HO cummins straight pipe - baldwin pa2820 HUGE filter
2003 f550 11 flatbed, 6.0, 6spd, 19,000gvw, vac/had brakes
2004 f550 11 flatbed, 6.0, 6spd, 19,000gvw, vac/hyd brakes
previous truck - 1995 F-350 cc srw 4x4 5spd
CCOUGHRAN is offline
Old 01-03-2008, 02:02 AM   #10 (permalink)
My Photos: (33)
I have used both products mentioned above and they both work well.
I'm out of town right now so I cant get the name of the stuff im getting from my local welding gas supplier. Its a good value product but the two mentioned above offer better protection
Dualie is offline
