Other Technical QuestionsDiscussion of other technical topics. Please see the sticky post at the top of the thread listing for specific rules. The rules for this forum are more restrictive than they have been in the past.
Unfortunately I don't own a garage right now. Fortunately I own two cars, one truck, four motorcycles, boat trailer and five bicycles. That means I need to keep alot of tires aired up properly.
I have a Craftsman 30 gallon compressor in the basement and on occassion will take it up the basement stairs and outside and 'make the rounds' but this is getting old. The thing weighs 200 pounds and doesn't like going up or down stairs.
So what I imagined would be cool is a jack or receptacle like an electrical socket outside on the front of the house that I could just plug my hose into and it would be long enough to reach all the vehicles. Has anyone done this? I could get a rubber hose fished in the wall but I don't know where to get a plate for what I'm talking about. -Jason
2000 F250 CC Lariat PSD Auto 4X4, Hutched tank and prepump, turn signal mod, heater control valve mod, Firestone ride rite's, Tork-Lifts tie downs, Crime stopper auto start/idle down/alarm, hidden hitch front mount receiver. and the list is growing!
A truck shop or even a good plumbing shop should have "Bulkhead Fittings", that are like a pipe coupler with nut threads on the outside. I've used them before in boxes and plates with conduit holes with pretty good success - as far as making a nice covered one, though, you might have to dream something up - like an electrical switchbox, or something of the sort. I'd go wander around in Home Depot for ideas. On the shop at work, we just have the couplers run through the wall on black pipe, fastened really solid with conduit clamps on the inside, and then 45'd down on the exterior side to keep the junk drained out of the coupler. Most of the couplers are well over 10 years old, and most of them still seal up really tight.
Take a male quick disconnect and screw it in thru the wall or plate into a pipe coupling . Hook your air supply into the coupling, same as a bulkhead fitting, 1/4" - 3/8" pipe or whatever size air hose you use. May have to use a washer between coupling and disconnect for spacing.
You could get real fancy and install a male quick disconnect permanently on the outside of the house. Run you hose through the wall and down to your compressor for a quick connect/disconnect at the source. I would also recommend installing a hood (maybe a faucet cover) over the disconnect on the outside of the wall to keep wasps from building dirt dobber nests in it. Or, see what short vinyl plugs they have that would fit in the male quick disconnect. just my .02 cents worth
short_stuff
Y2K F250 CC PSD Auto, Short-bed Lariat, Woodland Green/Gold, ordered 07/10/99, born 09/12/99, delivered 10/08/99, Access bed cover, Bed Rug, Zoodad mod, Viper Remote Start Alarm, Fumoto valve, 103K somewhat error-free miles (so far) [never back to dealer for anything]
Repairs: CPS, Water Separator Valve assembly, rear axle bearings, VSS, batteries, brakes, alternator, serpentine belt (x2), driver door pwrlock actuator, water pump
2009 VW Tiguan 2.0 l turbo 200 hp gas engine (TDI engine not available for it yet)
Jim Sult / Excavator (we dig it) Trying to fix it? KISS IT"KEEP IT SIMPLE STUPID" Avatar- purchased off Ford lot as NON RUNNING ENGINE - I drove it off lot in 1 hour/ my everyday 1996 F250 XLT Ext Cab, Powerstroke, 4x4 Dana 60 , Bilsteins shocks, Greggs MB AutoTrans, BabySwamps,Tony Wildman Chip, AutoMeter Pyro/Trans/Boost, Tymar intake, MBRP 4 in turbo back exhaust, 209000 miles,D&B HT Starter
1996 F350 XL PowerStroke 4X4 DRW, Auto Trans, Stock Work Dump truck, DDP down pipe,Tymar intake, 113000 miles
1997 F350 XL 2x4 DRW Powerstroke , DP Tuner PCM, 5 speed,Luk Clutch Tymar intake. DPP downpipe, 185,000 miles
