Other Technical QuestionsDiscussion of other technical topics. Please see the sticky post at the top of the thread listing for specific rules. The rules for this forum are more restrictive than they have been in the past. Topics will expire automatically in 60 days.
my wife and i carry Smith and wesson Mod. 640. Small frame 357 mag. can handle +p ammo, no hammer spur, 5 shot, SST, very compact and realiable. Both are loaded w/ Federal 357 hydro shok Personal defense ammo.
Mine :01 F-350 CrewCab Lariat 4x4, 7.3 PowerStroke, auto, ShortBox. Mods: 3-Gauage A-pillar W/ Autometer Lunar Guages<boost,pyro,trans> Galaxy DX-33 Radio W/ MonkeyMade steel whip, and Optima RED TOP batts.
I prefer a S&W revolver, they never jam, and they do not spill brass on the ground. In a hurry, you may forget one behind, god forbid. .357 is the caliber to have, magnums with hollow point will do the job and more.
If I was buying a new CC gun today, it would be the Springfield Armory XD40 SubCompact High Capacity (XD SC HC).
More than enough power.
High capacity
23oz (unloaded)
Built in accessory rail
Lifetime warranty
Etc, Etc, Etc.
If you are not familiar with Gun Tests magazine, they review all sorts of guns and compare them to comperable brands and models. They don't take any advertising (so you can't accuse them of letting $$$ sway their opinions) and they test guns off the rack from gunshops, rather than one that a manufacturer may have "tuned up" a little before it was tested.
That being said, they recently gave the afformentioned pistol an A+ rating, which is highly unusual. In fact, I can't remember them stating a single negative regarding it which is unusual as well.
03 F-350 6.0PSD SRW / Supercab / Short Bed / Rhino Liner / DR 3" Hanger Level Kit / DR Shocks / 18" Moto Metal 951 / BFG TA-KO 305-65-18 / Kahr K40 Elite98 in console/
There's a big pawn and gun there in Daytona, look around in there for something that fits your hand and that you like. ANY handgun is going to need maintaince, SS included. sweat is just as bad or worse than salt water. Marine supply houses sell a product called Boshield T-9. it was developed to stop rust and corrosion on aircraft parts. good product to wipe down firearm with, inside and out after cleaning. As far as calibers, the biggest one you can shoot accurately. Around the house , I keep a kahr MK40 w.N/S in my pocket. When I go anywhere, I carry that and a Sig 245 w.N/S. Both are loaded with Winchester L.E. SXT, 180 gr. JHP in the .40, 230 JHP in the .45. Always have a tactical re-load somewhere close (spare loaded magazine).It's good you decided to take responsibility for your and your family's safety. you owe it to them and yourself to practice regulary and become profecient. The more confidence you gain, the less likely you are to use it unless you absolutely have to. Always buy the best you can possibly afford, this is NOT the area to try and get by cheap. S&W also offer a line of M&P polymer pistols in .40 and a lifetime warranty.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: MaxRules</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: texrob1</div><div class="ubbcode-body">I have a Kahr PM9 In 9mm,they also make one in .40 Cal, VERY Concealeable! http://www.kahr.com</div></div>
I'll second the Kahr, I carry a CW9. It's the 9mm model. The thin profile makes it easy to conceal and it's very reliable and fun to shoot. Otherwise, go with the Glock if it conceals for you (too thick for me). </div></div>I have the same problem as you ,the Glock is too thick for me also,I have a Model 32 (.357 Sig) very nice handgun,although not as concealable as the Kahr.
__________________ 2005 F250 XLT wedgewood blue 4x4 C/C SWB,6.0L PSD, Auto.(Member of 05 STC Failure Club ) 2006 Expedition Eddie Bauer,5.4L (Wife's) NRA Life Member. TSRA Life member.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: DieselJambalaya</div><div class="ubbcode-body">Whichever semi-auto pistol you decide on, just make sure that the caliber you choose starts with a 4. (ex: .40 cal, .45 cal)
Or if you go with a revolver, just make sure that the caliber you choose starts with at least a 3. (ex: .38, .357)
.380, 9mm are too small in my opinion. I'm not taking any chances, and neither should you.
Oh, and I believe you can also feed .38 ammunition through a .357, but not vice versa. </div></div>You are correct,you can fire .38 in a .357,but the case is too long on a .357 round to accidentally fit in a .38,you can also shoot .44 Special in a .44 mag Etc.
The Kahr PM9 is the smallest 9mm I have found that is good to carry everyday. ANtyhing else has a fat grip or sticks out here or there. It is full 9mm +p powered and fits in the palm of your hand weighs about a pound. Glocks are best for a dirty environment they fire no matter what but they are all larger.
2005 F250 FX4 SuperCab SWB in DSG
Buckstop rear bumper American steel!
Daystar baja bar with PIAA Racing 80's
Quad pillar Air, trans temp, pyro, boost
Magnaflow 15954, ATS studs
Transfer Flow 46gal midship tank
Firestone Airbags 2400 kit ViAir 250C compressor
Eaton TruTrac, Rancho 9000's, Skyjacker 1.5" rings
ViAir 380C@200psi, 5gal tank, Siege Anvil train horns say move *****!
The Springfield Armory XD 40 subcompact is my weapon of choice.
2002 F250 CC 4x4 Lariat (SRW),
20" KMC Monsters,
37" Toyo M/T's
8" Full Spring Skyjacker
4in Turbo Back (no muffler)
Some kind of programmer/chip?,
RanchHand Frt/Rear,
AFE Stage 2 intake,
Banks Intercooler Pipes,
DieselSite Boots
New tranny(30K),
Banks TransCommand,
Mag Hytec Tranny Pan & Diff Cover,
Quad A-pillar(ISSPRO trans,boost,pyro,water)
About to be DynaTrac'd
My heart belongs to the Mustang and Windsor Motor, so you;ll have to forgive me until I get up to speed with thesee diesels
Go find an indoor range that rents guns. Try anything that YOU like the feel of. Then go to another range & do it again. When you find something that YOU are comfortable with, BUY IT.
Everybody here means well but a personal defense handgun is just that... PERSONAL.
Once you find something you like, take some classes too.
97 F250 SC LB 4X4 PSD TDE0, E4OD,3.55's, 285/70/16"s ,Modified fuel tank vents, 375+k headed for 500k
You guys have some big pockets if you can fit some of those guns in them. As far as a pocket gun I opt for a P32 or P3AT. I own a P32 and its a great gun. It is small, light, functions perfectly, accruate enough. It isnt very pretty but it works for me. I know a lot of people think the 32 is too small but 7 32's in the gut would make anyone think twice. If your still worried get a P3AT its a .380.
Sold, 97 F250 Supercab back to the 85 S10 and loving it.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Leader</div><div class="ubbcode-body">Go find an indoor range that rents guns. Try anything that YOU like the feel of. Then go to another range & do it again. When you find something that YOU are comfortable with, BUY IT.
Once you find something you like, take some classes too. </div></div>
