Construction Help - Diesel Forum - TheDieselStop.com
Old 12-06-2007, 11:39 PM   #1 (permalink)
Silverlode's Avatar
Construction Help
I want to build an enclosed shed under my deck. I am pouring a concrete slab and then constructing on top of that. I haven't quite decided the best way to address the roof however.
I have seen a product called Underdeck that looks like it might work pretty well, but it is really expensive. I don't have a lot of extra room to play around with, meaning that I would like the roof not to exceed about 6" distance from the bottom of the deck.
Anyone have any experience with this sort of thing? There has got to be a good and watertight way to approach this that isn't going to cost me $6K just for the roof. I have spoken to a few contractors and they all have gotten a look on their face like I get when I try to do calculus.
The enclosed space will be about 14'x 20' if that makes a difference.
Thanks for any suggestions.
03 F-350 6.0PSD SRW / Supercab / Short Bed / Rhino Liner / DR 3" Hanger Level Kit / DR Shocks / 18" Moto Metal 951 / BFG TA-KO 305-65-18 / Kahr K40 Elite98 in console/
NRA Life Member
Silverlode is offline
Old 12-06-2007, 11:56 PM   #2 (permalink)
88beast's Avatar
Re: Construction Help
doa slope of 2in per foot over the 14 foot part sloping down like a normal roof then pull rubberroofing (buy scraps way cheaper)
pull it over and leave a foot on the side
roll each side around a 2x2 and deck screw to building
then just leafblow off from topside each year
88 F-250 body,550 rear frame setup, 7.3 idi, back up camera, class 5 bumper hitch welded to frame and gusseted, front mount hitch and off road lights,93 front clip, headache rack, 37" humvee tires, ac power converter,factory buckets from quadcab, power windows and locks,cobra 29 cb w/ 102" whip, high lift jack behind seat, toolbox for the junk, visor, running lights, huge front bumper, oba,
in progress western style mirrors, holset turbo, airhorns, and some other goodies
88beast is offline
Old 12-07-2007, 12:11 AM   #3 (permalink)
Silverlode's Avatar
2" per foot for 14' would give me a drop of more than two feet on one side of the shed. I could probably afford a foot if I had too, but would prefer to keep it more around 6" for headroom inside. Do you think that approach would work with about 2" every 4'?
NRA Life Member
Old 12-07-2007, 12:35 AM   #4 (permalink)
Even a 2" slope per foot is not enough for regular asphalt roofing shingles. A 3 and 12 is recommended as a minimum for using that, any lower you are going to be using a material that water can not come back up under, like a commercial hot mopped roof, foam roof, or metal roof. I would go for the metal roof for sure. Just my .02
1992 F350 Crew Cab 4x4 7.3l IDI E4OD No Turbo
1993 F350 Crew Cab 4x4 7.3l IDI E4OD No Turbo
1990 F250 Super Cab 2x4 7.3l IDI E4OD Utility bed
1987 E250 Quadravan 4x4 6.9 IDI C6 Banks Turbo, Gearvendor, and U.S. Gear Exhaust Brake
DragRag is offline
Old 12-07-2007, 08:07 AM   #5 (permalink)
Band_Member's Avatar
My Photos: (63)
I don't know if this might help you some.
I built a roof (so to say) under my deck where there is a concrete patio. I wanted for us to be able to sit out there while its raining without the rain coming through the deck and dripping down on us.
I ripped strips the lenghth of the deck joists (in my case 10') out of 2x treated material figuring a 1/4" per foot pitch. Over 10' the strip went from 2 1/2" to nothing. I ripped as many as I needed for every joist above the patio. Then I predrilled the screw holes on the strips. I glued and screwed (s/s screws) the pitch strips on the underside of the joists with the 2 1/2" end away from the house.
This provided the pitch for the water to run away from the house on the top of the 1/2" treated plywood that I predrilled and screwed on next using a lot of caulking especially around the screw holes.
I'm thinking you can do the same then frame your shed walls up to it. You can also put a gutter where the water spills out and lead it away.
If anything accumulates up there (twigs, leafs, etc.) just break out a backpack leafblower and blow it off.
Just a thought. Maybe it'll work for you.
2005 F250 XLT SC, LB
6.0 Torqueshift
3.73LS 4x4 ESOF
A/C, T/C, Upfitters
Truck Build: 02/05/05 Kentucky
Engine Build: 02/03/05 Indianapolis
1910 Hrs, 75K Miles - No Major Problems
ZOODAD, SEIC Mods
4" Banks Turbo-Back Duals
3.5" Ready Lift
Bilstein 5100's
315 - 70R17 Goodyear Duratrac's
Boss 4" Wheel to Wheel S/S Nerf Bars
Bodiak Front Receiver
ScanGauge 2 w/Blend Mount
New Motorcraft 850CCA's @ 67K
Coolant Bypass Filter
HFCM Plug Upgrade
Blue Spring Fuel Pressure Upgrade
GlowShift FP Gauge/Strictly Diesel Adaptor
Zerex Red ELC
2 Stroke TC-3W Oil added 1oz/Gallon Fuel
~driver like ya stole er~
Band_Member is offline
Old 12-07-2007, 08:30 AM   #6 (permalink)
I agree with dragrag, with the slope you're trying to get, metal is the only way to go. Since it's under a deck, you won't have to worry about leaves and such. I would probably buy an aluminum pan roof system with built in gutters.
Charlie Brown, North Alabama
'97 F-350 Crew Cab, 5 speed, Dually. Pretty Stock. Traded
'07 GMC Sierra 1500 Crew Cab
hayhauler is offline
Old 12-07-2007, 10:47 AM   #7 (permalink)
With the deck above, I'd imagine the water that does make it through will be well-distributed and coming through rather "gently". I would surmise your slope could be quite minimal, especially if using metal or plastic/fiberglass roofing material. I'd make sure my house-side flashing was well-placed and sealed.
You could also "build" your roof at a workable level and then hoist it into position. Maybe even build it in sections (to make it lighter for raising), making sure the section seams overlap correctly and are well-caulked.
rtmartens is offline
Old 12-07-2007, 12:23 PM   #8 (permalink)
Silverlode's Avatar
OK, thanks for all the good replies and advice.
Would metal work better than a single sheet of a rubber type roof product stretched across plywood? I see single sheets of rubber for sale on ebay that would cover the whole area for under $500 delivered. Any idea what a metal roof would cost?
NRA Life Member
Old 12-07-2007, 01:05 PM   #9 (permalink)
About the same price depending on where you get it. Met al is good or the rubber you are speaking of. Do not use asphalt shingle with less then 3 and 12 pitch. It might keep out the water when new, but it will not last with less then that slop. I have built many houses, plus I know a good roofer, and I know that is his opinion on the matter.
DragRag is offline
Old 12-07-2007, 04:01 PM   #10 (permalink)
whitjo's Avatar
What about the translucent fiberglass panels, no need for lots of pitch and they will let light in below your deck too.
could be pricey though??
Early '99 F250 SD, 4X4, SuperCab, Long Bed, 7.3L "PowerStroke" Diesel, Auto, PMT1 PCM w/DPTuner 80 tow, 190K miles,
Volant intake, ISSPRO gauges, BDS front leveling kit, 4" straight piped, Dick Cepek 18x9 DC1-Chrome, Nitto Terra Grappler 325/65R18,
Pro GOD, Pro Guns, Pro Life Important Notice, Pro Life changes when someone breaks in.
whitjo is offline
Old 12-07-2007, 08:37 PM   #11 (permalink)
My Photos: (5)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: whitjo</div><div class="ubbcode-body">What about the translucent fiberglass panels, no need for lots of pitch and they will let light in below your deck too.
could be pricey though?? </div></div>
I used that method under the deck on my last house, I attached it from underneath using rubber washer nails like you use on pole barns.
2008 F350 Lariat CC SWB V10, Dark Blue Pearl Metalic.
SOLD!! 06 F350 lariat ,6.0 Auto, 4x4, CC, SB, Black, Moonroof, Pwr rear slider, Brake controller, 3.73LS, ESOF, Sec. group, Htd pwr TT's
If I wanted betterr MPG I'd buy one of those tiny tire, low to the ground light duty bowties.
bosspsd is offline
Old 12-07-2007, 09:52 PM   #12 (permalink)
The fiberglass will come out cheaper than the metal roof. Run it at a minimal slope and it will do just fine. I've done this on more than one deck for folks and never had a problem.
Joe
2002 F350, Crew Cab, 4WD, ISSOPRO Gauges,
3.73, Auto, 2wd low range mod, No door dinger,
Interior lights off switch, Zoodad Mod,
Extra Trans Cooler, Before coolers trans fltr,
Coolant fltr, Crimestopper remote start/alarm
Oil Guard Bypass, Air horns
MOUNTAINMAN444 is offline
Old 12-09-2007, 02:47 AM   #13 (permalink)
I think the fiberglass would work very well and last quite a while under the deck like that. I'm accustomed to using the alumninum pans, but for that application either fiberglass or "tin" should work fine.
Old 12-09-2007, 10:40 PM   #14 (permalink)
F350_6's Avatar
How much wind will your roof be subject to? The rubber type roof will work but if it will be subject to high winds you will need to "glue" it down using a bonding adhesive. The rubber roof will work on slopes down to 1/4" per foot so that won't be an issue.
The inexpensive rubber material (EPDM roofing) will not be a reinforced product so if it develops a tear it will rip open. If you decide to go this route make sure you use screws to put the plywood deck on your shed. A nail backing out will puncture the roof membrane, but may only cause a leak small enough to rot the wood where you won't notice until it's too late.
The material will be available from a local roofing distributor. It sounds like a 20' x 50' roll will give you more than you need for a single piece install. If you decide to go with a contractor tell them your interested in a single ply roof (EPDM, TPO, PVC) and see what they would charge.
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 393,000 & counting.
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
F350_6 is offline
