conversion questions - Diesel Forum - TheDieselStop.com
Old 01-01-2013, 06:06 PM   #1 (permalink)
Question conversion questions
ok so i got a 85 f250 4x4 351w that was my pulling truck but i am converting it to diesel putting a 7.3 idi or 7.3 turbo in it idk yet. what are your guys opinions and why?
My Rigs- 1985 f250 HD 2wd 6.9 idi
1985 f250 4x4 351w
kingdiesel is offline   Reply With Quote
Old 01-01-2013, 06:29 PM   #2 (permalink)
chuckster57's Avatar
Welcome to the Diesel Stop.
As long as you are bringing over the complete diesel drive train ( engine AND transmission) you should be able to do the swap with a few modifications.
Sent from my iPhone using AutoGuide.com App
Train Horns: Pictures here
PM please not visitor message
chuckster57 is offline   Reply With Quote
Old 01-01-2013, 06:41 PM   #3 (permalink)
i ment should i get 7.3 td or 7.3 idi
1985 f250 4x4 351w
Old 01-01-2013, 06:55 PM   #4 (permalink)
7.3 IDI is mechanical and doesn't need a computer to run, the Powerstroke is computer controlled.
An IDI with a turbo, and minor tweaks can make about the same power as the first gen. PSD. Since the PSD is computer controlled, you can use a performance chip or programmer for more power.
If you use the IDI, you only need power to the fuel shut off solenoid to make it run. The PSD will require the PCM and related components to run.
Old 01-01-2013, 07:39 PM   #5 (permalink)
how do u put a turbo on a idi?
1985 f250 4x4 351w
Old 01-01-2013, 07:56 PM   #6 (permalink)
There are kits available, or if you can find a used one. Ford installed turbo's as an option in '93 and '94. Mine came with a turbo. Otherwise, if you have the ability and tools, you can build a system.
Hypermax and Banks are the only ones left that make a new kit I believe. ATS did the factory turbos using a Garrett turbo, but I have read here that they sold it all off.
Old 01-01-2013, 08:36 PM   #7 (permalink)
is this the right kit? Banks Power | 83-93 Ford - 6.9 & 7.3L>>Sidewinder® Turbo System
1985 f250 4x4 351w
Old 01-01-2013, 09:27 PM   #8 (permalink)
Looks like it.
Old 01-02-2013, 01:12 PM   #9 (permalink)
i think i am going to take the 6.9 in my truck now and put it in the 4x4 truck. will the 2wd tranny attach to a transfer case or will i need to get a new tranny and a transfer case
1985 f250 4x4 351w
