Does changing Spark Plugs help? + Injector cleaner? - Diesel Forum - TheDieselStop.com
Old 12-10-2007, 08:32 AM   #1 (permalink)
holstein05's Avatar
My Photos: (5)
My wife has a 98 accord. It hasn't had new plugs put in for over 80k miles. Would changing be beneficial in anyway since the car runs fine?
Also, do the off the shelf fuel injector cleaners really help?
Thanks!
2000 F350 4x4 Dually, 4 door, 6 Spd, 155,000 miles. And completely paid for.. finally
Edge Evo , Airbag Suspension, K & N Home made Tymar, 4" exhaust, Ranch Hand Bumpers front and Back
Removed: SuperChip Gold... Want it?
holstein05 is offline
Old 12-10-2007, 09:00 AM   #2 (permalink)
MarkEkberg's Avatar
My Photos: (13)
Re: Does changing Spark Plugs help? + Injector cleaner?
New plugs will help some, but the ignitions are so good these days it will only help with things like really cold days.
I think injector cleaners do help. I like seafoam the best.
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
MarkEkberg is offline
Old 12-10-2007, 11:23 AM   #3 (permalink)
BG44K is my choice of cleaners. I put it in and run the car for a 20 miles and let it sit for a few hours rather then putting it in and driving it for a long distance letting it sit overnight will help to loosen up the carbon.
2OOO F-250 4WD Crew Cab, 248,000K miles,
Stock. Replaced #1 Injector/harness, Starter Relay,CPS(twice), GPR, VSS, S-Belt, Alternator H2O Pump. AIS Severe Duty Filter, Switched 10K MOD, Bilsteins, Heater shutoff valve, Rotella Syn, Nitto TG's 305/55 on Eagle 20x10's, Mobil 1 ATF,Walker BTM, Optima Redtops,Mesa, Arizona
PRDATR is offline
Old 12-10-2007, 11:54 AM   #4 (permalink)
Seafarer12's Avatar
I like lucas for injector cleaners. Its worked wonders on my old PSD I run it in all my cars. Changing plugs wouldnt hurt. New cars arent as picky as old ones. When my S10 needs new plugs it will let me know, missing, mpg goes down the tubes, my neon might pick up 1 mpg with new plugs but other than that I can't tell I have put new plugs in it
Massey 65
Seafarer12 is offline
Old 12-10-2007, 11:59 AM   #5 (permalink)
My Photos: (27)
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body"> Also, do the off the shelf fuel injector cleaners really help?
</div></div>
I can't say about nowdays, but the engine reps from the big three only advised and recommended using Chevron Techron (or a spelling similar) some years back. In fact Ford or GM had a service bulletin saying to run a bottle through at a certain mileage interval.
'91 F-250 SC 4X4, 5spd. ATS Turbo http://sports.webshots.com/album/180135797kNEIOu
LMJD is offline
Old 12-10-2007, 03:48 PM   #6 (permalink)
Thing I'd be most worried about is the OEM plugs being siezed in the head. Some places they don't anti-sieze them and they weld themselves in.
Denny
'96 F-250 Reg. Cab 4X4 5-sp POWERSTROKE
298,500 mi & NO Problems, LUK Clutch
Dr.Evil is offline
Old 12-10-2007, 06:58 PM   #7 (permalink)
It probably has platinum plugs in it. Replace them with standard plugs and replace them on a regular basis.
The only reason platinum is used is it's the cheapest material that will last 100K miles (federal requirement). It has been proven time and time again that platinum plugs are LESS efficient and cost power.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 12-11-2007, 09:18 AM   #8 (permalink)
UTAH's Avatar
My Photos: (21)
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body"> ...the engine reps from the big three only advised and recommended using Chevron Techron (or a spelling similar) some years back. In fact Ford or GM had a service bulletin saying to run a bottle through at a certain mileage interval. </div></div>
I agree fully. Independent labs continue to show the benefits of running Techron. I only run Chevron and Texaco gasoline in my gassers. It's about 5 cents a gallon more, but since both contain Techron it's worth it.
Bill
Bilge Rat Association member with Ninja Wife
UTAH is offline
