dually fender repair - Diesel Forum - TheDieselStop.com
Old 09-12-2009, 03:48 PM   #1 (permalink)
I recently picked up a straight, rust-free replacement bed for my truck. However, it needs a couple small repairs to one of the dually fenders before it gets installed.
The first repair is to [what I will call] the mounting strips on the front and back of the fender. As you can see in the first picture, they have separated from the fender. What would be the best way to reattach these strips? Fiberglass resin, some other type of epoxy, elmer's glue? I'd rather not have the fender fall off on the highway later down the road.
The second repair is to the mounting point for the lower rear brace. The hole in the bracket to which the brace attaches has broken off, leaving a jagged stub. (You can see the evidence of a previous repair as well.) Could I reconstruct that tab using just fiberglass mat and resin, or should I embed a piece of sheet metal for strength?
Thanks in advance,
RD
1997 F350 CC DRW E4OD POS. electric fuel, DIY6637, Beans Stage I. 200k and counting.
webshots
RD97 is offline
Old 09-12-2009, 09:58 PM   #2 (permalink)
88beast's Avatar
first and second make a piece out of sheet metal roughly following the fender shape with as large a surface as you can
then drill holes where it will touch the fender
and fiberglass woven mat over that
the mat is stronger than the weave
do that for both it will be much stronger than stock and only take a little work
88 F-250 body,550 rear frame setup, 7.3 idi, back up camera, class 5 bumper hitch welded to frame and gusseted, front mount hitch and off road lights,93 front clip, headache rack, 37" humvee tires, ac power converter,factory buckets from quadcab, power windows and locks,cobra 29 cb w/ 102" whip, high lift jack behind seat, toolbox for the junk, visor, running lights, huge front bumper, oba,
in progress western style mirrors, holset turbo, airhorns, and some other goodies
88beast is offline
